Question about 4 Button Replacement Remote
I have the 476a model remote by automate, the unlock button has stopped working and the truck is alarmed, how can i get in without setting the alarm off?
3 Suggested Answers
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
doin12volt
  • 233 Answers
SOURCE: car starter not working
look under the dash for a small silver toggle switch....this is a disable switch for the remote start portion of the system..you may have kicked it / bumped it with your foot, causing the remote start portion to be deactivated. Just flip the switch the opposite way and try again..
Also, there may have been a pin style switch installed under the hood...Check to see if it is bent or broken, if it is, simply disconnect it and insulate the wire that was going to it.
This wire is used as a safety to keep the vehicle from remote starting while the hood is up..to keep people from being injured if the remote start is activated while the engine is being worked on.
Have whatever shop installed the system replace your pinswitch if that is the problem.
Posted on Dec 19, 2008
  • 1455 Answers
SOURCE: So I have a viper alarm system in my car and
You have to turn off your ignition and immediately press that 'eraser like button'(valet switch) for a second and release it. Alarm will then come out of valet mode and your remote should work, if it's good.
Posted on Oct 08, 2010
Mustang alarm
Ford sold a Ford branded alarm through the parts department. These sometimes were a dealer installed option on new cars. Mine would randomly stop responding to the remote and I would have the same symptoms as you describe. I had it removed and the original equipment factory system still worked. Be warned, if you have the Ford "accessory" alarm, your key fobs (remotes) are different and the method to program them is different from what you will read online. You can tell if you have the system by looking at your key fob. The standard Mustang key fob is a 4 button (lock, unlock, panic, and trunk). The accessory alarm uses a 3 button remote and clicking unlock twice would pop the trunk. I really wish I had a picture of the remote because there are 3 button Ford key fobs for cars without a trunk release although I don't think you should have one on a Mustang. Long story short, if you have the accessory alarm, you can solve your problem by having it removed but you will need new 4 button key fobs to remotely lock/unlock your doors
Apr 04, 2014 | 2003 Ford Mustang
My remote has zzzz above the car picture and when i set or unlock the alarm there is no sound coming from the remote or my jeep how can i fix this
Your alarm is in valet. Open any door, press lock, unlock, lock on the remote. Close the door, test the system. You should hear the chirps now.
Apr 21, 2011 | 477A Automate 2Way Replacement Remote ...
2002 VW Cabrio alarm problem: alarm will not un-set. Door will not lock using the key OR the remote. Hitting "alarm off" button on remote, it unsets, then arms again immediately. With engine...
i have a 2002 vw cabrio and won't start after i took out the battery everbody is telling me that anti-theft is lock mode how do i rest it so i can start my car
Nov 08, 2010 | 2000 Volkswagen Cabrio
I changed the batteries on my F350. This set the alarm off on the truck. I cannot get it to turn off. I finally had to cut the wires to the siren. The lights still flash for a minute or longer everytime...
If it is a Ford Factory Alarm it should have key FOBS (remotes). Just press the unlock button 2 times and that should stop it. Alarm systems no matter what brand always have remotes. If you have remotes pressing the unlock should disarm the system 99 times out of 100. If that doesn't work then either the battery in the remote is dead, or the remote is broken. Hope this helps. Cobra :-)
Jun 12, 2010 | 2003 Ford F350 Super Duty DRW SuperCab
I have an 08 Jeep Liberty that has a remote starter on the key. I tried to unlock the car with the remote, however, that didn't work, so I unlocked the car with the key. The alarm went off, I tried pushing...
Sounds like you have a key without the chip in it. Replacement keys without the chip will only unlock the doors and will activate the theft alarm when you start the vehicle.
May 22, 2017 | 2008 Jeep Liberty
Car alarm went off while unlocking the door, now
you need to reset alarm/immobiliser.lock car with remote, hold button down for 30 secs,then press/hold down unlock button,should reset.another way is with key in ignition/turned on, press alarm button down and hold for 30 secs.this resets immobiliser.toyota
systems vary..depending on market.
Mar 30, 2010 | 1991 Lexus LS 400
2001 Jeep Grand Cherokee Laredo. Alarm sets off when unlocking doors with remote and will not shut off with remote, or by pressing the reset button behind blinking alarm light under dash,or by using key in...
I found a solution on another site showing if i turn the ignition on and hold the reset button on behind the alarm light untill it turns to solid blue light then turn off the ignition , it will disable the alarm.
Dec 12, 2009 | 2001 Jeep Grand Cherokee
How to set factory alarm without remote, togle switch enabled
factory alarms are passive, if it is working it sets itself when u exit the car. u don't need the remote for the alarm to work if it has a factory system. if u want to test if it is working lock the car with the power lock button and leave the window down, reach inside the car and open the door from the inside handle, the alarm will sound if it is working, to disarm just lock and unlock driver door with the key..
May 31, 2009 | 1993 Nissan Pathfinder
I have a car fitted with a Clifford GS 470 alarm but I cant get the alarm to stop. The car that this alarm was fitted in has not been started in 5 months and so the battery ran flat. I replaced the battery...
you might have to replace the batteries in the remotes. The reason why the alarm is going off because once you plug power back to the alarm brain it sets the alarm off and the only way to make it stop is to hit the unlock button the remote. Make sure all connections on the alarm brain are good and try changing the batteries in the remotes. also might have to reprogram the remotes to the brain if it has been sitting for awhile.
Feb 16, 2009 | Vehicle Parts & Accessories
4 Button Replacement Remote Logo
738 people viewed this question
Top Directed Electronics Vehicle Parts & Accessories Experts
Kevin Daniels
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
