Question about HP LaserJet 4ML Printer
No printer driver for HP LaserJet 4ML on Mac running Snow Leopard
I have a HP LaserJet 4ML printer which works fine. When I updated my Mac to Snow Leopard, the printer will no longer work since HP does not provided a printer driver. Any solution other than replace a perfectly good printer?
  • 223 Answers
The drivers should be packaged into snow leopard. This printer is listed as a supported printer for Snow Leopard.
this link will walk you through the process
Hp.com
Al
Eliteprintersolutions@gmail.com
Posted on Jul 14, 2010
Hp color laserjet 2550l need driver for my mac
Sir/Madam
The latest HP printer driver for devices listed below are built into Mac OS X 10.6. You do not need to download or reinstall any HP software for full printing functionality.
HP LaserJet print drivers are included in Apple's Mac OS X 10.6 Snow Leopard DVD and also available via Apple Software Updates.
Please Visit official HP Printer website Below Link URL:
http://h20566.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay/?spf_p.tpst=kbDocDisplay&spf_p.prp_kbDocDisplay=wsrp-navigationalState%3DdocId%253Demr_na-c01844302-4%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken#N1000E
Snow Leopard - HP LaserJet printer setup instructions
  1. Upgrade install from Mac OS X v10.4, 10.5:
If updating a Mac using the Snow Leopard DVD, the install process should automatically detect your previous HP printer queue, delete, and then create a new HP printer queue using the latest HP printer drivers included in Snow Leopard.
USB printers:
  1. Make sure printer is turnedOnand connected.
  2. Open a document to print, and then choose File , Print .
  3. Open the Printer pop-up and choose your printer.
  4. If you don't see your printer, choose Add Printer , and then selectMore Printersbutton.
  5. In the Name column, select the printer, then clickAdd.
Network printers:
You can connect to HP printers on your local network that use Bonjour, IP, and Open Directory, as well as shared printers connected to an Apple Airport base station.
NOTE:Apple does NOT support AppleTalk in new Mac OS X 10.6.
  1. Choose File , Print .
  2. Open the Printer pop-up menu and choose your printer. It may be in the Nearby Printers submenu.
  3. If your printer does not appear, choose Add Printer from the Printer pop-up menu.
  4. A dialog appears listing any Bonjour, IP, shared, and Open Directory printers on your local network. It may take a minute or two for your printer to appear.
NOTE:On larger networks, outside the Bonjour link-local network, your printer may not show up in the list. You can connect to the printer using IP. An IP printer is a network printer that uses TCP/IP protocol (such as JetDirect, LPD/LPR, IPP) to communicate with your printer. You need to know the IP address or DNS name.
  1. Click IP in the toolbar.
  2. Select HP Jetdirect - Socket in the Protocol pull down menu.
  3. Enter the printer's information available from printers front panel or printers network configuration page.
  4. The system should automatically bind to the HP print driver in thePrint Usingpull down menu.
  5. ClickAddto create the HP printer queue for your HP LaserJet.
Your computer can usually detect whether a printer has special accessories installed, such as additional paper trays, duplex unit, or extra memory. If it can't, a dialog appears that lets you specify them. Make sure the settings in that dialog accurately reflect your printer's installed options to enable full functionality.
  1. Clean install of Snow Leopard or setting up a new Macintosh with Snow Leopard already installed:
If configuring a new Mac running Snow Leopard or if performing a new or clean install of Snow Leopard:
For USB connected printers, the install process should automatically create a new HP LaserJet printer queue using the latest HP printer drivers included in Snow Leopard.
For network connected printers, follow steps below.
USB printers:
  1. Make sure that printer is turnedOnand connected.
Network printers:
Or
In Case You Have Still Problem Then Please Foll Us On:
HP Printer Support
Feb 12, 2014 | HP LaserJet Office Equipment & Supplies
My HP laserjet 1018 does not work wotk my Mac OS x 10.6.7' cant find any drivers
Hi, use the driver "HP LaserJet 1022, 1.3.0.261" and it will work with Snow Leopard 10.6. Don't use the Gutenprint version of same driver---dosen't work!
Apr 12, 2011 | HP LaserJet 1018 Printer
My new operating system doesn't recognize my scanner any longer but does do fine with the printer which are both the same machine. How do I fix that? I moved from Mac OX leopard to Mac OX snow leopard....
Shortly after the world started upgrading to Snow Leopard, reports began emerging that many Hewlett-Packard printers were incompatible with the upgrade. So, you can wait till you get the updated driver which is compatible with Mac Snow leopard.
Good Luck!
Aug 23, 2010 | HP Photosmart C7280 Laser Printer
Need OSX Snow Leopard Driver for Laserjet 1018. Have MacBook Pro 13".
This is the best solution for that problem and works perfectly...
http://blog.ragnarson.com/2010/01/mac-and-hp-laserjet-1018.html
Feb 09, 2010 | Apple MacBook Pro MB991LL/A 13.3-Inch...
Five computers networked with Linksys WRT320N router. Operating systems: Win 7.0 on 3 computers (two hardwired)(one laptop - wireless), Snow Leopard 10.8 on 1 (wireless), and XP on one (wireless). Also...
Sometimes this problem occures when you install a later model wireless router.
Try installing the latest Wireless card driver on the XP computer and the LAN card drivers on the other computers except the MAC.
Dec 31, 2009 | HP LaserJet P2015n Printer
I work with Mac OS (Snow Leopard) and my Mac don't recognize the Agfa Snapscan e25. What should I do? Regards
Snow Leopard has a bunch of drivers built in to control various printers.  If it doesn't recognize the printer, then you will have to go on Agfa's web site to see if they have a printer driver compatible with Snow Leopard.  Keep in mind that Snow Leopard is a new OS and that printer manufacturers will take some time to update their programs and drivers to run on it.  If you don't find a driver then, you got to use a different printer or downgrade your OS to one that will run the printer.
Nov 06, 2009 | Agfa SnapScan E25 Flatbed Scanner
Need a driver for OS X Snow Leopard
sorry mate they dont do a driver for osx
Mac OS All the HP LaserJet printers covered by this document, except for the HP LaserJet 1018 and 1020 Series and the HP LaserJet CP1210 Series , are compatible with the latest versions of Mac OS X (Mac OS X 10.4 and Mac OS X 10.5).
Oct 26, 2009 | HP LaserJet 1018 Printer
Need MAC Snow Leopard printer drivers for;
I had installed the Mac X snow leopard, but every time i tried to print with mi HP laserjet P1005 i have this error
P1005 i have this error Process: PrintJobMgr [416]
Path: /System/Library/Printers/Libraries/PrintJobMgr/Contents/MacOS/PrintJobMgr
Identifier: PrintJobMgr
Version: ??? (???)
Code Type: X86 (Native)
Parent Process: cupsd [28]
I reinstalled the Hp drivers that I could find on the internet but the problem persist
Aug 31, 2009 | Apple Computers & Internet
Mac vs The HP 3330 all in one printer..need help
Hi there ,
I have a HP laserjet 3330 but cant find a CD to install in on my PC , I am trying to download drivers but having so much trouble .
can you help plz?
Jun 27, 2008 | HP LaserJet 3330 All-In-One Printer
HP LaserJet 4ML Printer Logo
155 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
