Question about Protron PLTV-4250 42 in. LCD Television
Lost power completely
Unplugged power cord and plugged back in- no red light or green light.... nothing
  • 1 more comment
  • ucdawn Jul 10, 2010
    protron pltv-4250 lost power completely..... no green light no red light...... unplugged and re plugged power cord, nothing
    protron pltv-4250 lost power completely...... no red light no green light..... tried unplugging and replugging in..... tried rebooting power cord..... nothing
    everyone is saying that this is a supply board problem- we are having issues getting the back of the tv off to even check this...... lost power on Protron pltv-4250- no red light no green light.... nothing..... tried unplugging and replugging.... tried rebooting surge protector... nothing
  • 10,594 Answers
If you are comfortable with working in tv circuit boards then unplug tv from AC wall socket, take off back of tv and follow AC cord going inside tv that will take you to power supply board, check fuse on power supply board, replace it with same rating written on it if it found blown.
Replug tv back in wall socket and check if it turns On.
If still problem not solved then power supply board is defective and need to be replaced.
Local tv repair shop will help you if you think its not safe for you to work inside tv.
Hope these info will help you.
Thanks.
Posted on Jul 10, 2010
  • Shahid Electronics
    Shahid Electronics Jul 10, 2010
    OK, thanks for rejecting assistance but thats they only way that I told you to fix your tv issue.
    Unplugging and replugging wont fix your tv problem, it got hardware failure for some reason and need to be checked.
  • 1,476 Answers
You could have a blown fuse but that is very rare these days with switch mode power supplies. Certainly I would check that first along with making sure you have power to the unit. If this all checks out ok I have a tip at http://www.fixya.com/support/r4606286-troubleshoot_dlp_tv which explains how to troubleshoot a dlp unit. Let me know if you need more assistance.
Thanks for using FixYa and for the great rating.
hardrocko
  • Kim Yearick
    Kim Yearick Jul 17, 2010
    Seems like you have plenty of people who want to help but aren't saying anything new or anything I haven't already suggested. The problem is not always going to be the power supply and these days almost never the fuse. I had a unit last week which had your syptoms and had a bad scaler board (control board) and a good power supply. TVs these days are quite complicated and when there are no lights it does not immediately mean the power supply is bad. It also does not eliminate the power supply as the problem.
    This is where some training or background in electronics would be helpful. Bulging caps have been a problem for many years, more often now with Chinese imports, but knowing that does not make you an electronic tech. You need to know how the circuits work.
    If you have no power I would suggest my tip at http://www.fixya.com/support/r4606286-tr... first to try to resolve the problem. If you have already been there as I suggested then here is your best approach.
    Check the fuse (main) if OK. Look for bulging caps and replace. If none or you replace them all and it will not power on check the outputs of the power supply with a DMM, with the unit hooked to an isolation transformer, check for + and - 5 volts, + and - 15 volts and probably + and - 24 volts. (keep in mind that I cannot put my hands on your unit and I am only making my best guess as a qualified electronic tech.) Personnally at this point I would have an idea if the pwr board was bad or not. If you don't think it is working order one from http://www.encompass.com . If this does not solve your problem then order the control board from the same company.
    This should get your unit running.
    If you need more help let me know. Thanks for using FixYa.
    hardrocko
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems the issue is with the power board or the main board and we’ll need to check few things. When you open the unit up; take a look at the power board-the board where the power cords/plugs goes into. You might see some filter capacitors a little bulged up in the top-If this is the case-this is your defective part(you can try to replace them-but some soldering equipment is needed). If not, then probably the main board has gone bad. This is the other board-where all the inputs are going into. All this is only recommended if you have electrical expertise and know how to solder/re-solder components. Please note that the TV components consists high voltages even when in off position. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
  • Protron Master
  • 6,993 Answers
your TV is having a power problem. The power board is defective, that's why there is no power on the TV. Also, do not overlook the power plug. The power plug may have been bad. Do a thorough diagnosis on the power cord in order to make sure power is entering into the TV, before you check for other causes of the problem.
