I have 2-Altec 872a-lansing speakers and their cabinets. They are "vintage" and they weigh alotvery heavy. I would like where to buy the front hard-latte grills for them? I would also like to know how old these are? Serial # 3534-4l-94 and Serial #3557-4l-94 and there is also a 6-didget # 391216 on both of them. Can you help me? with any information that you have will be appreciated greatly. Thanks againand hope to hear from you soon?
    Top Expert:
  • Audio Player... Master
  • 81,400 Answers
Sorry we do not have this type of information.
Posted on Jul 03, 2017
jimbo6
  • 89 Answers
SOURCE: Altec Lansing speakers in laptop
It seems as though the speakers wire connector may have become loose or disconnected. You will have to remove the switch cover above the Keyboard to check. Here is the typical instructions for removing it:
Before you begin any removal or installation procedures:
1. Shut down the computer. If you are unsure whether the computer is off or in hibernation, turn the computer on, and then shut it down through the operating system.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power cord.
4. Remove the battery by following these steps:
a. Turn the computer upside down with the front panel
toward you.
Close the computer.
3. Turn the computer upside down with the front panel
toward you.
4. Remove the three Phillips PM2.5×5.0 screws that secure
the switch cover to the computer.
5. Turn the computer display-side up with the front toward you.
6. Open the computer as far as possible.
7. Lift the rear edge of the switch cover and swing it forward
until it rests on the keyboard.
8. Release the zero insertion force (ZIF) connector 1 to which
the LED board cable is connected and disconnect the cable 2
from the LED board.
9. Remove the switch cover.
Remove the Keyboard:
Remove the four Phillips PM2.5×7.0 screws that secure the keyboard to the computer.
Turn the computer display-side up with the front panel
toward you.
5. Open the computer as far as possible.
6. Lift the rear edge of the keyboard 1 until it rests at an angle.
7. Slide the keyboard 2 back to disengage the tabs on the front
edge of the keyboard from the top cover.
8. Swing the keyboard 3 forward until it rests on the palm rest.
Release the ZIF connector 1 to which the keyboard cable is connected and disconnect the keyboard cable 2 from the system board.
10. Remove the keyboard.
Remove the Speaker Assembly:
Disconnect the speaker assembly cable 1 from the power button board.
5. Remove the two Phillips PM2.5×4.0 screws 2 that secure the speaker assembly to the computer.
6. Remove the speaker assembly 3.
Reverse directions to replace everything.
http://static.tigerdirect.com/pdf/HP_Pavillion_dv6000_MnS.pdf
Posted on Jan 14, 2008
toddg
  • 171 Answers
SOURCE: Compaq Presario v2000 ALTEC LANSING speakers not working
Go to "Start", "Control Panel", Administrative Tools, Computer Management, click on "Device Manager" on the left hand side and look on the right hand side. See if you have a yellow exclamation next to the "Sounds, Video and Game Controllers". If yes, double-click on the line with the exclamation and then click on the driver tab at the top. Click update driver and when it asks if you would like to to check the internet for updated drivers, tell it yes, this time only and continue. After this process, it should either download and install a new driver for your sound card or install the one that was shipped with your computer. If this does not work, please let me know and we will check the next possible problem.
Please remember to rate this solution.
Posted on Sep 24, 2008
SOURCE: Any info on Altec Lansing Satellite 31 set up?
Hi, I have these. Always unplug the Sub before changing the wiring around.
You should have a dual cable. Plug one end into the Sub's Audio In and DC Out (the one that looks like a power plug goes in DC Out, the one that looks like a headphone goes in Audio In). The other end of the dual cable goes to the Satellite that has the volume control. Plug into DC and Sub. Plug a cable with headphone plugs on each end into the SPKR jack on each Satellite. Plug another cable with headphone plugs into either Input 1 or Input 2. The other end goes to your computer's audio out. I don't have the original of these two cables so I can't tell you what they look like. If one is longer or thicker it should be the one to go between the speakers. Set the level control on the Sub about 1/4 up. Plug the Sub in and play some music. You can adjust the Sub level and the Bass and Treble to your liking. I have my Bass & Treble straight up, Sub at 1/4. You can use one of the inputs for your computer and the other input for another device like an iPod without having to unplug things.
