Hi i have a Sony KDL-40-2000 that has started to switch its sel*** then back on again within seconds mostly every time i use the remote to go into the menu but will sometime just swith off/on whilst watching without doing anything. It does not go into stand by mode as the green light remains on throught the on off process. Has anybody had this fault or know a remedy
redhead7377
  • 51 Answers
SOURCE: Four blinking red lights.
you can have the inverter board replaced...instead of the entire panel.
KDL 40S2010: inverter part # 178950032, you will also need 2 spacers..part # 289765511
you're looking @ 200-300$ for the inverter and 5-10$ a piece for the spacers.
KDL-46V2500: inverter part # A1251295B
you're looking @ around 500-600 $ for the part
Posted on Sep 09, 2008
SOURCE: Sony KDL 46V2500 - turns off, then on
We had the same problem, not quite as often...but I ck'd the power cord connection at the back of the tv and it was loose. I know,sounds so simple - but it worked. Good luck.
Posted on Oct 19, 2008
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Posted on Oct 23, 2008
SOURCE: pioneer pdp 502mx goes to standby no picture after power on
Contact Pioneer at 1-800-421-1404 about getting an in-home power supply replacement. This is a known issue with some plasma displays. Some of you would experience a loud pop and then the power supply fails. You get a red light below the ON button, when you press on, the red light will turn green for a second and then back to red. The plasma display will not turn on after the power supply fails. Call Pioneer at 1-800-421-1404.
Brought to you by http://abstravel.com and http://reservaciones.com
Posted on Mar 29, 2009
SOURCE: 55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Posted on Sep 28, 2009
Has verticle lines and turns off.
SONY LCD TV 32 inch, Display problems. Display half white colour.
Jan 20, 2012 | Sony KDL-32M3000 32 in. LCD Television
How to disable shop mode on 32" sony tv
You need to reset the TV to factory defaults, then run through the initial setup again and make sure you choose HOME and not RETAIL as the location on the second screen of the setup.
To reset the TV to factory defaults:
1. Switch on the TV
2. Hold down the UP arrow key on the Sony remote control
3.While stillholding UP, press the POWER/STANDBY button on the front of the TV once.
4. Release the UP button
The TV will switch off and back on again. You will lose all of your settings and you will need to run the automatic channel scan again, but you will be able to select HOME as the location this time.
Please note: This question is listed for Sony TV model number KDL-32BX300. If you have a different model the reset method may not apply to you. In this case, try it once and if it doesn't work, please post back with the correct model number.
Hope this helps - please reply to me from within this page if you need further assistance.
Regards,
BElectric
Feb 05, 2011 | Sony KDL32BX300 32 in. TV
Sony Bravia 46" The standby light flashes four
If tv model number is KDL-46S2000 then 4 times blinking standby light indicates back light failure problem in your tv.
Check/ replace back light inverter boards to solve its problem.
Thanks.
Dec 29, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Need to program my synergy v time warner remote to my sony bravia 32"
STEP 1: PRESS THE MODE BUTTON ON THE TOP OF THE REMOTE, THEN PRESS TV STEP 2: PRESS AND HOLD THE "SEL" BUTTON AND THESH "MUTE" BUTTON AT THE SAME TIME UNTIL THE BUTTONS ON THE TOP ARE LIGHTING UP IN SEQUENCE FROM RIGHT TO LEFT STEP 3: HOLD THE CHANNEL UP BUTTON UNTIL YOUR TV TURNS OFF. WHEN THE TV TURNS OFF HOLD THE CHANNEL DOWN BUTTON UNTIL YOUR TV IS BACK ON AND ALL LIGHTS ON TOP FLASH AT THE SAME TIME
Jul 18, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Have a sony KDL - 46v5100 volume problem
Tap the "Theater" button on the remote. You should see either "Theater Mode: On" or "Theater Mode: Off". If it is off, tap it again to turn it on and wait for it to go away. Now tap again (should say "Theater Mode: On") and then press and hold it for about a second. This should actually turn it off, as opposed to just pretending to. Works on my larger Sony KDL.
Jan 15, 2010 | Sony KDL 46V5100 46 in. LCD HDTV
Sony Bravia KDL-32V2000 LCD TV switching off and on by itself
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Apr 29, 2017 | Sony Televison & Video
TV volume goes down with out being touched
may have a sticky button or a shorted transistor switch.
Jul 01, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Help setting the time on a JVC KD240 Car Stero
Hello dmay006,
Are you releasing the SEL button after the receiver enters the PSM mode? As soon as the display changes, you should release the SEL button and then use the "up" button to scroll to the "item". Each time you press the "up" button, the display should change. When it reads "CLOCK HOUR", use the volume control to adjust the setting. Press the "up" button once again to advance to "CLOCK MIN" and adjust it with the volume control. Press SEL briefly once again to exit the PSM mode. Once in PSM mode, if no other button has been pressed within about 3-5 seconds, the receiver will automatically cancel the PSM mode.
If you are following this procedure and the receiver will not let you into the PSM mode or let you switch from item to item with the "up" "down" buttons, then it is most likely defective and requires service or replacement.
Hope this helps.
Jun 13, 2009 | JVC KD-G140 Car CD Player
KDL-40XBR3 turns itself off; STANDBY light flashes 9 times
sony 52 inch tv in stand by mode comes on and off on its own
Jun 01, 2009 | Sony BRAVIA KDL-40XBR3 40 in. LCD HDTV
Sony Bravia turns off by itself
Replace the BU Mount pcb. Sometimes they are called the FB pcb.
Jan 08, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
