Question about IBM ThinkPad T20 2647 Notebook
Does not boot error says no hard disk. I took out the old hard disk and installed a new one.
  • 6,826 Answers
Make sure that the hard disk you put in is one supported in size by the bios of the laptop.
Posted on Jul 10, 2010
Hp designjet t1100 blank hard drive installation
Unfortunately I had a similar issue with an HP A0 printer. The Hp 'Engineer' could not fix it. The hard drive had failed and there is a complete new hard drive with software loaded available but only through Hp.
Feb 27, 2014 | HP Designjet T1100ps Printer
Mine hitachi hard disk is 80GB SATA i cant able to install OS because it is showing error some virus found and u r not able to formate this. first when i put OS CD in drive it will install some files and...
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Apr 15, 2011 | Hitachi (14R9464-20PK) 250 GB Hard Drive
I get an error message saying error loading operating system when i boot up
Some essential files required at boot are corrupted. Try to perform a Repair install. If this doesn't fix it then the hard disk itself is damaged. Install a new hard disk, do a full install to it put back the old disk in and recover what you can from it before junking it.
Jul 02, 2010 | HP Media Center PC 873n (P9875A#ABA) PC...
DELL Inspiron disk failure how to recover OS in new hard disk?
Unfortunately you will need the restore disk to correct this problem. Even if you copy the old disk to the new, chances are you will copy the corrupt files and have TWO bad copies of xp. You can order the restore disk from Dell on average about $30.
Good Luck
C2Solutions
Jan 28, 2010 | Dell Inspiron 6000 Notebook
Installing windows on acer notebook help
you cannot usually switch installed operating systems from computer to computer like that and still expect windows to boot, but with windows 98 it *might* work.
to install windows 98 on the usb drive, insert and boot from the windows 98 disk like you were to install it on that computer , and then, it should, before it formats any drives, give you a choice of what drive to format.
Oct 09, 2009 | Acer TravelMate 340T Notebook
Windows xp pro will not boot with new hard drive
Its hard to tell just like this without having the computer in hand to check and test the jumpers and connection and all, but quick like this i think it might be a trojan virus that corrupted the boot sectors of the old hard drive, and when you copied the stuff from the old to the new, the virus followed and infected the boot sectors of the new one too. Try to reformat completely using the original windows install disk, and not the system restore/reinstall disk and reinstall windows after the format with the original windows disk again. If I was right, it should boot up OK with a fresh format and reinstall with the real windows CD, then install a virus scan and a spyware scan and scan and clean the old drive completely 2 or 3 times to be sure theres nothing bad left on it, then try to copy the whole disc, but skip the Windows repertory, the Program Files one too and the Documents and settings one also, cause those 3 are the ones most prone to corrupting a fresh install even if there is not any viruses in them. If it does not boot up OK after formating and reinstalling Windows though and says it's unbootable, then either there is a config error in the BIOS of the laptop, or the IDE controller that drives the disk is defective. If it's the BIOS settings, it's gonna be easy enough just changing the settings and won't cost you too much, and if its the IDE controller... then that's another story cause it's integrated in the motherboard like any other computer, so basically another computer will cost less than a new motherboard for a laptop. So if that is the case and the IDE controller is shot, you can still try to use an external USB drive to run the computer but not all computers support booting from the USB though, so before buying a brand new external drive, check the BIOS first to see if it does support USB booting.
Jul 08, 2009 | Compaq Evo N610C Notebook
Disk I/O error Replace The disk, and press any key
Its the problem with your Hard disk. Try to boot from xp cd and install a new copy. you will get error on installing if Hard disk is damaged. then you have to replace with new one
Apr 05, 2009 | Computers & Internet
Dell inspiron e1505 not booting up(currupt hard drive). Did system test and getting serveral errors for hard drive test fail. error ofoo:1a44,065d,0244, Thanks, Rob
You have two options, try to back up your data and reinstall windows is that hard disk or buy a new disk, install it windows and use the old disk as second HD, just to store data.
Aug 13, 2008 | Computers & Internet
Consistent hard Drive BOOT ERROR after an upgrade to MSNV-939 motherboard
You can run a disk manager for your drive however, I'll bet you will find its windows boot.ini. It may read just fine for a dual boot system but think about this. Windows can get confused real quick. I'm talking about the regestry. Take the time and do a fresh install of your Linuex and than re-install windows "clean install". I'll bet everything works out just fine. When 1 changes MB's there is a whole list of new drivers PCI devices loading into windows. Your system will run better with one copy of drivers for your new board and windows will not carry a list of old drivers and PCI devices of your old board.
Oct 17, 2007 | Mach Speed (MSNV-939) Motherboard
Consustently get "DISK BOOT FAILURE _ INSERT SYSTEM DISK AND PRESS ENTER" message
use xp sp2 bbootable disk and simply run a repair installation it should heal your system
IBM ThinkPad T20 2647 Notebook Logo
42 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
