Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
I am experiencing a small problem. My pump motor does not operate consistantly all the time. There are times when the controls sends a signal for the motor to start-up. You can hear the HUMMMM of the motor, then is kicks off the dedicated circuit breaker to the tub. However, if when you reset the circuit breaker and lightly tap the motor housing it will allow the motor to start. This has been happening since I started up this summer, about 2 weeks ago. On Friday night when I got home the control panel was showing "5n". The manual states this is a non functional high temp sensor. I unplugged the tub to see if it would reset...it didn't. I also added about 20 gallons of cold water hoping to cool down the spa..thant didn't work. I kinda remember thsi happening a few years back...and all I did was add cold water and it reset itself. Any helpful suggestions woudl be greatly appreaciated.
    Problem Solver:
  • 13 Answers
I would check your sensor connections on the circuit board & also check the wires leading to the sensor(s) (temp as well as hi limit)
during the winter mice love to chew on these things. If the spa finds a problem with any of the sensors it will protect itself & shut down
Posted on Jul 13, 2010
  • 760 Answers
Most likely you received the Hi temp signal, because you had no flow due to the pump stopping. You could have a problem with the control system for the pump motor, or the motor could be having problems. If this motor has a capacitor, it could be failing causing the motor not to start. The bearings could be going bad, and that's keeping it from starting.
Posted on Jul 10, 2010
How do I find out if the wipers on my 2006 H3 Hummeris on a relay?
The Wiper/Washer System consists of the following components:
• Windshield wiper/washer switch
• Body control module (BCM)
• Wiper micro relay
• Wiper 2 relay
• Wiper diode
• Windshield wiper motor
• Windshield washer pump
• Windshield washer nozzles
• Windshield washer solvent container
• Windshield wiper arm and blade assemblies
• Windshield wiper transmission
• WIP/WASH 10A fuse
• WIPER 25A fuse
Wiper/Washer System Description
The body control module (BCM) controls wiper motor low speed operation. The washer pump and high speed operation are controlled directly by the wiper/washer switch. The windshield wiper/washer switch supplies voltage on the signal circuits to the BCM for windshield wiper/washer operation. When WASH, MIST, DELAY, LOW, or HIGH is detected, the BCM energizes the wiper micro relay by suppling voltage to the relay coil. This allows battery voltage from the WIPER fuse to flow through the relay switched input then through the contacts and out the relay switched output to the wiper 2 relay switch contacts. Since the wiper 2 relay switch contacts are normally closed to the low speed circuit of the windshield wiper motor, the motor will operate at low speed.
Low Speed Operation
When the wiper switch is in the Low position, voltage is supplied through an internal resistor to the signal circuit. The body control module (BCM) monitors the windshield wiper switch signal 1 circuit, and energizes the wiper micro relay which will operate the windshield wiper motor. The wiper motor will operate at low speed, since the wiper 2 relay is de-energized. Low speed can also be commanded with a scan tool, by commanding Wiper Relay Cmd. ON and OFF. Refer to Scan Tool Output Controls .
High Speed Operation
In the High position, the windshield wiper/washer switch supplies voltage to both the wiper micro relay and wiper 2 relay coils. This energizes both relays and allows battery voltage from the wiper micro relay switched output to the switched input of the wiper 2 relay through its contacts and out the switched output of the wiper 2 relay to the high speed circuit of the windshield wiper motor. The windshield wiper motor will operate at high speed. During high speed wiper motor operation the wiper switch signal circuit is at the low speed signal voltage, and the body control module (BCM) supplies redundant voltage to the wiper relay via the wiper diode.
This info is out of hummer factory service manual !
Dec 10, 2016 | 2006 Hummer H3
Whirlpool green series WDF750SAYW2 fills with water then just clicks a few times. Does not go to wash cycle...stays on for the entire program time without washing, then drains. Only 7 months old. What...
