Question about Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White
Model #ffu2o65fw3 , serial # 73051999 . does this model have a battery to activate the alarm? If so ,where is it located?
  • 1,531 Answers
No there are no batteries on these units
Posted on Jul 10, 2010
Why is the temperature alarm light on, on my freezer Model# FFU21M8CW?
Good Afternoon Friend,
I understand that the temperature alarm light is on for your Frigidaire freezer, model# FFU21M8CW. This feature is designed to provide a warning of a possible malfunction. If the temperature of the food rises to a level unsafe for long-term storage, the buzzer will sound. The red light, if equipped, will also glow. The Temp Alarm feature operates on household electricity. If power fails, the alarm will not function. An ON/OFF switch allows you to deactivate the Temp Alarm when not wanted. Your freezer is shipped with the Temp Alarm in the OFF position. After your freezer has run approximately 4 hours, the red light, if equipped, will go off. Then you may activate the Temp Alarm without the alarm sounding. Press the ON switch to activate the Temp Alarm. To deactivate, press the OFF switch. If the alarm sounds, be sure freezer is properly leveled, and the door closes freely, and seals properly. If you suspect a technical malfunction, call an authorized servicer immediately. Hope this is helpful.
-Best Regards-
WP
Jun 24, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezer light doesn't work and door ajar alarm going off
The door switch is faulty. It switches the light on. There is no battery.
Dec 27, 2012 | Kenmore Freezers
I have a fridgerdire freeze that has not beem used in a a while. We plugged it in today and I have a power light and a temperture alarm. When I turn the freezer on I hear a buzzer alarm going off and the...
Hi James.
Most Kenmore upright freezers use a backup battery located at the lower part of the appliance. When the battery is low the freezer will beep continuously. If the unit has been off for a long time, and if the unit uses a battery, then the battery may need replacement.
Here a picture of the battery in its housing, located in the lower front part of the freezer.
Feb 19, 2012 | Kenmore 20.3 cu. ft. / 575 liter Upright...
What is the on/off switch at the bottom for.
Sorry to read about your problem, I hope this helps you out.
High-Temp Alarm Switch (on some models)
An alarm will sound if the freezer temperature reaches unsafe levels. The alarm operates on household electricity. If the power fails, the alarm will not perform.
An ON/OFF switch allows the temperature alarm to be deactivated if desired. The freezer is shipped with the switch in the OFF position. After the freezer has run long enough to lower the temperature, you may set the switch to the ON position.
CAUTION: Adding more than 3 pounds (1.5 kg) of warm food per cubic foot of freezer capacity can trigger the alarm.
To activate the alarm, set the switch to the ON position.
To deactivate the alarm, set the switch to the OFF position.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 25, 2010 | GE 20.3 cu. ft. / 575 liter Upright...
The high temp light is on. What can I do to reset it? Everything seems frozen and fine in the frezzer
HIGH-TEMP ALARM SWITCH (SOME MODELS)
An audible
unsafe levels. The alarm operates on household electricity.If
the power
An ON/OFF switch
allows the high temperature alarm to be
deactivated if desired. NOTE: You must open the
freezer door to
view the alarm switch. The
the OFF position.
After the freezer has run longenough to
position.
to the ON position.
i got this from the freezer manual from Kenmore hope this was helpful
Mar 28, 2010 | Kenmore Freezer 13.7 cu. ft. Upright...
Yellow power light keeps blinking on upright freezer even after replacing 9V battery and temperature is good.Have waited about 16 hours for freezer to stabilize. Problem?
If its the power light, and not a temperature alarm light, it may only indicate that there was a power loss, perhaps you had a brown out or power surge. you say the temps are good, any chance you have ice cream or bread in freezer? if its above 10° F they will be first to get soft, rather than firm. If I had the model # as it is on the model number tag, the only tag usually on the inside or possible on the outside, of the unit, that will have the model and serial number both listed.
Mar 24, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
ALARM WENT OFF ON OUR KENMORE UPRIGHT FREEZER. HOW DO WE GET IT RESET. WE HAVE PUSHED THE BUTTONS BUT RED LIGHT IS STILL ON AND FREEZER NOT RUNNING. THE PROBLEM STARTED BECAUSE WE DID NOT GET THE DOOR SHUT...
The light and alarm will remain active until the temp in the freezer is "normal" or satisfied. You should be able to push & hold the button (if electronic) until it stops. If it is a manual switch, they are usually located at the bottom of the cabinet below the door.(some are located inside the unit on the wall as well) It may be a "rocker" switch or part of the actual indicator light. Good luck
Sep 26, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Its keeps peeping
Hello twins49
Welcome to Fixya,
You said, your Frigidaire freezer 17 cu. ft. , it keeps buzzing or peeping
The alarm may be malfunctioning or it may be warning you of low temperature.
You can go to any hard ware store and buy a refrigerator thermometer and ask them if it can go into a freezer too!It can, But ask anyway!
If it is cold enough then it is a faulty alarm going off.
Your freezer may be equipped with an alarm.
Here is some information that may help you find it and turn it off if you wish
Temp Alarm (audible only or audible with warning light)
This feature is designed to provide a warning of possible malfunction. If the
sound. The red light will also glow on models so equipped. The Temp Alarm feature
operates on household electricity. If power fails, the alarm will not perform. An ON/
OFF switch allows you to deactivate the Temp Alarm when not wanted. The freezer
is shipped with Temp Alarm in the OFF position. After freezer has run approximately
immediately.
Let me no what you find.
Huuum
Please remember to leave a rating before you leave
Aug 26, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Kenmore Freezer Alarm
You can take the batteries out that power the alarm system. They are located through a small access panel/door front bottom right of the unit. If you bought the unit at Sears, you should call 1-800-4MYHOME and ask a technician if a replacement manual is available, or if they can direct you to a website for it.
Jun 09, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White Logo
97 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
