Question about Fisher and Paykel GWL11 Top Load Washer
Howling noise on start-up - Fisher and Paykel GWL11 Top Load Washer
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Does the machine make the noise when it is filling?If so then try a cold fill and see if the noise happens and if there is no noise then try a hot fill to see if there is a noise.Please reply with additional information on whether the noise happens on the filling cycle or at another part of the cycle.
Posted on Jul 10, 2010
Uncontrolled downshift of 1994 c220
no 4-3 or 3-2 downshift
uncontrolled downshifts outside range of kickdown switch
poor acceleration from stopped position
parking pawl will not engage
selector lever does not engage in r or p
engine will not start in p or n position
smoke in exhaust (fluid loss)
fluid loss between torque converter & primary pump
howling noise when changing gears (under full load)
howling noise which increases as engine rpm increases
1st gear & reverse too loud
3rd gear too loud
rattling noise at 1500 rpm in all positions except r
light grinding noise in p & n positions
rolling noises when driving in reverse
vacuum control circuit
Vacuum Control Valve (E300D & S350D)
Vacuum Amplifier (E300D & S350D)
Dec 02, 2012 | 1994 Mercedes-Benz C-Class
Howling noise as i'm driving down the road,does'nt seem like tires,farely new,any ideas
sorry did you get your tires rotated recentley if so that could be the tires ive had that happen to me before by not rotateing my tires for a while if thats the cause noise should go away if that not it its hard to tell you what a howling noise could be from is it only when your driveing and vehicle moveing
Nov 29, 2010 | 2006 Chevrolet Silverado 1500 2WD
Have a 2004 impala with howling noise from the front?
Here are a couple of things to check for. When driving turn car left and the right to see if noise gets louder then quieter. If so you will need a bearing hub. Also check power steering fluid in pump, if low you will get a howling noise. Looking for a noise is difficult task from a computer. Hope this gives you a starting point.
Mar 28, 2010 | 2004 Chevrolet Impala
Why does my car make howling noise that sounds like its coming from either front right or center of the car, it doesnt pull while going straight, the engine is newer with 40,000 miles on it, the wheel...
You probably have a bad hub bearing.If you can change the noise by slightly turning the vehicle one way or the other it is a hub bearing.If you turn left and the noise is still there then it is the right front bearing.If you turn right and the noise is still there it is the left side.If it makes the noise both ways it could be both front hubs.Hope this helps.Good luck.
Mar 23, 2010 | 2000 Chevrolet Malibu
GE GSL25JFR Freezer fan noise.
Replace the fan motor is my guess to cure the noise.
Mar 01, 2017 | GE Profile¿ 42" Built-In Side-by-Side...
Kenmore 90 series loud whirring/howling noise during spin cycle
Sounds like you have a broken motor coupler. They are inexpensive. Can be a little tough to replace but I can walk you through it. You can purchase a coupler here.
http://www.shop.washermd.com/product.sc?categoryId=1&productId=1
Dave
Dec 18, 2008 | GE WBSR3140DW Top Load Washer
Howling noise in the evaporator fan motor
Bad computer board in back of fridge, unable to control motor speed causing motor to hunt
Nov 02, 2008 | GE GSS25JEMWW Side by Side
Fridge makes howling noise
Hi there!
Check at the back for any objects or packets that are in contact with a fan. This often causes unusual noises.
See if you can identify the source of the noise, ao I can help further.
Thanks.
Jun 21, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
HOWLING NOISES
Did you check your Transmission fluid and your differential fluids make sure there up and I don't know if you checked your rear wheel bearings or not, You can usually tell a wheel bearing when you are driving the car at highway speeds and you go around a corner and it get quite a bit louder Depending on what way you are turning if your turning right and it gets louder it will usually be the right side front or rear. the left usually the left front or back. some cases I have even heard Axles making a Howling Noise. Please let me know what you come up with. And Thanks in advance If I helped you out any. Bear001
Jun 17, 2008 | 2000 Honda CR-V
"howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Jul 25, 2006 | Maytag SAV5701A Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
535 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
