I have two d-link usbs and i am trying to make a wireless network plz help me step by step
  • 6 Answers
Do you mean you have two d-link Wifi USB adapter? and Do you want to make a network between two PCs? If so , you just need to install the drivers on both PCs and then plug in each PC with your USB Wifi adapter.Then on one PC(Master) go to Control Panel,double click "Wireless Network Setup Wizard",then NEXT,you will require to enter an Network name(SSID), in here I recommand you choose "Manually assign a network key", because the automatically on from system alway very long and must use some file to transfer the config.then set the key ,then next, you can choose "Set up a network manually". After that, go to another PC(slave), double click your wireless connection icon on the task bar at the right side near the system time. the Network name(SSID) which you just set up on that PC will be in the list, if not just click "search" on the left side. double click the Network name(SSID), you will require to type your network key. then ok. You can begin to enjoy your wireless network in your home now! :-)
Posted on Apr 19, 2008
Hello, I am trying to install my d-link 125 usb adapter. I had to download the windows 7 driver from the d-link website, and now I am trying to install it to my computer. When I try to run the driver...
Use the following steps to let Windows do the installation for you.
Step 1: Use an Ethernet cable and plug your computer directly to your Internet gateway. Make sure Internet is accessible.
Step 2: Place your new adapter in the proper slot or port.
Step 3: With your computer running, a bubble message will appear stating that this device was not installed successfully. Left click on the message.
But if the message no longer appears, skip to Device Manager Installation.
Step 4: On driver installation failure, you can change the setting to use Windows Update by clicking Change setting...
Step 5: Chose to allow Windows to update your driver when it is not found on you computer.
Step 6: Once the driver installs successfully, close the window.
Step 7: Click/Right Click on the Network Icon located on the system tray to View the Available Wireless Networks. Find your personal Network and double click to connect. It should request for a wireless key, which by now should have been set up.
Oct 26, 2011 | D-Link DWA-125 Wireless 150 USB Adapter...
Trying to load software, i get to the second stage it tells me the ethernet cable is not connected properly. i cant get past this.
It seems that you are using usb connection to install your router. This error happens, to some, due to incompatibility issues. I suggest for you to set your wireless network by way of general steps and common cable connections. Let's put it, the old ways. This are the general steps for all types of routers.
Click the link below for proper cable connections in setting up your wireless network.
This link also provides somewhat a checklist on what you need for wireless connectivity
Then, configure your wireless connection. The following links provides the step by step instructions for each version of Windows:
Windows XP.
Windows Vista.
Windows 7.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
"Understanding explains better..."
Feb 01, 2011 | D-Link DIR-615 Wireless Router
I bought AE1000 wireless N USB adapter, and i cant get it to install, says "wireless adapter setup requires that wireless connections are managed by Microsoft windows, says to try the following,...
When you insert the setup disk on your computer, you can exit from the setup and then connect the adapter to the computer and a new window will popup "Found New Hardware Wizzard" and in that select the option "Install the drivers Automatically" and click on next, so it will automatically search for the drivers and install it on your computer... Once the drivers are installed on your computer then you can try to connect to your wireless network.
The Linksys AE1000 Wireless USB Adapter helps you connect your computer to a wireless network for quick Internet access. Installing the Linksys AE1000 is fairly easy. Just follow the steps below in setting up the Linksys AE1000 on your computer or laptop.
Minimum system requirements
- A computer with 1 GHz or faster processor.
- 512MB or more RAM.
- An available USB port.
NOTE: The Linksys AE1000 is supported for Windows 7, Vista SP1 and XP SP3 but NOT for Mac.
Step 1:
Insert the Setup CD into your CD-ROM drive.
Step 2:
Click Set up your Linksys Adapter. Proceed to Step 4.
If you do not see this, click Start on your computer and click Computer. Double-click on your CD-ROM drive. Continue to Step 3.
NOTE: For Windows XP, the file may be known as Setup.exe.