Sounds like a bad wash pump motor the clicks represent the control relay sending voltage to the motor if motor doesn't operate it cannot return signal to control
Jul 06, 2014 | Whirlpool Dishwashers
What is code P1351
Dec 30, 2011 | 2003 GMC Yukon Denali
Yesterday it was missing and did not want to idle now this morning it will not start. cranks over but does not fire almost like fuel pump or coil is out. any ideas ?
Check the Fuel Pump and the Timing Belt/chain. Being a 2000 it uses a coil pack so checking the timing belt/chain will require removal of one of the valve covers on a V-6 so you can see if the valves are operating when the motor is cranked. In a 4 Cylinder you can usually remove a dust cover from the front of the motor to visually check the timing belt. A Haynes or Chilton's repair manual could give you some tips on how to check it's operation. The Crank Position sensor is also a possibility. If it doesn't send the signal to the ECM for when to fire the cylinders then the motor misses. If it send no signal the fuel pump shuts off to prevent damage and reduce the possibility of fire. What you described could be any of those things mentioned. Make sure you check your fuses to make sure you haven't blown a fuse on the fuel pump circuit causing your current situation with a no start condition.
Jan 13, 2011 | 2000 Ford Windstar
My rear lift gate on 07 tahoe opens and closes its self weather the key is in the ignition or not, opens 1/2 way closes 3/4 then all the way up and all the way down, sometimes it sets off the car alarm- it...
Operation
A power open or close cycle can only be initiated from the fully closed or open positions while the vehicle is in park and the liftglass ajar switch input to the liftgate module is inactive. At any time during a power open or close cycle the operation can be reversed by pressing any of the open/close switches. The power liftgate can be switched to manual mode with the on/off switch in the overhead console and during manual operation the power latch will still operate. During power liftgate operation the liftgate module continuously monitors the liftgate position and load profile. The position is calculated from hall effect sensor counts and the electrical load of the gear motor is used to determine physical resistance to the liftgate. Both of these profiles must be learned before the liftgate can operate properly and relearned any time most liftgate components are serviced.
Object Obstruction Detection
The liftgate control module continuously monitors power liftgate operation and calculates its location and direction of travel using 2 hall effect sensors that are part of the gear motor assembly. The hall effect sensors are 3 wire sensors and are supplied with a 5 volt power circuit, ground and signal circuits from the liftgate control module. The hall effect sensor signal circuits are referenced from battery voltage within the liftgate control module and pulsed low by the hall effect sensors.
The power liftgate system uses a secondary object detection method which consists of object sensors fixed to both sides of the liftgate near the seal area. The object sensors consist of an internal fixed resistor and normally open switch contacts which when closed will bypass the resistor. The signal circuit is supplied 5 volts through a resistor and monitored within the liftgate control module, and during normal power liftgate operation the signal circuit should remain a fixed value. When an object presses one of the sensors the contacts close and the resistor is bypassed causing the signal circuit voltage at the module to go low.
Gear Motor Assembly
The liftgate motor is a bi-directional motor and open or close operation is the result of the direction of the motor rotation. The liftgate module controls the liftgate motor through the control circuits by suppling power and ground in the appropriate polarity. The motor control circuits are monitored by the liftgate module prior to activation for a high or low condition and during motor operation for any irregular current flow conditions.
The liftgate motor clutch engages or disengages the liftgate motor to the liftgate drive gear and is the component that determines power or manual operation. When the liftgate module supplies power to the clutch control circuit the clutch coil is energized and the liftgate motor is engaged to the liftgate drive gear so that power operation can occur. The liftgate module monitors the clutch control circuit at all times for a short high while in an inactive state or a short low or insufficient current flow while in an active state.
The full open switch is part of the gear motor assembly and will close and become active when the liftgate reaches the full open position. The full open switch signal circuit is supplied battery voltage through a resistor and monitored within the liftgate module. The liftgate provides a low reference circuit and when the switch contacts close the signal circuit goes low and the liftgate module determines the switch to be active.
