Question about Epson Stylus Photo RX680 Printer
Epson RX680 printer reports "a printing error has occurred. Turn the printer of then on again." This does not solve the problem at all. The print carriage is not locked wit the power off as I would expect. If I repeat turning it on and off, it will start up OK, but will not do anything without reverting back to the same error message. There is no paper jammed anywhere in the printer. One of the times that it did seem to boot up correctly, I tried to copy a page. The feed progressed to the point where printing would begin, and the same error happened again. "A printer error has occurred. Turn off the printer and turn it on again. Please see your documentation." Needless to say the manual (the documentation) offers no help at all.
TheBigW
  • 34 Answers
SOURCE: RX680 Printer Error
Try turning it off and taking out the ink cartridges and putting them back in. If that doesn't work it could be defective. If it's new then it should be under warranty.
Posted on Oct 07, 2008
jacklee366
  • 541 Answers
SOURCE: Epson R320 "General Error" message - unable to clear
try downloading the ssc this will reset your printer
Posted on Mar 03, 2009
gwbm
  • 353 Answers
SOURCE: EPSON BX300F prints a page and then shows Printer Error.
Try uninstalling your printer, rebooting the computer, then re-installing your printer. If this does not work, it will require the printer top cover to be removed for further investigation. Either take the printer to a technician to investigate, or if you want to have a go yourself, post a new comment to this effect and I will provide information on how to proceed.
Posted on Mar 22, 2009
aicaxz
  • 511 Answers
SOURCE: epson c90 paper feed problem
Is the message general error? The problem is tchip. When turn on chip is recognized by printer, but when start to print, printer "read" some information from the chip. Here is the error. Some pin at the chip for redaing the existence of chip, other pin for reading the information. Check connector between chip and carriage.
Posted on May 30, 2009
  • 14 Answers
SOURCE: I have an Epson RX680 printer. When I turn the
Press the stop/clear button then press the maintaince button(spanner) and the ON button all at the same time in that order.That will reset it.
Posted on Apr 26, 2010
SX415 Error message A printer error has occurred - switching off and on again results in the same message.
Diagnosing the Problem - Epson
https://files.support.epson.com/htmldocs/rx620_/.../trble_1.htm
EpsonAn error has occurred in the printer parts. Turn this product off, and then back on. If theerror message still appears, contact your dealer. Scanner error occurred.
Epson printer sx415 printing problems/paper jam - Forum Thread ...
www.pcadvisor.co.uk > Forums > Tech Helproom
Jun 30, 2010 - Epson printer sx415 printing problems/paper jam ... before it will work correctly again otherwise you will continue to get the error message.
Oct 08, 2015 | Epson Stylus Office Equipment & Supplies
I have an Epson RX680 the black and yellow ink are not printing after trying several print head cleanings and even replacing the cartridges (even though they were better then half full)
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Nov 15, 2012 | Epson Stylus Photo RX680 Printer
HOW TO CLEAN ROLLERS FOR EPSON RX680 PRINTER
Follow these steps to print the nozzle check:
  1. Make sure plain, letter-size paper is loaded in the sheet feeder.
  2. Make sure the CD/DVD tray is not inserted in the Epson Stylus and the CD/DVD guide is in the paper printing position.
  3. Press the Setup button.
  4. Press cp_button_41_er.gif or cp_button_42_er.gif to select Maintenance and press OK.
  5. Select Nozzle Check, then press OK.
  7. Press cp_button_6.gif Start to print the nozzle check.
Oct 28, 2010 | Epson Stylus RX680 Color All-in-One InkJet...
Jan 31, 2010 | Epson Stylus Photo RX680 Printer
Won't reconize new ink cartridge rx680 printer
hi friend,
Run the Head Cleaning utility to clear any clogged ink nozzles. To run the Head Cleaning Utility, follow the instructions below.
For Windows users:
1) Make sure that your printer is ON and the error light is off.
2) Access the printer software.
3) Click the Utility tab, then click the Head Cleaning button.
4) Follow the on-screen instructions
5) When the power light stops flashing, click Print nozzle check pattern in the Head Cleaning dialog box to confirm that the head is clean and to reset the cleaning cycle
If you find that any segments are missing from the nozzle check pattern, you may need to repeat the head cleaning and print the pattern again.
Or u could consult the user manual
u should let the ink settle for 12-24 hrs???
hope this helps u
please rate me..........................
thank u for using fixya
regards
sivaranjini
Nov 25, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
Epson RX680-How to print only in B+W
You can set it to "grayscale" and supposedly print only in black/grey.
However, Epson printers use a small amount of every color even when printing black only or greyscale (black). Your printer will still not work with one color tank empty.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=FAQ&oid=90584&prodoid=63069505&foid=95907
Here is how to set it:
Open the properties page for the RX680 and on the "Main" tab, click on [Advanced]. A Note may appear egarding incorrect settings.
Click [Continue]. Find the [ ] Grayscale box and check it, the [OK]
[OK], etc.
Here is Epson's note on using grayscale / colors:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=FAQ&oid=90584&prodoid=63069505&foid=95908
Sep 24, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
What is specialty print on the epson rx680?
The Specialty Print service on the Epson RX680 allows you to restore colors in faded photos, correct poorly exposed photos, reduce redeye, and even crop while you copy photos.
Aug 29, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
Printing lines across the picture
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Overview&oid=90584
Q: How can I tell if the computer or the printer is causing a print quality problem? A: You can print a nozzle check pattern to determine whether the print quality problem is caused by the Epson Stylus Photo RX680 Series or some other source.
Above under FAQ
Dec 10, 2008 | Epson Stylus RX680 Color All-in-One InkJet...
Epson Stylus Photo RX680 Printer Logo
585 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
