Samsung SpinPoint P80 SP1604N 160 GB Hard Drive Logo
A
Anonymous Posted on Jun 18, 2010
How do I change the setting from Master to Slave?
Anonymous
Level 3:
President:
  • Master 1,566 Answers
  • Posted on Jul 10, 2010
Anonymous
Master
Level 3:
President:
Answers
1566
Questions
0
Helped
386340
Points
4966
To set it to slave, just remove the jumper/s.
For more information, you can look it up on the manual.
http://www.fixya.com/support/p284394-samsung_spinpoint_p80_sp1604n_160_gb/manual-19289#
How do I slave a cd-rom drive in a dimension 1100
Most CD or DVD drives installed in modern computers have a group of short jumper pins on the rear of the drive that determine the master or slave setting for the device. The master or slave setting helps to identify the drive when it shares a connector cable inside the computer with another device, such as a hard drive or even another optical drive. Without the master or slave jumper setting, the computer would not be able to tell one device from another or from which drive to retrieve or write data. Configuring a CD drive as master or slave is a relatively simple task that takes only a couple of minutes.
Turn the CD drive so that you view the rear of the unit, then check the position of the jumper covers on the set of pins next to the power adapter plug. If the CD drive will be the only device on the IDE data ribbon cable, set the jumper cover on the two pins farthest away from the power connector. This position is the master drive setting, and, by default, most CD drives ship with this configuration. In most cases, if the CD drive is the only device connected to the cable, you do not need to change the jumper setting. Determine if you need to change the CD drive jumper setting if the device will share a connector cable with a hard drive or another optical drive. If the CD drive will be the primary (master) device on the cable, do not change the jumper setting. If the CD drive will be the secondary (slave) device on the cable, continue to the next step to change the setting. Use a pair of needle-nosed pliers or your fingers to remove the jumper cover from the CD drive if the unit will be the secondary device on the IDE ribbon cable. Set the cover over the pair of pins next the pair from which you removed it, then press it until it completely covers the pins. The jumper is now in the slave setting position.
Pins location master slave
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to IDE-1 means Pri slave escape then press f10 to save to cmos to restart
you will have to have master with slave set up
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master
IDE-2 means Sec master
IDE-3 means Sec slave
single or master :::::
master with slave ::'::
slave :::':
black line between dots is plastic jumper
note the plastic jumper is ' located at the rear of the hard drive between the EIDE and electrical lead/s
Hope this helps
I have two hard drives. Both hardrives are recognized but only one has a drive letter of c the other does not have a letter. Both drives are set for cable select. I have also set them for master and slave...
slave :::':
Hope this helps you
1helpful
Jumper settings for master drive
if its a SATA hard driveyou dont need to set master slave the biggest capacity hard drive will set as master
slave :::':
Installation of the drive and setting of jumpper to make it either as a master or slave
slave :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
How do I set the jumpers to make it a slave?
slave :::':
[email protected] How do I slave HDT721050SLA360 500GB 7200rpm
if you want to set a master / slave on you computer
slave :::':
How to set hd fujitsu MHZ2250BJ as slave ?
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
1helpful
Hard drive problem
Although I covered most of the ways to speed up Windows boot time in another article, I encountered a unique roadblock recently that made me write this article.
During the last week I was asked by a customer to upgrade one of their office computers from Windows 98SE to Windows XP. Normally this is pretty standard, however because their current hard drive was only a 20GB with a gig or so remaining I wanted to upgrade their hard drive as well.
I proceeded to ghost the drive to a larger hard drive and then installed an upgrade version of Windows XP on top of Windows 98 to preserve all of their settings and programs.
Everything went flawlessly, until I was finished...
After I completed the Windows XP upgrade, I shut down the computer completely and restarted it. The computer took FOREVER to boot into Windows XP. It was literally 2 minutes before I saw the Windows XP logo screen and another 30 seconds more before the desktop appeared. This was definitely a problem.
After checking multiple settings in the BIOS, I compared the old and new hard drives. Everything seemed to be normal, except one. The old hard drive was setup to Cable Select and as my normal routine I had set the new hard drive as a Master drive. I changed the new hard drive to Cable Select, rebooted the computer, and the Windows logo screen came on seconds after the POST screen as before. Therefore, I have to add one more item to my list of ways to make Windows boot faster. Try changing the hard drive from Master to Cable Select, check the boot up speed and switch back to Master if you don't see a change.
Master/Slave Settings
Now for a refresher course on hard drive connections. When connecting more than one hard drive to a computer on the same IDE controller, you generally have to assign one as the primary (master) and one as the secondary (slave). You do this by changing the jumpers on the hard drive next to the power connector. Normally, the drive will have a diagram to let you know which jumper should be set for a master drive and which to set for a slave drive. You'll notice in the picture below the jumpers are circled on the end of the drive and the top of the drive shows the diagram to follow.
After changing the jumpers, connect the hard drive cable from the motherboard to the hard drives. Under normal circumstances, the end of the drive cable attaches to the Master hard drive, while the inside connector on the cable connects to the Slave drive.
What About Cable Select?
Cable Select (CS) settings were designed to make it easier to connect hard drives because you didn't need to bother with setting the Master/Slave jumpers. You just connect the drives and depending on where you connected them to the cable the computer would know which is Master and which is Slave...in theory. Now comes the confusing part.
With cable select, you first needed a special 40 conductor IDE cable that would determine master/slave connections. This was different from the normal IDE cables at the time. Also, the Master connector on CS cables was the inside connector not the end connector. This made for a very confusing switch from everyday master/slave configurations.
80 conductor Ultra DMA cables WILL determine the Master/Slave settings through Cable Select however. So as technology advances, Cable Select as a concept may still catch on. With the newer Ultra DMA cables, you can set both drives to Cable Select (CS), connect them and they will work. Another change with the 80 conductor cables, the Master connector is on the end of the cable where it should be. In situations where you are using a newer Ultra DMA drive and cable, you can use Cable Select or standard Master/Slave jumper settings and the drive will boot properly.
In my scenario to start this article, the change from Master/Slave to Cable Select for this particular computer reduced the Windows boot time by more than 2 minutes.
For more information on Master/Slave settings versus Cable Select visit the following pages:
Mike's Hardware: How to Connect IDE Hard Drives
Configuration using Cable Select
UnixWiz.Net: Using IDE Cable Select
2answers
Slave pin settings
hi frined
remove your hard disk jumper & u r hard will be slave
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
