Question about Garden
My Karcher K3.96M power washer is leaking and does not create any power for the water. I think the pump has developed problems. The unit is 5 years old. Is it cost justified to fix it or better to go and get a new one?
SOURCE: Karcher Power Washer Problem
I had the same problem with my Karcher. The recall was lifted Aug. 0f 2007. Tried numerous people at Karcher....head of Customer Service, vice president, etc. No one returns telephone calls not even cutomer service....poor, very poor customer service. Thinking about calling Germany.
Posted on Jun 14, 2008
barkencoa
  • 3463 Answers
SOURCE: Washer leaking when filling up tub
Unlikely to be pump, sounds more like hose leaking, or drum seal.
Depending upon severity of leak, place a sheet of newspaper under front of m/c, pushing it as far back as you can. switch m/c on for a few secs, then switch off, remove paper and you should be able to judge where leak is.
Tilt m/c back and have a look underneath.
At 12 years old, if it looks major, I think I would replace m/c.
Plz rate my solution.
Thanks.
Posted on Dec 31, 2008
delgriffith
  • 97 Answers
SOURCE: karcher 3300 G water leak out rear of unit from white plasticplug
if its just a plug, remove it with an allen key and wrap a couple layers of teflon tape around it. That should stop, or at least slow down any leaks that are coming out of the threads.
Posted on Jun 19, 2009
  • 497 Answers
SOURCE: durabuilt pressure washer 1600psi. Water leaking
Sounds like a faulty seal around the gun. Repair might be few bucks if you take it in. But the price of the part is probably under a buck. Depends if you want to rip apart it yourself.
Posted on Aug 12, 2009
  • 242 Answers
SOURCE: pressure washer is pulsating when powered on
it just the presure building back up ,it will last years doing this,i would not worrie as replacing the presure pump will only be a temp fix and it will do it again ,most washes do this after a year or lots of use.
Posted on Dec 31, 2009
Water is leaking from the bottom of washer mower is running and some water is coming out
ive seen this before, lots of people dont clean out there power washers when not in use, hard water build up is a big problem in these units witch cause the pump not to surge correctly, you should get it serviced, thankx
Apr 18, 2011 | Karcher K2.26 Electric Power Washer
My three year old Karcher power washer has suddenly started behaving as if it has lost its power. There is also an intermittent motor noise when I release the trigger. When I press the trigger again the...
This sounds like it had water left in it and it froze over the winter. The motot turning on and off signals a water leak on the output side of the pump. You may have a cracked pump housing. Locate the pump and make sure nothing is leaking in that area when under pressure. looh for fine hairline cracks.
Apr 01, 2011 | Karcher Garden
Pump leaking from base
I have the same Problem, the leak is from the seam of the Manifold housing. There is a small crack in the seam. A manufacturing defect.. A New Manifold Complete Replacement is about $61.03, about the half the price what I paid for this pressure washer at Walmart... :( If under 1 year old, and you can find a receipt to prove it,Karcher will replace the whole Pressure washer under warranty.
Jul 06, 2010 | Karcher K2.26 Electric Power Washer
Karcher K2.26M water leak
I have the same Problem, the leak is from the seam of the Manifold housing. There is a small crack in the seam. A manufacturing defect.. A New Manifold Complete Replacement K2.26* Part # 97501760 is $61.03, about the half the price what I paid for this pressure washer at Walmart... :( If under 1 year old, and you can find a receipt,Karcher will replace the whole Pressure washer under warranty.
Jul 03, 2010 | Karcher K2.26 Electric Power Washer
Hi My karcher k3.65 jubilee is leaking water when the pump is switched off from underneath
Hi This could be just the water inlet channel broken or split. You will need to remove the yellow cover via the screws at the back of the unit and then connect the water hose to see where the leak is coming from. If the water comes from underneath the pump then you will need a replacement pump seal kit of which you can purchase on the Internet.
Jun 11, 2010 | Karcher 1750 psi Electric Pressure Washer
Water is leaking from under the chrome piece inside my Karcher 3.68m pressure washer. Hose intake and outlet look good. Any sugeestions.
Plastic Pump Manifold is cracked.
Can be replace at a local Karcher Service Center, or if you are mechanically handy. Replacement Manifold Complete, is available from www.karcher.com.
If it is under 1 year old, and under warranty Karcher will replace if you have a Receipt proof of purchase.
Jun 08, 2010 | Karcher K3.68MR Factory Refurbished 1,800...
Karcher is spraying water from inside the unit, it actually a k2.97, any ideas please
Hi I have water spraying from air vent/intake on side of my k370 can you help ?
Mar 01, 2010 | Karcher K2.26 Electric Power Washer
New nozzle, plenty of water, but no pressure.
It is warrantied for 1 or 2 years. Low pressure could be due to the un-loader valve needing grease. If it is leaking it will not work properly. If it is stored somewhere cold during winter months the small parts inside will crack.
Sep 18, 2009 | Karcher 2500 PSI Pressure Washer
Karcher k7.80 pressure washr
I have a Karcher K 3.86 M electric PW with a similar problem: water leaks from the pump near the outlet and the pressure surges on and off continuously at intervals of 1-2 seconds. The leak appears to be coming from a very thin crack in the plastic pump head in what I think is the "unloader" valve portion. I read elsewhere that if you leave water in these PW's and it freezes it will crack, causing leaks. I don't know how you can empty all the water out so I think we must store these PW's in areas that won't freeze in winter.
Jul 29, 2007 | Karcher 2500 PSI Pressure Washer
Garden Logo
452 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
