Question about Uniden Cordless Phone
Phone not charging, Only 1 month old
    President:
  • 1,118 Answers
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Secend Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Posted on Jul 10, 2010
My iPhone 4 is a few months old and last night it suddenly stopped charging. Of course i didn't realize it until my phone died during the day today and i tried plugging it in and wouldn't ch
The charge adapter maybe faulty.
If your cell phone is a few months old, then it would be still under warranty. Take it back to the place where you purchased it and have it repaired or replaced under warranty.
Jul 26, 2012 | Apple iPhone Smartphone
W20i charged phone, took phone off charger, phone went dead and won't turn on. phone is six months old and had no problems
As you have got this problem and cell is only 6 months old. Pls get it replaced under warranty.
Do carry the invoice with date to the service center.
Alternatively also check the charger, as sometime the cell shows charging due to inserting the pin and a low current passes through but still charger is faulty. Try using some other charger and then go ahead.
Regads,
Richee
Take some time to rate me if it works well.
Jun 14, 2011 | Sony Ericsson Cell Phones
No network coverage & says needs sony ericsson battery to charge which it already has & is only couple of months old
update your phone software using seus(sonyericsson update service)
download it from
http://www.sonyericsson.com/cws/download/1/110/61/1304321491/Update_Service_Setup-2.11.5.6.exe
May 18, 2011 | Sony Ericsson Cyber-shot C905 Cell Phone
Switch not workjng only 6 months old
Consult you owners manual as it should be under warranty.
Jun 22, 2010 | Kitchen Appliances - Others
3 month old new phone. samsung tocco lite. battery problem
1) faulty battery - you'd need to get a replacement from the manufacturer (should be free if still under warranty)
2) when you initially charged the battery after purchasing, if you used it at all before it was completely charged it won't hold a charge.
3) if you live or travel in mountain area, phones lose battery power quicker due to an increase in elevation and distance from nearest tower.
4) if phone has been exposed to moisture or direct sunlight for an extended amount of time, it can damage the phone's ability to hold a charge.
honestly, your best bet is to replace the battery & allow it to charge for 24 hours in "off mode". if the problem persists, then send it in to be repaired.
Mar 19, 2010 | Lands Phones
Wont charge
Hi.
First remove the battery to reset the phone, and check if the problem is still there.
If the phone is under three months old you can call the phone provider, or Nextar, at the number listed on manual, and get the phone replaced.
If you do not want to replace the phone, go to a phone shop, test a replacement cable and ask to test the battery.
Dec 18, 2009 | Nextar MA7151B MP3 Player
Battery not charging
Since it is only a month old you need to take it back. These devices have a smart battery. Most of the time in your situation, the charger itself is the issue. Have you tried charging it by computer usb?
Also, one thing you can try is a hard reset if you hav't already. A hard reset is holding both the lock and home key until you see the apple appear. You could also do a firmware upgrade but I would highly suggest that you take it to an apple store before modifying anything since its so new.
Hope this helps.
Aug 21, 2009 | Apple iPhone 3G
Nokia n73
The battery is faulty or needs replacing. All rechargable batteries lose their efficiency over time meaning that they hold charge for less time. It sounds like your battery is either at the end of it's life or has a fault. If the phone is less than 12 months old, it's worth contacting the seller or manufacturer to ask for a replacement
Jun 02, 2009 | Nokia N73 Cellular Phone
Phone has been idle for a few months. Will not turn on or charge.
Hi have you tried to charge the phone What hapens ?
1. could be that the charger is not outputing the proper current an longer may need to purchase a new charger for the Cell Phone.
2 try to charge the battery in a different phone if possible maybe a friend has the same brand otherwise only one option left buy a new battery and chage it if it works then problem is fairly simmple
the old battery has reached the end of its life and will not charge !
Dec 07, 2008 | Samsung SGH-A800 Cellular Phone
Samsung D900i
It is probably the charging port. It seems to be a common issue with this model of phone.
If it is the charger port on th eD900, You have 3 options.
1. get it repaired, under warranty if possible
2. Get a new one
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on ebay
For more information and links to the parts check the following link below.
Samsung SGH-D900 will not charge problem
Aug 29, 2008 | Samsung D900i Cell Phone
Uniden Cordless Phone Logo
428 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
