Question about HP PSC 750 All-In-One InkJet Printer
How do i change the ink cartridge for an hp psc 750 model ? Thanks
  • 1,476 Answers
It should be as simple as lifting the top assembly, between the scanner and the printer, and wait for the cartridge to relocate to the center of the machine. Pull back on the top of the cartridge to remove it. Make sure that you remove the protective tape from the new unit and install it in the reverse procedure.
You will need to do a head alignment. Open the control panel, click on "installed printers and other hardware", click on "view installed printers and fax printers", click on the printer in question, under "printer" choose properties, click on cartridge maintenance and follow the instructions to print a test page and reset the cartridge if necessary.
This should finish your cartridge change. Let me know if you need more assistance.
Thanks for using FixYa and for the generous rating.
hardrocko
Posted on Jul 10, 2010
Actaviosan
  • 100 Answers
SOURCE: hp psc 750 xi how to replace black ink cartridge
1) Pull out your old black ink cartridge, py pressing the button on top of the old cartridge and pulling it down.It will be released, then just get it out.
2) Look at the back of your new ink cartridge, there should be a small panel with some small squares and kinda orange panel, this is the side that should not face you, it should face the ink cartridge holder on the printer.
Just put it in like that. Tell me if you have any problems.
Posted on Nov 17, 2007
SOURCE: Cannot locate ink catridge for HP PSC 750 printer
With power on, simply lift up from the hatch located on the front of the unit. The ink jet will slide to the middle position.
Posted on Mar 28, 2009
  • 38 Answers
SOURCE: Align page not detected error on HP PSC 750 printer
Need to replace all print head with error or nozzles block
and try for alignment
once the page is printed it needs to be scanned to save alignment
if still get same message need to check for scanner functionality
Posted on Nov 08, 2009
edmacias
  • 70 Answers
SOURCE: how to change ink cartridge on hp psc 1510
Hi, Please check this link: http://h10032.www1.hp.com/ctg/Manual/c00366227.pdf
Refer to pages 43-48 (printed number on the page or pages 46-51 in the PDF page guide)
Hope this works for you.
Cheers, Ed
Posted on Nov 25, 2009
  • 157 Answers
SOURCE: I have a hp psc 750 and have just put a new black
Did you make sure you removed the plastic tape protection before installing the cartridge? Check to see if there is anything on the bottom of the unit. It could be the problem. Check the install instructions.
Posted on Feb 01, 2010
How to change ink cartridge hp psc 750
1- Open the printer
2- Remove the ink cartridges from the print head.
3- Use cotton swabs dipped in hot water to thoroughly clean the print head.
4- Repeat this until there is no ink residue coming off on the cotton swab.
5- Once finished, allow to dry and replace the cartridges
Mar 19, 2013 | HP PSC 750 All-In-One InkJet Printer
I just hooked up my hp psc 750 printer to my laptop do you have to have a color ink to use this all in one printer
Yes you have to use both the black and color cartridge in order for the printer to work. Both cartridges need a good supply of ink in them to, or it wil not print.
May 24, 2011 | HP PSC 750 All-In-One InkJet Printer
Wheres the ink cartridge?
Information on how-to change Ink is located here.
If you are satisfied with my answer, be sure to click on the "Thumbs-Up". If you have further questions, please feel free to ask them. Thanks for using our service!
May 04, 2010 | HP PSC 750 All-In-One InkJet Printer
How to install ink cartidge? hp psc 750
1. Allow your injet printer to run entirely out of ink. Unless the quality of your images is suffering, there is no problem with letting your ink run low.
2. Open the printer door. It should fold from the top down toward the tray. When it is open, it should expose the inner workings of the printer.
3. Press the change cartridge button. It is at the top of the printer next to the power button.
4. Pull on the green top of the inkjet ink cartridge and remove it up and out of its holder. Do this gently so the printer is not damaged in the process.
5. Recycle the empty inkjet cartridge or have it refilled at an ink refilling center.
6. Carefully remove the tape from the refilled or new inkjet ink cartridge and insert the cartridge in the same orientation as the one you removed.
7. Push on the green top until the cartridge snaps into place, press the cartridge change button and close the printer door.
Feb 08, 2010 | HP PSC 750 All-In-One InkJet Printer
I have a hp psc 750 and have just put a new black ink cartridge in and keep on getting the error message wrong black ink cartridge
Feb 01, 2010 | HP PSC 750 All-In-One InkJet Printer
Color ink is out I need to print black and white can I change it
you need to have both cartridges with ink for the unit to work.
thanks
Apr 17, 2009 | HP PSC 750 All-In-One InkJet Printer
Mar 27, 2009 | HP PSC 750 All-In-One InkJet Printer
Black ink Cartridge
Ink Cartridge Supplies for the HP PSC 750
Description
C6615A Black Ink Cartridge (HP #15)
C6578AN Color Ink Cartridge (HP #78)
That's right according to the above info
Try
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 09, 2009 | HP PSC 750 All-In-One InkJet Printer
HP PSC 750 All-In-One InkJet Printer Logo
433 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
