Question about HP Digital Projector Vp6110 Multimedia Projector
I can't get a picture when I hook my projector up to my laptop.
    President:
  • 1,099 Answers
HELLO,
If your LCD or DLP projector displays no image, this could be a variety of problems. First, check that the projector has power. On the top of the LCD or DLP projector should be some lights. With power, those lights will be on. If it has power, check to make sure that the projector lamp is firing. If so, go to the source. Make sure that it is connected with a VGA cable or USB cable to your computer, or with an RGB cable, S-Video cable or DVI connection to your VCR/DVD Player. From a laptop computer, the VGA cable should be connected to the VGA out connection, and into the VGA in connection on the projector. Are both ends tight?
If everything has checked out so far, the solution probably lies with the external monitor port. Check this by holding the Fn key on the keyboard, then press the F7 key. (On some computers, the key might be F5 or F3. Try these if F7 doesn't work) Each time you press the Fn / F7 combination, you will cycle your display through the following settings:
* Press Fn / F7 once: The laptop screen only
* Press Fn / F7 twice: The projector port only
* Press Fn / F7 three times: Both the laptop and projector port
* Wait a few seconds after each time you press the key combination to let the LCD or DLP projector refresh. Nine times out of ten this will result in seeing your projected image.
Hope this helpout....
Posted on Jul 10, 2010
Nec multimedia projector is hooked up to laptop
check your connection from projector to laptop, you might probably need some rca cables
Aug 28, 2013 | Office Equipment & Supplies
Monitor Display on TV
Try the following:
Power up the projector first. With the laptop hooked up but not powered on once projector is warming up begin booting laptop. If there is still no display once its projector is fully warmed up and laptop booted you can try using the (fn) key with the laptop monitor switching function key usually F4 which switches the display monitor to show on external, external and laptop or just laptop. If this all fails try changing resolution of laptop to something that might be more projector friendly.
Let me know how you go.
Mar 23, 2009 | Dell Inspiron 6000 Notebook
Connected to mac
reset the laptop with the video cable hooked up
Feb 20, 2009 | Toshiba TLP S30 Multimedia Projector
Hook a laptop to the dp9300 proxima
Assuming that you are on the correct input on the projector it may be that you need to toggle the image to the HD15 pin output connector. Most laptops do not auto output an image you have to send the command which is function F7 on some computers both held down at the same time. Also the native resolution is 1024X768 if your resolution is set to high it will not sync up. This is set in the display properties of your computer.
Nov 25, 2008 | InFocus Proxima DP9300 Multimedia...
Emp-s1
Pls change the display settings of your laptop to 800x600 or 1024x724 then check. The projector SVGA.
Pls tell if you are not able to solve the problem.
Viren
Apr 12, 2008 | Epson EMP S1 Multimedia Projector
Hooking projector
You will probably need a standard VGA cable. The ends look like the connection for a monitor. Take a look if you don't know what I'm talking about: http://en.wikipedia.org/wiki/VGA_connector
There should be a port on your laptop and one on the projector. After it's hooked up you might have to toggle between the projection settings or select the correct source on the projector. Normally, there is a source or input button on the projector. If the picture isn't showing up on the projector but is on the laptop or vice versa, you'll need to toggle between settings. On my dell, it is fn (function) and the F8 key but sometimes it's the F7 key or some other F? key, just look for the LCD/CRT on the function button or the picture of a monitor looking thing. This is only if you don't see the image from the projector. Hope this helps you out!
Nov 09, 2007 | Compaq Presario 1200 Notebook
PowerPoint and Projector (InFocus LP640) Incompatability
I am unsure of this from your post, but don't try to hook the projector up to the laptop while either one of them is on. Power both the laptop and the projector off, hook up the projector to the laptop, then power on the projector first then the laptop. If you are already doing this, I apologize for stating the obvious.
Jul 03, 2007 | InFocus LP640 Projector Multimedia...
Projector won't show picture
My projector will not show the picture but i have sound
Oct 27, 2006 | Panasonic PT L711XU Multimedia Projector
HP Digital Projector Vp6110 Multimedia Projector Logo
451 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
