Files i transfered my old hard drive from my old computer and put it in a new computer but some of my files wont open
Save
Posted on Nov 09, 2008
May be some of the files got corrupted. or may be you are trying to open it in lower version of the softwares. check the files in some other system also. or try coping them again.
Posted on Apr 23, 2008
Need to transfer files from old computer to new Hitachi 3 terrabyte drive
The need to transfer files from one hard drive to another is common when restoring from backup, to make more room on a drive by archiving files or to copy or move files to a portable hard drive. Whether the destination drive is an installed second or third hard drive or is a portable hard drive, the procedure to transfer files from one hard drive to another remains the same.
Plug the destination hard drive into the computer if the drive is portable, and confirm that the computer has recognized the hard drive with a pop-up acknowledgment message. Click the "Start" button then click "Computer" or "My Computer," and then double-click on the icon of the hard drive that contains the files to be copied. When a window appears displaying the contents of the hard drive, navigate to the location of the files to be transferred. Click on each file to be transferred while holding down the "CTL" key to select all files to be copied. Right-click on one of the files that has been selected and click "Copy" in the menu that appears if you wish to leave a copy of the files on the hard drive, or click "Cut" in the menu that appears if you wish to move the files instead. Double-click on the icon of the destination hard drive in the "Computer" or "My Computer" window to display the contents of the hard drive in a new window. Navigate to the location on the hard drive where the files are to be saved. Double-click on the destination directory to open the directory and then right-click on blank space inside the directory window and click "Paste" on the menu that appears. A window will appear and display the status of the file transfer and disappear when the file transfer is completed. Hope this helps.
Jan 07, 2013 | Computers & Internet
Transfer your data over from the old hard drive to the new computer
The easiest way is to connect the old hard drive to an USB adapter case and make it an USB external hard drive. Connect this to the USB port on your new computer, the computer will see the external hard drive as an External storage device. You can then open the various folder on the hard drive and copy the files to your new computer.
You can delete all the unnecessary folders and files off the old hard drive and use it as a backup storage device.
Jul 31, 2012 | eMachines ET1161-05 PC Desktop
Just got new HP laptop and i'd like to transfer photo's and some files from my old HP desk top computer. What do I need to do this?
If the old computer still works, see the following. Otherwise look for the * for a solution further below. If the old desktop has Windows XP SP3 or newer, you can use the easy transfer wizard. It is included in Windows 7.
If the old desktop has a network connection, you can use an ethernet switch to create a network to share files. Once both computers recognize the switch, set up a network. If you have Windows 7 on one computer and do not have it on the other, do not use the Homegroup network. This may come up automatically; otherwise, use the Network Control Panel and add a network. Start the Easy Transfer Wizard and set this computer as the new computer. There may be an option to get the Transfer Wizard to copy and install to the old computer. Note the code for the Easy Transfer Wizard. Then install the Windows Easy Transfer Wizard on the old computer and launch it. Set this computer as the old computer. Use the code given in on the first computer to synch the transfer. Go through the settings to select the files to transfer and then start the transfer. Prepare to wait a while for the transfer.
If you can't use the Easy Transfer Wizard, set the hard drive on one computer to Share (click Computer (My Computer) and right click on the hard drive and select Properties. Then choose the Sharing tab. Enable Sharing by clicking the Share button.) On the other computer, map to a network drive and locate the Shared drive. Drag and drop the files to the new computer.
If you already have a network connection to a cable or DSL router, you will be asked about "New network found" and to define it. Make sure to make it the home network on both computers. (If you were directly connected to a cable or DSL modem, then you will again get this question. Note the switch will not let your computers talk to the outside network without a router though.)
(Alternatively, use a cross-over ethernet cable with the direct cable networking option.)
Other options: use the Microsoft Easy Transfer Wizard to put the photos and files on a DVD, external hard drive or flash drive with sufficient capacity. You may need to download and install this program to the old computer. For the optical drive option, you need a DVD-RW drive on the desktop and a DVD reader (minimum) on the laptop. (You can use an external optical drive, if you have one.) Another option is a USB file transfer device. Some of these come with the Easy Transfer Wizard on their install disc.
*If the old computer will not turn on, take the hard drive out of the computer and use a USB to IDE/SATA adapter. Follow the directions for the device and attach it to a USB port on the laptop. See if the drive mounts (is listed when you open the Computer File Explorer). Then drag and drop the files from one drive to another.
