Question about Refrigerators
How do I program the controller for this model of refrigerator? The control panel is locked and the door alarm light is on.
  • karichris_20 Jul 16, 2010
    The advice I received did not fix my problem. All I need to know is how to enter the programming mode to enter the code to unlock the control panel...
  • Refrigerators Master
  • 6,826 Answers
What refrigerator are you referring to?
What make and model?
Posted on Jul 16, 2010
  • 2 more comments
    Maytag side by side with a freezer drawer. Mod# MFI2266AEU. Are you able to read the previous thread?
  • Duane Wong
    Duane Wong Jul 16, 2010
    I read the manual .pdf file file your model and the only alarms are the following:
    Temp Alarm
    The Temp Alarm feature provides temperature information in the
    event of a power outage.
    Power outage:
    During a power outage, if the temperatures in the
    refrigerator and freezer compartments exceed normal operating
    temperatures, the highest temperature reached will be displayed.
    ■ Press the Temp Alarm touch pad until the indicator light is lit,
    to turn on this feature. Press and hold Temp Alarm for
    3 seconds until the indicator light goes off to turn off this
    feature.
    Temperature alarm:
    An alarm will sound repeatedly if the freezer
    or refrigerator compartment temperatures exceed normal
    operating temperatures for an hour or more.
    The temperature displays will alternately show the current
    temperatures and the highest temperatures the compartments
    reached.
    ■ Press the Temp Alarm touch pad once to stop the audible
    alarm and alternating temperature displays. The Temp Alarm
    light will continue to flash until the refrigerator returns to the
    set temperature.
    Door Alarm
    The Door Alarm feature sounds a chime every few seconds when
    the refrigerator door has been left open for 5 continuous minutes.
    The chime will sound until the door is closed or Door Alarm is
    turned off.
    ■ Press the Door Alarm touch pad to turn this feature on or off.
    The indicator light will be lit when the Door Alarm feature is
    on.
    Filter Reset
    See “Water Filtration System.”
    User Preferences
    The control center allows you to set user preferences, if desired.
    Temperature Display (F_C)
    This preference allows you to change the temperature display.
    F - Temperature in degrees Fahrenheit
    C - Temperature in degrees Celsius
    Alarm (AL)
    This preference allows you to turn off the sound of all alarms.
    ON - You will hear the alarm sound.
    OFF - You will not hear the alarm sound.
    Auto Light Level Selection (LL)
    This preference allows you to adjust the dispenser light level from
    dimmest to brightest (settings 1 through 9).
    NOTE:
    The Auto Light feature on the control center must be
    selected to activate this preference.
    Sabbath Mode (SAB)
    ON - All control center lights, interior lights and alarm tones will
    be disabled.
    OFF - All control center lights, interior lights and alarm tones will
    be enabled.
    NOTE:
    Press the door alarm touch pad for three seconds to
    restore all lights.
    To Access the User Preferences Menu:
    1.
    Press and hold the Door Alarm touch pad for three seconds.
    The preference name will appear in the Freezer display and
    the preference status (F or C) or (ON or OFF) will appear in the
    Refrigerator display.
    2.
    Use the Freezer (+) or (-) touch pads to scroll through the
    preference names. When the desired preference name is
    displayed, press the Refrigerator (+) or (-) touch pads to
    change the preference status.
    3.
    Set your preferences by pressing and holding the Door Alarm
    Crisper Humidity Control
    You can control the amount of humidity in the moisture-sealed
    crisper. Depending on your model, adjust the control to any
    setting between FRUIT and VEGETABLES or LOW and HIGH.
    FRUIT / LOW
    (open) for best storage of fruits and vegetables
    with skins.
    VEGETABLES / HIGH
    (closed) for best storage of fresh, leafy
  • Duane Wong
    The maytag manual I read is at the following location after entering your model #:
    http://shared.whirlpoolcorp.com/product_...
  • karichris_20 Jul 17, 2010
    No, this problem originates when the water dispenser is left on for 5 min. The control panel locks to prevent flooding. Nothing I can find tells one how to unlock it. Evidently I need to enter into a programing mode to enter a code.
  • 2,272 Answers
Press and hold the "Door Alarm" button on the control panel until the indicator light turns on (the control panel is located on the water and ice dispenser). Turn off the alarm by pressing and holding the "Door Alarm" button until the indicator light turns off.
CONTROL PANEL LOCK The control panel can be locked after selecting the temperature of the refrigerator and freezer compartments. To activate this function, simultaneously press buttons 13 and 15 for at least 3 seconds. An acoustic signal will sound indicating the activation of the function. With the “Control Panel Lock” function activated, the entire control panel will be locked except for button 11 (alarm reset). An acoustic signal will sound and the message “CL” will appear on the freezer temperature display whenever and for the entire time a key is pressed. To unlock the control panel, proceed as before, simultaneously pressing buttons 13 and 15 for at least 3 seconds. If this procedure is in-case not helping then please mention the exact brand and model number of the unit. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Jul 10, 2010
  • karichris_20 Jul 15, 2010
    The door alarm light is on continuously and the panel is locked. I know there is a procedure to enter into the programming mode but I do not know how. The refrigerator is a Maytag Mod# MFI2266AEU. Side by side with a drawer freezer.
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
Samsung refrigerator alarm beeping continuously
May 15, 2016 | Samsung Refrigerators
Model E402b. Why is the alarm going off?
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow Cause of Beeping Noise in Frigidaire Refrigerator eHow
Jun 02, 2015 | Fisher and Paykel Refrigerators
I have a frigidaire side by side model GLHS37EHSB7 refrigerator makes a continuing beeping sound what could be wrong?
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
May 11, 2015 | Frigidaire Refrigerators
Alarm keeps sounding every 2.5 minutes, it works fine on electric, gas and battery and is 12 months old.
May 03, 2015 | Refrigerators
Refridgerator beeps
Apr 19, 2015 | Refrigerators
Got fridge freezer but no instructions. Alarm keeps going off. Front panel contriols
Apr 10, 2015 | Refrigerators
How do you get the model 370lb to stopping beeping
Mar 30, 2015 | Refrigerators
Open door 18 beeps lights flash red green fridge not cooling
Mar 14, 2015 | Refrigerators
Why does my Hotpoint ff187e frost free fridge freezer lights flash and the alarm sound even after reseting them as per manual. rest them ok for a while but then restart what's the problem?
Jul 27, 2014 | Hotpoint Refrigerators
Refrigerators Logo
62 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
