Question about Sansui RZ-5300AV Receiver
I HAVE A PIONEER RECEIVER SX-1280. WHEN I HOOK UP A SET OF SPEAKERS TO EACH SET OF SPEAKER TERMINERALS A B C ,IF I TURN TWO SETS OF SPEAKERS I HAVE AUDIO. IF I TURN ON ALL THREE SETS I LOSE AUDIO
  • Bob Jul 10, 2010
    This is a vintage 1978 Pioneer receiver Model SX-1280. It has 3 separate speaker outputs labeled A, B, & C. If I connect speakers to each output, then select any 1 output I receive audio, if I select any combo of 2 outputs I receive audio, BUT if I select all 3 outputs I loose audio. Any suggestions?
  • Bob Jul 13, 2010
    Did't fix the problem, but need to accept so the next problem can be reviewed.
    President:
  • 1,851 Answers
As you can see at the back side near the speakers connectors, the total combination of the speakers resistance must be not bellow 4ohms per channel. Since the speakers are connected in parallel and usually are 8ohm resistance, with 2 speakers you have in total 1/8 + 1/8 = 2/8 = 1/4 that is equal with 4ohms. In the case with 3 speakers you get 1/8 + 1/8 + 1/8 = 3/8 that is 2.666ohms. This total resistance is out of specifications for your amplifier (and most of the amps). The good thing is that your amp is just stoping to play; in many other cases I can tell you that the amp will get trouble.
If you'd like to clarify for me the set up for your speakers and the area you'd like to have audio, I'll try to find a possible solution suitable for your needs.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Jul 10, 2010
  • 6,826 Answers
The Pioneer receiver has 3 speaker terminal sets, apparently. One for right, one for left, and one for center channels.
Sounds like a good idea. But, when you switch it to turn all three sets you lose audio completely.
Sounds to me like the amplifier for that mode (3 speakers) is underpowered for your speakers.
However, if you put low wattage speakers onto each terminal a, b, or c and it still doesn't work, then the circuitry inside might be burnt out.
There is no reason that I can see based on your description that it shouldn't play out of all three speakers if you have the recommended speakers for that receiver hooked up to it.
Good luck on fixing this.
  • Duane Wong
    Duane Wong Jul 13, 2010
    I wish you the best in solving the problem on this vintage receiver.
Pioneer elite sx-a6 keeps going to standby
I had a receiver that would shut off when I had the volume too loud. It was caused because the speakers were using too much juice. Does it work with less speakers or at low low volumes? Then this may be the case.
I solved it by getting a different receiver.
if it has nothing to do with volume then check your manual and settings for a auto standby feature that may be just putting the receiver to standby after a set time.
Apr 14, 2014 | Pioneer ELite SX-A9 HI-FI Audio Receiver...
1976 pioneer sx 1250 receiver has no sound from receiver to speakers
for
1976 pioneer sx 1250 receiverhas no sound from receiver to speakers
check the integrity of speaker systems,
check the receiver internal components, pay close attention to the
capacitors, possibly have dried up or swollen (age)
Check for continuity to the speaker outputs.
These may take some time, but I hope you will make it.
Sep 09, 2012 | Audio Players & Recorders
I would like to set up my old Pioneer PL-514 turntable and my Pioneer SX-550 sterio reciever to listen to some old LPs. I seem to have lost the instructions and connection diagrams. Could you please...
http://www.vinylengine.com/library/pioneer/pl-514.shtml
http://www.hifiengine.com/manuals/pioneer/sx-550.shtml
The upper link is for the turntable, the lower is for the receiver. they want you to create an account tu dowlnload so just create an account with them. In my expierience turntables had hook upeads out the back(wires connected) that would hook to phono in on receiver and speakers would hook to receiver via speaker wires(may not be included) by pos and neg. The speaker wire usually either has a rib or a line or writing on on leg so you can identify which wire you would want to be pos or neg.
Mar 10, 2011 | Pioneer Audio Players & Recorders
Can you hook it up to the tv to get sroundsound
You can grab a copy of the manual here:
http://www.pioneernz.co.nz/Site/Pronto/Files/user_manuals/SX255R%20USER%20MANUAL.PDF
The short answer to your question is: No.
This stereo amplifier provides for up to two sets of stereo speakers. System A and System B. There is no Surround capability in this stereo, only straight Left and Right on system A, system B or both.
Using this stereo and speaker system will probably sound better than the speakers inside your TV however. Simply connect the "Audio Left" and "Audio Right" output jacks with RCA patch cables from your TV, Cable Box or Satellite TV box to an unused input on the rear of the SX-255R (CD, LD/DVD, Phono, etc.), then select this same input when you want to listen to TV audio.
I hope this was very helpful - and good luck!
Jun 24, 2010 | Pioneer SX-255R Receiver
I have a Pioneer Audio Multi Channel Receiver model SX-316-S and I can't seem to figure out how to hook up my TV and DVD to the receiver so that all sound comes through the receiver
DVD audio straight in from its highest quality audio output. Use the stereo audio output to run straight to the TV for casual watching through TV speakers without the Pioneer involved.
A TV is just a glorified night-light, not a sound source - get its related audio from the Cable Box, ditto the highest quality
Mar 04, 2010 | Pioneer SX-315
No surround sound like the movies
HOOK IT UP FROM A DVD PLAYER OR BLU RAY,,, WITH EITHER COMPONENT OR A OPTICAL CABLE ,,MAKE SURE YOU HAVE ALL OF IT TURNED ON ON THE RECIER SETUP
May 14, 2009 | Pioneer SX-315
Speakers not playing correct on a Pioneer SX-550
It could be the speaker output or the amp input. If you have a headphone socket on the amp try headphones and hear if it's the same problem.
If it's the amp's power output then this can be repaired. It's a case of unsoldering the blown transistor or integrated amp chip and soldering in a new one. It's not hard but you need to find someone competent.
Apr 28, 2017 | Pioneer Audio Players & Recorders
Pioneer vsx-d902s
Hi Tracey
Most of these older machine had speaker switches on the front panel. Can you check what they are set to. It may be that both switches(A and B) are set in, or set out. this could present the problem you are having with no sound. turn on just one switch that corresponds the connections you have made on the rear (use speaker A) Another thing to check, is when you first turn on the amp, do you hear a relay click shortly after you switch on. If you don't hear this delayed click, then there may well be a problem in the output stages of the amp. If this is the case, then you will need to take it to a tech to have a look and see what has failed in the amp. Hope this info helps, if you have any questions, I am happy to try and help you further.
regards
robotek
Nov 07, 2008 | Pioneer SX-315
Pioneer SX1280 repair
I have taken my 1280 to Austin Stereo, they are honest , upfront, and guarantee their work. So impressed that I took a 1080 that two previous techs had butchered and they fixed it to like new specs.512-451-0408 is their #. They go out of their way to help those of us that are not well versed in techspeak. Both units sound superb with the big 15 inch Cerwin Vega speakers!!!
Feb 02, 2008 | Sansui RZ-5300AV Receiver
Sansui RZ-5300AV Receiver Logo
113 people viewed this question
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
ashburton
Josh Whitehead
Josh Whitehead
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
