Question about Fedders Y Chassis A6Y18F7A Air Conditioner
Will my Fedders A/C unit run on 110 volt outlet?
Will my Fedders A/C unit run on 110 volt outlet or do I need 220? The sevice # is A6Y18F7A-D, & serial # ER 141155 146Y
    Guru:
  • 1,524 Answers
220 V unit requires a 220 V outlet
Posted on Jul 10, 2010
What do i have to do to plug my 110 air conditioner into where my 220 window unit
You need a step down transformer, to convert 220V to 110V. You can't just plug the 110V A/C unit in directly unless it is clearly marked as being suitable for multi-voltage supply (110V - 220V input).
Such a transformer has to be of sufficient capacity to handle the current, or wattage, that will be required. The Frigidaire unit in your question is a 3.5 kW cooling capacity, so the transformer would need to be about the same, ie for a 10A supply at least. They are quite big boxes, about $120.
http://welectronics.com/TRANSFORMERS/step-up-down.JPG
You would put this in the roof or in a cupboard.
Apr 25, 2015 | Frigidaire FAC126P1 wall/window Air...
Tip
How to convert 220 volts to 110 volts for the iPod Touch
<p> <p>The battery of an iPod Touch prepared for use in the United States is designed to be reloaded from the current supplied by a 110-volt electrical system. Power is transmitted to the battery charger with an iPod battery, which are connected via a USB cable and then connected to a 110 volt outlet. To use the power of a 220 volt outlet with an iPod Touch, set the current 220 volts to 110 volts. A conversion adapter voltage, also known as "Step Down Transformer," it is necessary and can be obtained from an electronics store, a hardware store and even some drug stores. <br /> <p><br /> <p>1. Place the 220-110 voltage converter card (aka, "Step Down Transformer") next to a 220 volt outlet. Plug the adapter into the outlet. <br /> <p><br /> <p>2. Connect the end of a USB cable to the USB connector USB iPod charger iPod. Connect the other end of USB cable into your iPod's own socket on the bottom of the iPod Touch. <br /> <p><br /> <p>3. Plug the iPod into the 110 volt outlet in the battery adapter for the iPod Touch. <br /> <p><br /> <p>4. Unplug the charger from the iPod adapter and the adapter from the outlet when the battery is charged. Unplug the USB cable from the iPod charger and iPod Touch. <br />
on Aug 09, 2011 | Apple iPod touch
How can I wire a 110 outlet to a 220 outlet?
If the bed is a 220 volt, you can only use a 220 volt outlet.
If the bed is 110/220 you should check the web for specs and wireing.
May 31, 2014 | Health & Beauty
Need to how the power source will be hooked up, and how, it will wire into a 13 SEER Goodman Packaged Unit, with HKR-15 strips. wire size?= 15 Ft. run: panel to unit
Minim 20 amp circuit ... is this 110 or 220? You need to know.
20 amp circuit needs to have #12 wire. If 110 Volts, you need a black, white and green #12. If 220 Volts you need a black, a red, and a green. If you have anything IN the unit that needs 110 (probably not), you need black, Red, White and Green (bare) #12 wire. Definitely needs to be on a dedicated circuit. If your unit has a resistance heater (electric) you will need a 30 amp circuit (probably 220) which needs #10 wire minimum. 220 volt breakers are double. You will need two spaces in your panel box. Would not hurt to put in heavier wire (#8) protected by a 30 amp breaker ... $ is the governing factor.
Having said all of that --- you should be reminded that I dont even know what country you are in nor your prevailing voltage nor what your national or local codes require. My comments based on installing several Goodman products over several years on the Eastern Seaboard.
Aug 26, 2011 | Heating & Cooling
What will the size wire will i need to wire up to consumer unit
It depends on if you are running a 220 or 110 volt supply. Assuming that your supply is 110 volt and your microwave draws about 2000 watts, that would mean that you need a wire with a cross section of about 2.5 sq, mm to allow a safety margin. If your mains are 220 volts you can use 2 sq mm or a little less - say 1.5 sq mm to be on the safe side. (On 220 volts a microwave draws aprox. 2 amps for every 200 wats output and 1 sq mm wire can carry 10 amps - as a rule of thumb. At 110 volts these figures are roughly double).
Feb 13, 2011 | Microwave Ovens
Maytag model MDE7057AYW 5600 Watts dryer runs ,but
5600 watts will not operate off 120 volts.
This is a 220/240 volt hookup.
There are 2 legs of 120 volts each that operate the dryer.
The only part requiring 220v is the heater.
Otherwise 120v routes through the various controls and relays.
Mar 12, 2009 | Maytag Dryers
COOK TOP WIRING
 You have Red and Black HOT wires and a Green Neutral - That is 220 volts. From the wall - Black is Normally HOT and White is Neutral. That is 110 volts. If that is a typical household outlet, is will only supply a demand at about 15 amps while running at 110 volts. Your Cooktop will most likely demand somewhere around 50 amps at 220 volts. - Short Answer - You will need to have a 220 volt supply line ran to the cooktop from the breaker. Easy to do but dangerous if you are unfamiliar with high voltage.
Apr 30, 2008 | Jenn-Air JED8430 Electric Cooktop
Wiring a stove
If there is no 220 outlet in the location where you're planning to put the stove then you need to run wiring to the new location. There are two seperate phases of 110 volts coming to your home. The voltage between each of these phases and the neutral wire is 110 volts. When your house was wired only 1 of the 110 volt signals was run to your 110 volt outlets. In order to create a 220 volt outlet you need both of the 110 volt signals run to the outlet.
If you have a straight shot between your breaker box and the location where you need the 220 volt outlet then this is not too big a deal. If you have finished ceilings and walls inbetween then this will be much more difficult.
If you're not comfortable with electrical wiring this would be a good time to call a licensed electrician.
Nov 18, 2007 | Ovens
Fedders Y Chassis A6Y18F7A Air Conditioner Logo
138 people viewed this question
Top Fedders Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Mike
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
