My Simple Comfort 2000 worked normally for about 2 years until recently. It was already a part of the house when we purchased it. There are several issues: 1) The "set" Temperature mode remains on constantly. It (inconsistently) will switch to the room temperature or even allow anyone to adjust the temperature. If it remains in the "set" mode it consistently sits at 45. Obviously its not 45 degrees in the home but nevertheless thats what it does. 2)After I sit there and try adjusting the temperature several minutes (even sometimes leaving and coming back several hours later) it might eventually let me adjust to a temp (like 75 or 72 degrees) and the unit will kick on. When the unit kicks on it runs normal (but will move to the set temperature and then begin dropping back down to 45 again). Then it becomes very cold in the home and unless I turn the unit off it again will not let me adjust the temperature. The short of it the unit does not turn off/on like it should. 3) I have turned the
hotuna
  • 288 Answers
SOURCE: Temperature varies 13 degrees around setpoint on aux heat
I don't have the book for this particular unit but, check the sequencers that control the electric heat mode, as the regulator heat pump works good. The part may have a time or temperature delay that is too long for you. Also if it has a remote thermostat, check the heat anticipate setting. You will have to check the installation manuel, but its usually .6 to .8, but I don't think that is the problem.
Posted on Dec 04, 2007
kf4rwe
  • 25 Answers
SOURCE: Heat pump blows heat half the time and cold half the time
It sounds like it is just going into the defrost cycle. Go outside and see if it is iced up. If it is, it reverses itself to melt the ice. Heat strips should come on if unit has them
Posted on Dec 03, 2008
pierre1811
  • 144 Answers
SOURCE: electric furnace won't shut off
It sounds like a bad or badly miswired T-stat
Posted on Jan 20, 2009
tborn6
  • 700 Answers
SOURCE: Honeywell T87f 3855 Doesn't Activate Heater
thats becaue you need more than this zone working like you said about the master/slave this zone is a slave.
Posted on Jan 25, 2009
jumptrout51
  • 3361 Answers
SOURCE: Carrier Comfort 13 Puron model 24ACA3 / FV4NB006
Verify 24 volts at the low voltage transformer inside the air handler. If it is OK, jump out the red/green and yellow thermostat wires. If everything comes on, replace the thermostat.
Posted on Jun 08, 2009
Transmission only goes forward in 1 or 2 position.
Dear Don a,
I recently had a problem with my GMC doing the same thing, and it had the same transmission as yours.
The solutions for mine were the shift solenoids inside the transmission case.
Because I was driving a GMC van/motor home conversion, the local transmission shop could not fix it, so I had to do it myself.
I pulled the transmission pan, ( I had already purchased a transmission pan gasket and filter kit ) and found the two shift solenoids at the bottom edge of the transmission housing, and held on with 2 screws each.
I had to buy the solenoids at the local GMC dealer, they cost me $ 39 each.
I had the whole job done in 1 hour, and I am slow!
P.S. I found I had to tighten the transmission pan gasket several times because until I had the screws REALLY tight, it continued to seep oil.
God bless your efforts.
May 09, 2016 | 1996 Oldsmobile 88
Simple comfort thermostat
most thermostat are plus or mines 5 degree for turn on or off
Jan 29, 2018 | Cars & Trucks
Simple comfort 2200 thermostat not working properly
We have a Simple Comfort 2200 Electronic Thermostat and last night it quit blowing cool air and the # sign beside the air temp (the set to temp) starting blinking
Aug 11, 2012 | Heating & Cooling
AulineI have a Beko freezer,model ZN231.Had it for several years.Is this affected by the recent fire scare in the media?
It doesn't appear to match any of the listed model numbers. Please check out the attached article to reassure yourself:
POTENTIAL BEKO REFRIGERATOR FIRE RISK AND RECALL NOTICE
I would normally give a pointer to articles I have already posted this response on, but as this is such a potentially serious matter, I have posted my entire response here for you.
According to several sources I have checked, including most importantly, BEKO's own website, the MODEL numbers (not serial numbers) affected by the recall are as follows:
CDA543FX
CA5411FFS
CDA752FS
CDA645FW
CA5411FFW
CDA752FW
CDA647FS
CA5411FFX
CDA752FX
CDA647FW
CA7014FFX
CS460FF
CDA648FS
CA7015FFS
CS460FFS
CDA648FW
CA7015FFW
CS460FFSD
CDA653FS
CA7015FFX
CS461FFW
CDA653FW
CDA539FS
CS461FFS
CDA653FX
CDA539FW
CSA4706FFX
CDA659FS
CDA539FX
CSB4606FFS
CDA751FS
CDA543FS
CSB4606FFSD
CDA751FX
CDA543FW
CSB4606FFW
The fridges affected were manufactured between January 2000 and October 2006. After shipping and sitting around in shops, you can probably extend that margin to machines SOLD between 2000 and 2008. The first 2 digits of the serial numbers indicate the year of manufacture, so if your serial number doesn't start 00, 01, 02, 03, 04, 05 or 06 you don't even need to check.
If you go to the BEKO website, there is a link to check your serial number:
https://refsafety.beko.co.uk/
Jul 12, 2011 | Beko Refrigerators
Radiator cooling fan wont turn off unless i pull the fuse. It has already worn down the battery several times. I have already purchased the relay switch but I am having trouble locating the original part....
The relay should be inside the engine bay bolted to the front of the engine bay behind the bumper under the main air filter housing. It's held on by 2 small bolts. You should be able to remove the air filter housing (the entire housing, not just the cover) and it should be right there. Just follow the wires coming from the fans to find it.
May 10, 2011 | 2000 Chrysler Grand Voyager
I have a comfort zone heater 1500W Portable Quartz infrared heater CZ-1500WT For the first two years it worked perfectly - two weeks ago the electric plug end that goes into the receptacle gets...
Unless you want a new house, stop using that heater immediately. There are severe internal electric problems with your heater. Since it's already 3 years old, I'm not sure it's worth trying to repair. With what you described, I'm surprised it didn't trip one of you circuit breakers.
Be safe, Don't continue to try to use this heater.
Jan 18, 2011 | Comfort Zone Heating & Cooling
I'm looking to purchase a Rudd 2 stage model, 16 SEER, 5 ton along with a 100000 BTU 95% furnace. I have a two story home and will only be using the 1 AC. Will the Rudd cool both floors?
Assuming that there are ducts ran upstairs and downstairs, it all depends on the square footage of the living spaces, i.e. bedrooms, living room, dining room, etc. You need an average of 1 cfm per sq ft. For every 1 ton of air, you have an average of 400cfms. So your 5 ton unit will cool/heat 2000 sq ft. A 16 seer unit with a 95% furnace is a nice buy and you will notice the difference for sure. Hope this helps!
Aug 03, 2010 | Ruud Central System Air Conditioner
Pen drive
you can use the volumelabel of the pen drive its simple just right click and change volumelabel
May 21, 2008 | Pen Drive IVO MP3 Player
Heating & Cooling Logo
134 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
