Question about Samsung Washing Machines
Grease build up
How do i get rid of the grease build up inside my washing machine?
I mainly use a cold wash
  • 1,940 Answers
I would run a small load with maybe a couple of dirty towels with some dish cleaning soap, particularly one with good grease removing capabilities. Also, be sure to use the hottest water setting you have available for this load.
Posted on Jul 10, 2010
Am using Daewoo - DWF-750S Top loading washing machine. We have the problem of black film built up at the back of the drum. Am using powder to liquid detergent, the problem still persisted, infact the
Frequently, if you use low temperature washes most of the time, a layer of grease (sounds yukky) builds up in all washing machines. The way around this is to find some clothes (boiler suits or overalls would do) which require high-temperature washes to remove grease and run these through at a high temperature wash for a couple of washes, using both detergent and washing soda (Na2CO3, sodium carbonate). The sodium carbonate will dissolve the grease, both on the clothes and the washing machine.
Jan 31, 2015 | Daewoo Washing Machines
Bad smell in washing machine...clothes smell bad after wash
hi there is a build up of lime and old dirt in the inside of your drum the best thing to get rid of the smell is put a very small amount of bleach in the drum and put your machine on a very hot wash it will help in your hand book it will tell you to use your hot wash with a bit of powder and no cloths at leased once a month i dont know if you use your hottest wash most people dont these days because of the low temp powders, also the best product to use is lim away but you can only get it on usa bases or from the usa you might find someone on line that sells it that will get rid of all the lime thats been built up in your machine if you cant just use a bit of thick bleach hope this was helpful
Nov 18, 2011 | LG WM-2277HW Front Load Washer
Smells very bad inside washer
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} A lot of machines can suffer from this problem. It is usually down to a bacteria build up between the drum and the tub. The majority of appliances that suffer form this have been used mainly on 40 degree washes and with a biological detergent.
The best way to get rid of this smell is to place two tablespoons of washing soda or soda crystals in the detergent drawer and then run the appliance empty on the 90 degree wash. You may have to repeat this treatment several times before the smell goes but it will go eventually.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
Jan 20, 2010 | Speed Queen CTSA0AWN Front Load Washer
Very strong musty smell inside it which is going onto the washing!! What is the best way to get rid of it? We have tried a realy hot wash with a cup of vinegar? email address is mclaren29@xtra.co.nz
Depends how old the machine is the hot wash with vinigar usually works but if the machine is relativly old there will be huge build up of scum in the machine the best way to solve this is to stip and manually scub the drum and pipes out/do not know what washing powder and stay soft you use but try to use a white or clear type stay soft and a powder for hot and cold washing/also just check where the drain hose goes from the machine into your house drain pull out the hose and make sure the smell is not coming from the drain back into the machine.Get a technition to strip and scrub the machine it costs money but saves a world of smell.
Dec 29, 2009 | Washing Machines
Oily substance collecting in the door's rubber seal.
It is not oil, but a build up of grease and living bacteria, caused by doing too many low temp washes.
The only permanent solution is to replace the door seal, and at least once a month, do a hot boil wash without clothes in, but with powder or detergent in as normal.
This is called a maintenance wash, and is now recommended by all manufactuers.
Please rate my solution.
Thanks.
May 13, 2009 | Bosch Washing Machines
A bad smell from inside
A lot of machines can suffer from this problem. It is usually down to a bacteria build up between the drum and the tub.The majority of appliances that suffer form this have been used mainly on 40 degree washes and with a biological detergent.
Dec 30, 2008 | Ariston Technologies AWD121WH
Dirt and grime always building up around seal inside door
This is a very common problem with a lot of users, it is mainly down to the way you are using your washer.
The most important factor is that you are probably doing a lot of low temp washes,eg:40oC.
This does not let the wash powders and detergents to work properly at these low temps, so consequently you get a build of slime and grease and bacteria which is actively growing.
At least once a month depending on how often you wash, do a 90oC hot wash with powder in, but no clothes in.
This is called a maintenance wash, and most manufactures are recommending this now in the user instructions.
The other thing to do now before it gets any worse, is thoroughly clean the door seal and glass with a scouring pad or steel wool pan scrubber you will not hurt the door seal by doing this, and remove as much of the grease etc that you can, pull back the door seal and get inside where you normally can't see.
You will find that the seal will be stained, but as long as you get off the worst, it should be o/k.
Hope this helps solve your prob.
Plz rate my solution.
Thanks, and a merry xmas.
Dec 23, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
Can't get rid of E1 error on a Samsung front loader washing mach.
E1 : washing machine has exceeded a check time for fill, heat or empty.
Common causes for this are fill and empty problems, heater fault (or the wiring
to it broken), water pump open circuit (although that would stop the water draining too) Pressure chamber blocked or pressure tubing pipe looped below the pressure bottle, or a sticking eco ball in the sump hose (sludge and grease build up)
This error code is generic and vey common.Since you have tried the remedies.Try getting checked the internal wiring damage by professionals.I hope certainly hope the problem lies there.
Dec 09, 2008 | Washing Machines
Stale water smell
If the washing machine itself smells bad when you open the door, it could be that it's covered in a horrible grease and gunge inside all the hoses and the tub. This particularly affects older washing machines and is common with washing machines that have only really been used at 40° or where only liquid detergent has been used.
Not using enough soap detergent over a long period of time can cause a build up of grease and therefore bad smells.
Get rid of washing machine smells
You could try to clean the washing machine inside using Soda crystals which dissolve grease. I recommend putting half a packet inside the drum and washing on a boil wash (or follow instructions on the packet) Using this method every month or so, or using ordinary detergent if no soda crystals are available can help prevent smells from your washing machine. If your washing machine is badly affected by grease and slime, it may be very difficult to remove it.
Get rid of washing machine odours using vinegar
White distilled vinegar has an array of uses. For bad washing machine smells, try putting half a cup of white vinegar inside an empty machine and put it on a boil wash. Because the first bit of water goes into the sump hose and is sealed off, I recommend that you wait until the washing machine has been filling for about 30 seconds and then pour the vinegar into the soap drawer to let it wash down into the machine. I've had reports back from people that this does actually work.
Mar 07, 2008 | Hotpoint WMA40 Front Load Washer
Washing Machines Logo
56 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