DTC B153A 00: Liftgate Latch Switch Signal Circuit
DTC B153A 08: Liftgate Latch Switch Signal Circuit Signal Invalid
When calibrating the liftgate position, the liftgate module (LGM) is placed in a functional state to learn the liftgate travel limits. DTC B1019 00 will set automatically as an indicator that the system is in learn mode and not as a fault indicator. Once the travel limits are learned by the liftgate module, the LGM will exit calibration mode. If the LGM does not exit learn mode, DTC B1019 00 will remain current and indicate a fault.
DTC B153B 02: Liftgate Open Switch Signal Circuit Short to Ground
DTC B153B 05: Liftgate Open Switch Signal Circuit Short to Short to Battery or Open
DTC B153E 02: Liftgate Position Sensor Signal Circuit Short to Ground
DTC B153E 05: Liftgate Position Sensor Signal Circuit Short to Battery or Open
DTC B153E 08: Liftgate Position Sensor Signal Circuit Signal Invalid
Your best bet , take it to the dealer .
Aug 08, 2017 | Chevrolet Tahoe Cars & Trucks
Aquarius FDM550 after 1st rinse continual noise from bottom right rear of machine! pump or motor or what???
It is a pump motor noise. If it stops after some time leave it. If the water empty not sending signal to the controller also this problem could occur.
Contact service provider for further assistance.
May 21, 2010 | Dishwashers
Thermostat calls and from time to time won't ignite
I would first look at any wire connections both at the furnace and the thermostat. Then I would replace the thermostat. Check the units control board when it does not start for an error code. There should be a small viewing port to look into the furnace cabinet to see the control board.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Feb 12, 2010 | Goodman Heating & Cooling
I have a krups xp2070 that i just put a new motor in. When making espresso, the water pump does not turn off. Is it related to the little relay switch that connects to one side of the pump?
The unit is programmed to operate the pump for a very specific period of time depending on the function. Power to the pump is provided by the main power module but controlled by the control module. Either the module is not sending the right signal or the relay on the power module is stuck on. You could try programming the espresso time to reset the pumping time. Will the pump stop if you press the espresso 1/2 cup button again?
Dec 12, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
What is a p1138 code for a nissan sentra 2005? i searched on the net it says switch control valve? what is this?
COMPONENT DESCRIPTION
Swirl Control Valve
Swirl control valve consists of actuator and valve. The valve is
installed in the intake manifold, and the actuator is connected to the
rear end of the valve shaft.
The swirl control valve uses a step motor which has four winding
phases. It operates according to the output pulse signal of the ECM.
Two windings are turned ON and OFF in sequence. Each time an
ON pulse is issued, the valve opens or closes. When no change in
the control position is needed, the ECM does not issue the pulse signal.
A certain voltage signal is issued so that the valve remains at
that particular opening.
Dec 01, 2009 | 2005 Nissan Sentra
I need to know the timing sequence for a 1998 Mercury Mystique 2 liter
ignition timing or valve timing?
ignition timing not setable.
info:
The ignition system consists of an ignition coil, spark plug wires and spark plugs.
The crankshaft position sensor signal is the basis for ignition timing calculations. The alternating voltage signal from the crankshaft position sensor is digitized by the powertrain control module. This digitized signal is then used to position the closing time of the primary circuit of the ignition coil.
Ignition angle is determined by the powertrain control module in response to engine operating conditions. Once ignition angle has been determined, the powertrain control module interrupts the current to the primary circuit of the ignition coil thus triggering the ignition spark which is supplied to the cylinders through the spark plug wires and spark plugs.
The ignition coils are triggered by the powertrain control module in pairs (cylinders 1 and 4 and cylinders 3 and 2) sending one ignition spark to the firing cylinder and one ignition spark to the corresponding cylinder on the exhaust stroke. This make sures that any unburnt fuel residues remaining in the cylinder on the exhaust stroke are re - ignited to provide cleaner exhaust emissions.
May 06, 2009 | Mercury Mystique Cars & Trucks
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
492 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
wadingriver
wadingriver
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