Posted on Nov 15, 2008
SOURCE: Altec Lansing ada745 fuse
Yes, it's a 1A 250V glass fuse, 0.75" (1.9cm) long. The only other number on the fuse is "239", if that means anything. You take it out by putting a flat screwdriver in the slot on the fuse holder cap, turn counter-clockwise, and pull out once it releases.
Posted on Nov 20, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: my altec lansing speakers for my sansa is messing up my sansa
Download the Sansa Recovery Tool from Sandisk's website (make sure the Sansa is not plugged into the computer yet). Once the Recovery Tool is downloaded, connect the Sansa to the computer while holding in the REC button and continue to hold it even after th player is plugged in. It should go into Recovery Mode in 10-15 seconds or so.
-Tha Mp3 Doctor
Posted on Jan 18, 2009
I have Altec Lansing ada 885 I only have sub woofer can anyone tell me how to power on with out other speakers . Because I have no switch to turn on with no other speakers and also the name of he plug on...
Throw it away, they are garbage speakers. I ordered one and ended up giving it away as it was so dire. It hissed when turned off, it drove me mad! The part you are missing is the amplifier which is in a small box unit in the right hand front speaker. Power goes into it and the input audio is amplified and goes to the Sub Woofer and the two satellite front speakers.
It will work on a stereo amplifier, but not as it is.
Manual
Using the Speaker System Altec Lansing ADA885 User Guide
Set up
Setup Altec Lansing ADA885 User Guide
Mar 10, 2018 | Altec Lansing Audio Players & Recorders
Altec lansing 221 computer speakers sound solution
Unfortunately it looks like Altec Lansing goofed up on this set and didn't provide a bass control knob. You will need to use some sort of software equalizer on your computer to turn the bass down.
Mar 24, 2012 | Altec Lansing 221 Computer Speakers
Just want to know what it would cost to buy the altec lansing speaker moder acs 45.
It will cost you about $75 for the Altec Lansing ACS45.2 Powered Subwoofer Speaker, which I am assuming is what you're talking about, since the only thing that comes up under ACS45.2 is that. It should cost you about $75, although you will generally only find used ones because Altec Lansing no longer sells them.
Apr 10, 2011 | Computers & Internet
Altec lansing vs2121 model speakers blown
I have the speakers ( in perfect condition) but can not find the base unit. Do you want to sell your base unit ? Or do you want to buy the speakers ?
stevem727@gmail.com
Mar 11, 2010 | Altec Lansing VS2121 Computer Speakers
Need advice on Altec Lansing x5021
Altec Lansing is the best company to buy speakers if you watch movies or listen to music. it hits both deep and a strong bass. These are the best speakers to buy.
Feb 25, 2010 | Altec Lansing MX5021 System
How do u take apart the speaker cabinet on an altec lansing ACS22 speaker?
the easy method is to drop it from Empire St Bld.
ha ha ha....
the difficult way is to check where are the screws on the speakers....mostly they are hidden behind the front perforation cloth or plastic sheet of sound out pad...that can be removed carefuly by using a small hook or a screwdriver...be careful not to hurt the actual speaker inside.
Jan 23, 2010 | Altec Lansing ACS22BW Computer Speakers
Step up transformer for altec lansing atp3 that runs on 220 volts
What voltage are you stepping up to?
Does the unit run off a seperate PSU/Transformer.
Can you check your info please.
Jan 19, 2010 | Altec Lansing ATP 3W Computer Speakers
No sound after i buy new PC ( speaker altec lansing atp3) should i install altec driver ?
check the port to which u have connected ur speakers. And also install proper driver
Aug 20, 2009 | Altec Lansing ATP 3W Computer Speakers
Altec Lansing computer speakers , power requirements
You have to find out what the speakers are rated at then go form there. There is usually a placard or sticker on the back that says what watts and voltage they are rated at. Then you have to find out what plug goes in. Or you just buy an OEM plug
Dec 06, 2008 | Altec Lansing Multimedia Computer Speakers
301 people viewed this question
 Grubhead
Grubhead