Step 3:
Read the License Agreement and click Next.
Step 4:
Insert the Wireless USB Adapter into a USB port on your computer or laptop.
Alternatively, you can also use the USB Extension Base to connect the Wireless USB Adapter. Plug the Wireless USB Adapter into the USB Extension Base and connect the Base to a USB port on your computer or laptop.
Step 5:
If you have an Easy Setup key, select Yes, I have an Easy Setup Key and click Next. Proceed to Step 8.
Otherwise, select No, I don't have an Easy Setup Key and click Next. Proceed to Step 6.
NOTE: For more information on Easy Setup Key, click here.
Step 6:
Select your wireless network and click Next.
Step 7:
If prompted, enter the wireless password for your network. Proceed to Step 10.
Step 8:
Follow the on-screen instructions. Click Next once you have completed the on-screen instructions.
Step 9:
The installation is complete when you see the screen below. Click OK.
Step 10:
You are directed to the Cisco Connect screen. Click Close to exit.
Nov 04, 2010 | Linksys AE1000 IEEE 80211abg IEEE80211n...
I was once connected fine to my router via my D-Link DWA-110 but now I cannot connect at all. Ive done everything I could think of but still dont' know whether its my router or the USB wireless adapter...
are you getting any error message when you try to connect to the wireless network ?
Check the wireless settings of the router.
If you have any other wireless computer working then the router must be working.
If you do not have any other wireless computer or device in the network then you can try to change the wireless settings of the router.
Click Here for step by step solutions
Nov 06, 2009 | Computers & Internet
Experiencing error when connecting to wireless router
I've had this happen before when using a USB wireless device. Is the wireless on your system built in? Or do you connect it to a USB port? The external devices sometimes try to use their own software to configure wireless so you can shut it off and just use the Windows wireless tool. I assume you setup the wireless with a security key and entered that key into your system to try and connect? Let me know if any of that helps and rate the solution if it does!
Mar 31, 2009 | D-Link Xtreme N DIR-655 Wireless Router
How do you install wireless usb adaptor
A wireless USB adapter is a simple device that connects to an open USB port on your computer or laptop, allowing you to connect wirelessly to a network that is within range. They come with different connection speeds, ranges and security protection allowing you to connect to the Internet and use email servers, without complicated setups. Installing USB adapters to a computer is a simple task that anyone can perform. With just a few steps, you can access wireless networkmag-glass_10x10.gif where there is one.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Moderately Easy Instructions
  1. Step 1 Research around before purchasing a wireless USB adapter. There are many different networking companies such as Belkin, Netgear and Linksys (see links in Resources). Compare prices and features such as speed in megabytes per second (mbps). Look for wireless USB adapters with a compliance of IEEE 802.11b or IEEE 802.11g. These options give you increased security on your network.
  2. Step 2 Plug your purchased USB into a USB port on your computer. Depending on the chosen model, you may have an installation CD. Place your installation CD into the CD-ROM on your computer, and follow the setup instructions to install the wireless USB drivers. Some adapters will install automatically.
  3. Step 3 Locate the wireless icon on the lower right of your computer screen. If there is an "X" marked on it, use the manual that comes with your purchased wireless USB adapter to configure it properly. The wireless icon usually lights up when a wireless connection point is detected.
Dec 11, 2008 | Computers & Internet
D link router
This could be due to many factors. A few to look at is:
Move the router closer to the PC
Update the drivers on the PC, making sure the wireless network card is not using windows drivers alone (re-installing the drivers from the CD or website will fix this.)
If the wirless network on the PC is a USB pen type, then change it to a different port. Or, it may need USB 2. If your PC does not have this, you can purchase a USB 2 PCI card from ebay for under £10.
Try unplugging any DECT (digital cordless) phones in the house, as they may be interfering.
Feb 03, 2008 | D-Link DI 514 Wireless Router (DI-514)
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
