I GOT WHIRPOOL WASHER , NOT DRAINING WATER. PL HELP ARAIN
    President:
  • 1,554 Answers
Check the drain hose or clogs and kinks whether the machine is a front-loader or a top-loader and make sure it is clear and free of any obstruction. Front-loaders usually have pump filter that can access through the toe panel. Remove the screws attaching the bottom of the toe panel to the cabinet then slide the panel down and off. Propping up the bottom front edge of the machine or cushion its top rear edge and lean it against the wall for easy access and removal of the screws. Unscrew the filter and clean it. Also make sure the pump impeller is turning freely.
For top-loaders, the cabinet needs to be removed for access to the drain pump. Please indicate the exact model number of the machine for specific troubleshooting and repair advice. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from posting comments or follow-up questions. You can continue communicating with an expert as long as you need assistance regarding the issue stated herein.
Posted on Jul 10, 2010
Frontloadernot draining
Take the power plug off the wall. Be prepared for a lot of water before attempting the following. It doesn't spin because the unit is not draining water. It will not spin with water in it - must drain first. Check drain hose for kink,check exit pipe for blockage. Remove the front access panel, bottom front, screws beneath; if you find a hose there with a cap -this is for draining water. Could be your "coin trap assembly" is blocked, therefore not allowing all the water to pump out. Remove the clamp (or unscrew) that connects the trap assembly to the pump and clean it out.
Pl click so if helped
Apr 08, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Washer fills with water but does not go to next cyle
Take the power plug off the wall. Be prepared for a lot of water before attempting the following. It doesn't spin because the unit is not draining water. It will not spin with water in it - must drain first. Check drain hose for kink,check exit pipe for blockage. Remove the front access panel, bottom front, screws beneath; if you find a pipe there with a cap -this is for draining water. Could be your "coin trap assembly" is blocked, therefore not allowing all the water to pump out. Remove the clamp (or unscrew) that connects the trap assembly to the pump and clean it out.
If helped pl click so.
Apr 02, 2013 | Frigidaire FTF530FS Front Load Washer
I took clothes out of my frigidaire affinity washer and there is water resting in the drum of the washer what does this mean
If helped pl say so.
Mar 18, 2013 | Frigidaire ATF6000ES Front Load Washer
Hi I have a 5 cycle 2 speed top load whirpool washer and it all of a sudden will not go to the Spin Cycle and drain out the water. It stops in the rinse cycle. I need help!
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 25, 2011 | Washing Machines
Not draining all the way
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Pl give me a very good rating for the long awaited free help!
Jun 07, 2010 | Kenmore Elite 45986 Front Load Washer
Water seeps into Whirpool Duet washer
If your washer is leaking water when it is not in use, the following link explains how to troubleshoot to isolate the cause:
http://www.fixya.com/support/r3753262-front_load_washer_fills_when_not_in_use
The problem is either attributed to a defective pressure switch or a water inlet valve that is leaking by. The link I provided will explain how to determine which one.
If you still require assistance, please let me know.
Jan 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Draining water from washing machine
Filter is normally down r/h side of machine it unscrews anti clockwise..Good luck
Oct 10, 2009 | Whirlpool AWM6100 Front Load Washer
Whirpool Duet - Soap not getting into wash cycle
O.K. Is the water draining out properly? If the filter is blocked then your washing will be churning in dirty water as the machine will drain for a maximum time then rinse etc. in the used water.
May 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Ultimate Care II keeps taking water.
ck your drain nose/drainline, chances are you have along hose, perhaps even draining along the floor behind hte unit, into a "closed" drain system. in which cawee the wwater is syphoning out during the rinse cycle, youlll needt o raise the drain hose to above 48" and have it drain into a stand pipe to prevent siphoning effect
Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirpool top load washer
things to check, to narrow it down:
  • is the timer stopping prematurely? (timer problem)
  • is the machine draining the water as fast as usual? (water pump problem or something blocking water flow)
  • is it spinning as fast as usual? (clutch problem)
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 11, 2008 | Washing Machines
Open Questions:
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
