Question about Goodman CLQ36AR49 Air Conditioner
NOT COOL ENOUTH
IT COMES ON BUT ONLY GIVES YOU FRESH AIR
  • Goodman Master
  • 43,501 Answers
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 12, 2010
FocusPro TH5000 will not cool
Make sure the thermostat is set to "cool" mode. Make sure the thermostat is wired correctly and has fresh batteries in it. Check both the thermostat end and the air handler end of the wires. If All this checks out, the problem is most likely in the air conditioner, not the thermostat.
Mar 29, 2014 | Honeywell TH5220D1003 FocusPRO 5000...
GSL22JFRE BS Freezer OK but not Fridge ??
Clean the condenser grille, rear and under unit
Apr 24, 2012 | GE GSL22JFR Side by Side Refrigerator
Which setting of the vent gives you the coldest air?? I see fesh air or vent?
Thank you for choosing FixYa. The vent setting is for getting air from the outside. The Fresh Air setting takes the air from inside and turns it into, you guessed it, fresh air! Hope this helps :)
P.S. Choose fresh air.
Jun 21, 2011 | Frigidaire FAC127S1A Air Conditioner
No cool air comes out
When you turn it on, do you hear the compressor come on? Make sure the controls aren't set to fresh air or vent.
Jun 01, 2010 | Sunbeam AW24CR3FHUE Air Conditioner
Get cooled fresh air from this ac unit
They are sized to always recirculate, some models do have a "vent" and when open, the vent brings in a percentage (by volume) of fresh air mixed with the air in the room.
May 26, 2010 | GE AJCQ12DC Air Conditioner
Will freezer side work if frig side is out
The freezer will appear to still work for awhile after the fresh food side fail to maintain a cool temp, you will need to remove the back in the freezer section and see if the fan motor is turning, if the fan motor is not turning you willl need to replace the fan motor and this will correct the problem and allow cool air to circulate to the fresh food section and cool the fresh food side of the refrigerator
Apr 17, 2010 | Refrigerators
Freezer temperature working fine fresh food
I need you to confirm that your model number is ZICS360NR and I will help you, Sea Breeze
Nov 13, 2009 | GE Monogram ZICS360NR Bottom Freezer...
SONY VGNFJ270 LAPTOP BECOMES HOT AND GIVES LOT OF NOISE
If the fan is noisy and the laptop is running hot, then most likely the fan is faulty and spinning slowly. Therefore the fan is not providing sufficent air flow to cool the laptop's CPU. The fan needs to be replaced and possibly the heatsink assembly needs cleaned to remove dust buildup.
Jun 24, 2009 | Sony Computers & Internet
Re: air cond. should exhaust lever be open or closed to cool off?
Im not sure what type of unit you are speaking about but in general a window airconditioner unit will have an exhaust button. This button generally opens a small door that allows a small ammount of fresh air to mix with the conditioned air from the room. When it is closed all of the air is recycled from the room. To cool a room fastest, close the outside air inlet.
Jun 21, 2009 | Heating & Cooling
Refrigerator wont cool
all the cooling comes from the freezer. a fan pushes 20% of the air over into the fresh side.look for something blocking the airflow into fresh side. also check for defrost malfunction(is there frost buildup in the freezer on back wall towards the bottom.
Jun 11, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Goodman CLQ36AR49 Air Conditioner Logo
49 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
