Question about ViewSonic VA720 17" LCD Flat Panel Monitor
VA720 To turn on I have to push button 5-6-7 times. After short blink monitor is dark. lubar3@yahoo.com
  • lubar3 Apr 19, 2008
    How can I get capacitor to change one?
  • 472 Answers
You could possibly have 2 problems with your monitor, though they are more then likely linked.
The Viewsonic monitors (like most) end up with buldging capacitors after several years use. This is typical of most equipment these days.
You can either replace the capacitors yourself or get in contact with someone local to you to have it done.
The reason I say there could be 2 problems that are linked is the fact when your screen does finally come on, it flicks the screen up for a second which would normally indicate a problem in the inverter circuit.
Because of the power fault though I believe it is more likely the one fault causing two problems.
With the capacitors failing, the voltage inside that powers the internal video board are not stable. That is what causes it to behave as it is.
On the homepage of this site you can use the Repair Service section (on the left side about half way down the page) to find a local repairman if that is the route you want to go.
Posted on Apr 19, 2008
  • Peter Thompson
    Peter Thompson Apr 19, 2008
    After you open the monitor up (with great care) you will in most cases see the capacitors that have failed.
    Check the numbers on the side of those, quite possibly 1000uf 16v and goto your local electrical parts store and get the same or higher rated on the volts capacitors to go back in. IE a 1000uf 25v capacitor is ok, a 1000uf 10v capacitor is not.
    If you don't understand capacitors, then ask the people at the shop to explain how they are marked.
    As a quick guide, the stripe on a capacitor points to the negative leg. On the board, you will see a circle printed there with a dark side in it. The negative leg goes to this hole on the board.
Turn it on and the green light blinks but the
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 15, 2010 | Computers & Internet
disconnect all the cables from the monitor except the power cable and turn it on if still the same issue the monitor has gone bad.
Mar 28, 2010 | Computers & Internet
Dark LCD screen. Very faint image.
Internally it has a inverter board which go bad sometimes or due to heat sometimes get unpluged.So you will have to open it make sure when you do there is no power going to it.Look at the wires make sure they are snug and try again.
good Luck
Oct 04, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Display on mac mini only shows no signal and turns black
his step-by-step guide describers how to obtain and install ViewSonic VA720 drivers for Mac.
1. Define your ViewSonic Monitor device model.
2. Define your operating system to install your ViewSonic Monitor device. Note: Update Drivers in Mac
3. Browse Monitor Drivers.
4. Find ViewSonic Monitor Drivers.
5. Select ViewSonic VA720.
6. Download ViewSonic VA720. Note: you can update all Drivers automatically with RadarSync (Freeware) or Driver Detective (Shareware).
7. Install ViewSonic VA720.
8. Restart or reboot your computer to finish your driver installation. Note: you can backup your computer drivers before updating.
May 03, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Viewsonic VA720 monitor has small blinking light, won't turn on
When turning on the computer we get analog auto save, and don't get as far as the desktop, how can I solve this problem
Debi
Viewsonic VA720 LCD 17'' monitor LED light blinking, no display
there is atleast a 5 year difference between your computers. Technology has made a huge jump from back then, especially in graphics cards!!! that LCD was probably made after your computer, alot after your computer as a matter of fact. So it is your graphics card. get a new computer, its time to update
Apr 28, 2009 | Computers & Internet
Monitor blinks and then remains blank after computer turns on
THERE OR AN DEVICE THAT IS CALLED A CHOCK AND IT IS A MAGNET IN A SQAURE HOUSING THE A CORD FITS OVER YOU CAN PICK THEM AT ANY ELECTRONIC STORE THIS MAY HELP WITH AN INPEDANCE PROBLEMS SOME TIMES
CANDYMANGANDY
Dec 13, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
Viewsonc VA720 Flickers On and Off Continuously
Take a look at the capacitors and see if you have any weak one. An obvious way to spot one would be one bubbled up on top. A bad cap won't always be bubbled up. The monitor probably can operate until the voltage drops under 8 volts. Also possible if power supply check out good would be a weak backlight inverter.
Apr 05, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
ViewSonic VA720 17" LCD Flat Panel Monitor Logo
126 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