Note you may need to change the owner of the files on the new computer. (This doesn't apply with the Easy Transfer Wizard if the old user is made equivalent to the new user in the setup of the wizard.) To change the owner, right click on the file in the File Explorer and choose the Security tab. Select the Advanced settings.
I hope this helps.
Jun 30, 2012 | detto intellimover usb data migration kit...
I have downloaded the files from my old computer to the Seagate hard drive. How do I transfer those files to the new computer?
Copy, Paste. Just choose what files you want to copy over, and WHERE you want to store them.
If I were you I would create a new folder on the desktop, right-click an open space, new folder.
Then highlight all your old files, right-click, copy. Open the "new folder", right-click empty space, paste.
Mar 17, 2011 | Seagate 500GB FreeAgent GoFlex Hard Drive
I want to transfer data from my old computer to my new conputer using my Segate 500 GB back up drive. How do I do that?
First, you need to choose all the files you want to back up and put that into a folder then plug in your external harddrive click "my computer and double click your external hard drive and it will open another window. just drag all the folders that you want to backup and paste that to the new open windows which is your hard drive then thats it. just remove the external harddrive correctly and wait for the file to be complete transferred.
hope this helps. please rate my solution thanks.
Jan 12, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have a iomega eGo 500GB which I used on a dell laptop running Windows XP. I backed up all my files on the drive and now have a new laptop running Vista (old laptop has gone) put whan I pluged in the...
Enable "File and Print Sharing" on the "old" computer.
Connect the IOMEGA to the "old" computer.
Enable file-sharing on the "root" folder of the IOMEGA.
Connect the "old" computer to one of the LAN ports on a router (wired or wireless).
Connect the "new" computer to another LAN port on the same router.
Make sure that both computers are in the same "workgroup".
From the "new" computer, browse to "show computers in my workgroup".
You should see an icon for the "old" computer.
Double-click that icon to "open" that icon, and you should see all the files on the IOMEGA.
Copy those files to the 'C:' drive on the new computer.
Nov 11, 2010 | Iomega 250GB Ego Portable HD Red 250 GB...
I recently bought a Toshiba Satalite laptop to replace the one I dropped which was also a Toshiba Satalite. I had taken out the old hard drive and installed it in the new one but now it wont do anything...
Yes it does matter. XP was configured for the old Toshiba and this will only work if both Toshiba laptops are exactly the same model.
To get your new Toshiba operating, put the new hard drive with the Vista operating system back in the Toshiba laptop.
To transfer your data from the old hard drive, purchase a USB adapter hard drive case and place the old hard drive inside this case. This will then be an external USB hard drive.
Plug this USB hard drive into the new Toshiba's USB port and it will detect it as an external storage/hard drive. You can then open the various folders and files and copy the data files to your new Toshiba.
To free up disk space on this USB hard drive, delete the Windows folder, Program Files folder and other folders that are no longer needed.
Use this hard drive as a backup hard drive etc.
Sep 11, 2010 | Toshiba Computers & Internet
Can't transfer my email files from old computer to new computer
Good Day!
To transfer files from an old computer you can use USB or flash drives, copy the files from your Old Computer to Flash drive, after copying---attach the flash drive to your new computer then copy the files and save it. This is the easiest way to transfer files.
Other way of transferring;
-You can also transfer files by Burning your files into a CD/DVD and copy it to your new computer.
-Get your hard disk from the old computer and attached it to your new computer
-Or connect/network your two computers.
I recommend USB or Flash drives, the simplest and easy way.
Hope I was able to help.
Jul 16, 2010 | Microsoft Windows XP Professional for PC
I have windows vista just had a new hard drive installed the data off the old drive has been put onto an hdd caddy how do I load it back onto the new hard drive of my computer, the caddy is a plug in via a...
When you insert the usb cable from the caddy into a USB port on your notebook, Vista will automatically recognize it and open a dialog box. Choose to view files and folders.
Open another Window using Explorer and resize it so you can see the contents of your C: drive.
Then simply drag your files and folders from the caddy to the C: drive where you want them.
Remember that transferring program files will NOT help you as many of the files needed to run a program are located in other folders such as yours Windows directory. You will need to reinstall any software you wish to use.
This method is strictly for data transfer, as an example all your pictures, documents, spreadsheets, etc.
Sep 24, 2009 | Dell Studio 15 Laptop
Computers & Internet Logo
106 people viewed this question
David Payne
David Payne