Get a screw driver, open the TV cover to gain access to the power board, check for any blown fuse/bad components.
You need to get a meter, read the power board of the TV, in other to detect the bad component (capacitor, diode, transistor etc.), make necessary replacement and the TV should power up again.
The fault is mainly a power problem, so the power section of the TV needs to be diagnosed.
Good luck.
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
http://www.invacare.com/doc_files/1125085.pdf
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
Turned itself off. I turned it back on and power button blinks green for a few seconds then blinks red continuously. red light by card reader blinks red about every five seconds. No picture, no sound.
unplug it from power source completely 15 minutes then plug back in with NOTHING plugged into any of the ports. If it boots back up then does it again later it make be something plugged into a port causing power to back feed into the boards. I had this same issue on my plasma last year ended up being the xbox360. After this if it still wont power then your power board maybe bad.
Oct 19, 2014 | Panasonic PT-50LC14 50" Rear Projection...
When i turn on my xbox i'm getting 3 flashing red lights what does this mean
it means your xbox is overheating, you can send it back as they extended the warranty on it for this common fault unless you have modified it, in which case look up ring of death on youtube.
Jun 13, 2011 | Microsoft Xbox 360 Elite Console - Black
Prints multiple copies of job and will not shut off or stop printing
Unplug the power cord from the printer. Hold down the red "X" button. Plug the power cord back in while holding down this button. Release the button. Should see flashing red and green lights. Unplug the power cord again. Replug. Should be reset.
Apr 10, 2011 | Dell 1100 Laser Printer
My xbox has a three light red ring
Let's unplug and reconnect your power supply
  1. Disconnect the power cord from the back of your console. Unplug the power cord from the wall outlet and the power supply unit.
    Reconnect the power cord to the console. Then plug the power cord back into the wall outlet and the power supply unit.
  2. Make sure that all three connections are firmly secured.
  3. Turn your console back on.
    Check the light on the power supply. If this solution worked, your power supply light will be green and the power button will look like this:
Dec 29, 2010 | Microsoft Xbox 360 Console
Power outage this am. Wii won't even turn on
Usually, after a power outage, a power spike (when the power returns) can disable/blow the fuse in the AC adapter for the Wii.
Try the following steps in this order:
FIRST:
- unplug the Wii's power cord from the wall, and leave it unplugged (from 5 mins. to 5 hours). Then, plug it back into the wall. (Unplugging the power cord from the back of the Wii will not help. You need to unplug the power cord from the wall.)
- This usually helps reset the fuse circuit in the AC adapter, and your Wii should work again.
SECOND:
- open the panel on the AC adapter box in the power cord; since the screws are proprietary, you will need to creatively use existing tools to turn the screws
- check the 3A fuse in that box; if it looks blown, then replace it
THIRD:
- it might be cheaper to replace the AC adapter with another one
FOURTH:
- get the unit repaired
MUST DO:
- buy a SURGE PROTECTOR power bar, and plug all of your expensive items into it (to prevent this from happening again).
Hope that helps!
Aug 09, 2009 | Nintendo Wii Console
On my PS2 thin the red standby light is on and I push the button to turn it on, the light turns green like usual, but only for a second and then the light completely shuts off as if it was unpluged, after...
Try pulling the power adaptor out of the back of the ps2 ,then make sure no dust or debree is in the part that plugs into the ps2 then plug it back in and make sure its attached firmly. The ps2 should turn on now
Jul 12, 2008 | Video Game Consoles & Games
Protron 42
on the back of the TV where the power cord plugs into the back of the tv there is a small black on/off switch- it's not as obvious as you would think.... but that was turned off. Not sure how that happened since the back of the Tv was never touched when it went dead- but I unplugged the cord from the back of the tv and from the outlet and reset that switch and it worked.
Jul 10, 2008 | Protron PLTV-4250 42 in. LCD Television
Protron PLTV-4250 42 in. LCD Television Logo
200 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
