Question about Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Where is the main connector for the LCD panel
Sony Bravia 46 LCD TV - Where is the main connector for the LCD panel located? It seems to be loose on my unit, causing picture to be unstable.
  • 11,361 Answers
Most T-CON board is at the middle top center of the screen undet a metal shileld with very small wires and connectors attached to it. Most T-CON failed after warm up due to the heat from the panel and from the power supply, since heat rises, it gets a lot of exposure to the heat.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Send me pictures of the back of the TV if you cannot tell where it is.
budmrtn@aol.com
Posted on Jul 10, 2010
Left side is dark and right side is good
The LCD sets use backlights and also a pair (some models combine both into one unit) of inverters- one drives left side and the other right side.
You could have a bad inverter (some versions call it T-con) or even a bad display panel(main screen unit).
In most cases this is not a do it yourself repair.
May 17, 2012 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Sony Bravia 46'' picture has a slight green tint and adjusting the Hue does nothing.
hello!
that could be the t-con to main board cable's problem. first, try to tighten grounding screws.those, which connecting grounding latches of the cable.
You need to open your set. This cable is a thick shielded one with two 30 or so pins plugs. They are NOT interchangeable. In case you try to swap cable's ends. Try to move latches by hand without unplugging connectors, while TV is running. Very gently! If those moving a bit, you may see "greenge" vanishing. Tighten those screws with "phillipls" screwdriver by hand. if there is no difference, you may need to replace that cable. I'm talking about "greenish" ghosts on the picture, intermittent. If I'm wrong, it might be the main board's issue, but always start with small. Main boards are not interchangeable, factory replacement only! Cables-are.
Good luck,
Alex.
Nov 26, 2011 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Have a 2 yr old 46" Sony LCD. No picture at start up.
It may just need time to warm up. Try starting it up and waiting around for the picture to show.
Jun 04, 2010 | Sony BRAVIA KDL-46WL140 46 in. LCD TV
Sony bravia kdl 46s4100 no picture
it sounds like your back light might be going out. You might be able to fix this by installing a new backlight inverter board.
Jan 24, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony BRAVIA KDL-46XBR 46 in. HDTV LCD Television. I have a problem when the unit is switched on. The screen has 2/3 lines running across it. The picture stays like it for about 10 mins then goes back to...
I hope this helps
It seems Sony is extending the warranty on your TV
http://esupport.sony.com/US/perl/news-item.pl?news_id=378&template_id=1
IF YOU FOUND MY SOLUTION HELPFUL PLEASE VOTE 4 THUMBS UP.
(any less hurts our averages)
Thank and Good Luck!
Jan 19, 2010 | Sony BRAVIA KDL-46XBR2 46 in. LCD HDTV
Sony bravia 46 lcd The picture dims and
set has a light sensor. go in menu and turn light sensor off
Jul 01, 2009 | Sony Televison & Video
Sony Bravia 46S2010 no picture only glows but, only sound on
sound like you had problem with the lcd display panel. The Tcon had problem that attack to the panel.
Mar 07, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Picture freezes on Sony Bravia 46 in
this can be a weak signal check the connections on cables. also in hot weather you can get a build up of static electricity and it will need to be discharged, turn off tv at mains and cross the connector and the cables if you have a buster or other box connected to them turn off and do the same to them. use something metal but make sure there is no power to them.
Jun 21, 2017 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony BRAVIA  KDL-46S2000 46 in. LCD HDTV Logo
200 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
