Question about Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer
Im trying to fax out a paper & my fax machine wont let me put in the fax number. It just has a bunch of letter over the screen & it looks like its searching
    President:
  • 1,285 Answers
This is what you have to do (you have the software disk that came with)
uninstall completely disconnect all (power/usb/phone jack) and re install /set up as new...(this can take 15-20 min)
Posted on Jul 10, 2010
How do you retrieve the old faxes? The paper wasnt in the right feed and a bunch of faxes came in and it never got through. I need to retrieve it.
? Printing All Unprinted Documents in Memory
1 Press [Menu].
2 Use [{] or [}] to select , then press [Start/Copy].
3 Use [{] or [}] to select .
4 Press [Start/Copy].
The fax prints the documents one at a time, after each the reception number is displayed on
the LCD.
5 After printing, the LCD displays .
6 Press [*] to delete the previous printed documents.
If you want to keep the documents in memory, press [#].
Jan 31, 2011 | Canon FAX JX200 Fax / copier Plain Paper...
I havent used the fax machine in quite sometime<<< i must be doing something wrong... im able to receive faxs but cannot send them, im sure im prolly doing something wrong can u give...
Hey!!The best and fastest way is to put in your documents in the ADF(automatic Document Feeder)Put the machine on fax,Dail your fax number and press the BLACK start button.Good Luck!!
Nov 05, 2010 | Canon MX310 Office All-In-One Printer
How to register number has been delete. How do you put them back in a Pansonic Panafax UF-55o machine. The fax machine work just the long distance number that was register are going. Need to know how to...
press
function 72
set
press 01 on the soft key pad enter fax number
set
enter name with the letters on the soft key pad
set
continue with 02 as above or press stop
press
function
62 set to print diectory
Mar 24, 2010 | Panasonic Panafax UF-550 Plain Paper Laser...
CAN'T GET ALPHABET LETTER TO APPEAR FOR STATION ID.
Letters are on the soft pad to the left of the number keys. Very tiny, so look close. You can also lift up the mylar sheet and remove the paper sheet.
Mar 04, 2010 | Panasonic Panafax UF-890 Plain Paper Laser...
I never Used A Fax Machine. I was Given A ''Brother IntelliFaxMC''
if you look at the area where you put your paper to seend ( that is the document feeder ) there should be a diagram of a pice of paper with a corner turned over, if lines are on the top part put paper in dac feeder face up. if lines are on the little corner pice put the paper face down,
if not sher put one pice of paper with lettering in doc feeder press copie of it comes out you got it right. hope this helps
C.W.H. ( typboy)
Jan 23, 2009 | Office Equipment & Supplies
Letters vs. numbers
After you put in the number with the hard buttons press set twice, then enter letters for the NAME with the soft buttons on the left side.
Jan 19, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
Fax machine with error code. Panasonic UF-780. Error: "Check cassette info code = 011"
you broke the tab on the back of the paper cassette. if you look in where the cassette goes on the back left you will see a hole with a sensor that looks kinda like a upside down letter U . put paper inbetween the sensor and the machine should say out of paper and put the cassette back and you should be fine
Dec 29, 2008 | Panasonic Panafax UF-780 Plain Paper Laser...
Hp1040 fax and copy machine
I solved this problem by returning my fax machine to where I purchased it and exchanged it for another type of hp machine and it automatically goes in long format when it scans long format paper. If it scans short letter form, it automatically copies itself and adjusts itself. Thank you aniway, durl
Nov 25, 2008 | HP 1040 Plain Paper Inkjet Fax
Need to change name and number
Press the MENU button and press 7, then 2 on the numbers keypad. You can then use the keypad to change the fax header. Press the keypad numbers corresponding to the letters you need. It will cycle through lower case first, then upper case. Press the RIGHT arrow button to advance one space between letters.
Jul 18, 2008 | HP 920 Plain Paper Fax
Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer Logo
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
