Question about Sony FD Trinitron WEGA KV-36XBR800 36" TV
SONY WEGA 36" TV, BLANK SCREEN NO SOUND
WHEN WE TURN ON THE TV IT SOUNDS AS IF IT WANT TO COME ON THEN THE RED LIGHT BLINKS AND IT GOES OFF
    Genius:
  • Sony Master
  • 1,689 Answers
Most commonly, the power supply, and or scan failure causes this. There may be some bad caps, in these areas. In the horizontal output area, the flyback and the horizontal output transistor may also be defective. There may also be some damage to the power supply in this case.
Jerry G.
Posted on Apr 19, 2008
My Sony wega tv won't turn on goes into standby red light blinks 10 times then shuts off?
Look at the owner manual as the 10 blinks is a error code or Google the model number to locate that information--Sony error codes are general and often misleading.
I would if looking at the set inspect the lamp first.
Aug 28, 2012 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a sony wega trinitron, when the tv is turned on, (no visual, or sound) the red stand by light blinks 7 times, and you hear the tv click off? Please help
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Jun 06, 2011 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Attempted to turn the tv on, screen stayed blank with no volume either and standby light blinks 16 times.
High voltage is dead,FBT,flyback transformer the cause.The big block of plastic with a red wire with a cap hook to a CRT(tv tube).
Nov 04, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Apr 10, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
SONY GRAND WEGA KF-50WE610 can't turn on TV screen.
Ths 5 blinks usually indicate an AKB problem. There is a break in the video path. I'll look up your specific model and post the results here. Please update this if you wish to attempt the repair yourself.
Thanks,
Dan
Mar 19, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony wega kv-36hs20 will not turn on
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Mar 02, 2009 | Sony FD Trinitron WEGA KV-36HS20 36" TV
Sony wega trinitron won't turn on
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • and some times the eprom ic is fulty ...
  • try to unplug your tv from the main power for 5 hours then press the power button and keep pressing for 7 seconds then release ,if this do not work ,you should take your tv to a qualified person
  • i hope this helps ..
  • Jan 01, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
    Sony Wega Rear Projection TV, Red light flasing
    I had the same problem, it because of heat buildup, and the inside is fried, you need repair
    Jan 02, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
    SONY 36 XBR SOUND BUT NO PICTURE
    posible solution is adjust the screen to low.also check the trimer if it is working.check the resistor in the heater line...weng
    Oct 30, 2007 | Sony FD Trinitron WEGA KV-20FS120 20" TV
    Sony FD Trinitron WEGA KV-36XBR800 36" TV Logo
    74 people viewed this question
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
