Question about Panasonic PT-47WX49 47" Rear Projection Television
Picture is smaller than screen and has a blue duplicate picture
  • 1,476 Answers
Sounds like you have bad convergence ICs. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, how to repair it and where to get the parts at the best price. Let me know if you need more assistance.
Thanks for using FixYa and for the generous rating.
hardrocko
Posted on Jul 10, 2010
The normal screen is divided in two smaller screen,which are showing the same channel.I want to return the screen to its normal screen size of single screen channel
The smaller picture is PNP called picture and picture.It can be set in to the menu setting.Go to menu setting and search the PNP code.Try to off or diable the PNP menu setting to back the normal single picture.
Jul 09, 2011 | LG 42PC3D 42 in. Plasma Television
White bleed thru on top of screen when picture is smaller
This is the first time I've heard of white bleeding through on these TV's, it usually red or blue. There is a cable called the LVDS cable. It transmits the picture from the main board to the LCD screen. It runs from the main board under the power unit to the top of the LCD screen. You could replace it yourself and find the cable online.
Xe Technology
Jan 05, 2010 | Vizio VO47L 47 in. LCD TV
I RECENTLY PURCHASED A 1994 bIG SCREEN TV ( mODEL # TP55C81 ) THE PICTURE IS PURFECT BUT IM SEEING THE RED GREEN AND BLUE LIGHTS . THE CLOSER I AM TO THE TV THE SMALLER THE LIGHTS ARE AS I BACK UP THE...
You have a projection TV - basically a red, green, and blue spotlight is shown onto the back of an opaque screen that creates the color picture you see. The spotlights you are seeing is common for a TV of this vintage and type.
According to the user's manual, you should ideally be sitting no closer than 10 feet to the screen.
Sitting closer to the screen may enhance the phenomenon you are experiencing.
Nov 19, 2009 | Toshiba Televison & Video
Blue light flickers, but no picture
I have a gatway fpd2185w the blue light blinks and then dims and the power button dosent work.
Jun 28, 2009 | Gateway FPD2185W 21 in. LCD Television
3 inch red area at top of screen and smaller blue area at bottom of screen
this would need a optical block. there would be no other way to solve this issue
Apr 18, 2009 | Televison & Video
Picture green and not clear, getting smaller, shutting itself off
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 07, 2009 | Philips Magnavox 51MP392H Rear Projection...
Toshiba TP50G50 Theaterview picture is double with red color only
Your alignment is off. Go to the set up menu then convergence. hit right and you will be in the convergence menu. select the color that is not in alignment. The green line does not move. if blue and green are lined up the line will be cyan. if red and green are lined up the line will be yellow. when all three are lined up the color will be light. Best of luck!
Nov 16, 2008 | Toshiba TP50G50 50" Rear Projection...
Normal picture mode make the sharper picture quality but smaller screen apparance
If the broadcast is in 4:3 (square) then either you can have the black bars on the side, or the TV can stretch the image to fill the screen.
Nothing wrong with your set. The broadcast must be in 16:9 to fil the screen.
Aug 07, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Screen Issue when HD Satellite Receiver is set to 1080i
these tv's are absolute garbage. Ours does the same thing with hi def.
never again for a samsung
Nov 03, 2007 | Samsung HC-P4363W 43 in. TV/DVD Combo
Panasonic PT-47WX49 47" Rear Projection Television Logo
334 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
