Question about Toshiba TheaterWide 62HM84 62" Rear Projection HDTV-Ready Television
Power went out in home now tv wont turn on. Looks
Power went out in home now tv wont turn on. Looks like it might be the ballast. Can i replace on my own? How do I find one?
  • Toshiba Master
  • 8,457 Answers
U hear alot of clicking,when the power is turn?Yes,the ballast board is dead.Yes,tries Partstore.com,Ebay.com to buy one.
Posted on Jul 10, 2010
How to fix 3 flashing lights?
Look for a thermistor near the lamp and ballast
Aug 22, 2015 | Samsung HLS6186W
I recently replaced the lamp - part # 915P061010. But the TV powers off about every 20 - 30 minutes / red status lamp is illuminated. At times the TV will remain on for hours. But eventually the TV...
It looks like your ballast board is going bad, this is a common problem for DLP TV's the ballast board is the power source to the lamp and if for any reason this board does not send enough energy to the lamp it will turn off, It looks like your ballast it starting to get weak it gathers enough energy to turn on but gets weak again and turn back off you have a new lamp and it requires for the ballast to be working at it's full potential
Sep 13, 2010 | Mitsubishi WD-57734 57" HDTV
When I power up the TV, the fan turns on and I get the green blinking timer light as usual. Once the light turns off I manually boot the TV with the bypass switch and hear the second fan start up but the...
I would suggest it is a ballast problem. You can check supply of 5 volts to ballast's small 5 pin connector (trigger voltage) and about 300V-330V to large 2pin connector. If both voltages present at the start and lamp is working with in another TV - it is bad ballast.
Aug 11, 2010 | Mitsubishi WD-62725 62" Rear Projection...
Lamp doesnt look blown but lamp light flashing n tv wont turn on
Check the Lamp Fan if it is defective Lamp will try to light but will shut off, And the Ballast board is what turns Lamp on, For Part number o to Encompass parts distrubtion and type in your model they should list the ballast board and PN Then go to Ebay Look under Electronics type in PN, I got mine for $65.00
Lamp for $85.00
Jun 27, 2010 | Panasonic PT-45LC12 45" Rear Projection...
I have my tv KDS-R60XBR1 projection tv from sony. the problem is the tv is not turn on. led red flashing and turn off. no picture and sound. I replace the lamp, but it still doesn't work. Please give me...
WELL IF YOU JUST RECENTLY REPLACED THE LAMP AND THE TV STILL WONT TURN ON THE PROBLEM IS GOING TO BE COMING FROM THE BALLAST BOARD IT LOOKS LIKE IT'S NOT SENDING THE CORRECT AMOUNT OF VOLTAGE TO THE LAMP SO IT COULD TURN THIS IS THE POWER SOURCE FOR THE LAMP IF THIS PART IS NOT OK THEN THE LAMP WILL NEVER TURN ON
http://www.discount-merchant.com/how-dlp-works-like-magic-a/141.html?click=48428
Dec 11, 2009 | Sony Televison & Video
New lamp turns on flashes 7 times
Just a thought...you *might* have a bad ballast in addition to that defective power supply.That flashing could be the ballast trying to ignite the lamp. A lamp is just like an enclosed welder's arc. The ballast generates a high-voltage spark to initially start the lamp, then low voltage with high current keeps it burning. If you look into the lens and see "lightning" flashes but no lamp ignition, that's what's happening. The ballast could've been damaged by the defective supply. Also, try a known-good lamp...just to rule out a defective new one--in the shop, we kept all old working lamps as testers.
Aug 30, 2009 | Sony XL-2100U Projector Lamp for...
I just bought a new lamp for my samsung tv because the tv just want black,I JUST REPLACE THE LAMP a year ago to the date, i went to the store and just install it and it still does not turn on? so i called...
Steve The part you are inquiring about is called the ballast, It is a small (say 3" x 8" ) circuit board that attatches directly to the bulb via the two pronged leads coming off the bulb. On this set you'll have to take the back off to get to it. Once you do, you'll see it right infront of the optics block, just a couple screws will loosen it. There is a white and black power line and a sleeved reciever line connected to it. Get the model number off your ballast and go to shopjimmy.com rivervalleyelectronics.net or ebay and replace. If I remember correctly. There are several compatible ballasts for this set. Rule of thumb though, is that just because it looks the same doesn't mean it is. Call samsung, they will also sell you the newest, latest and greatest ballast. You can just ask them for a part number too and then shop around. Good luck.
May 10, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Pt456c12 wont come on blinks green at the on off light
Good Day, teagues;
It sounds like a bad lamp. Lamps normally have a 5,000-hour life. Looking at the lamp can tell you if it’s bad if it looks burnt, but not always. Your Panasonic TV is also known for having failure of the ballast, which turns the lamp on. 95% of the time it’s the lamp, trouble shooting the ballast is a little more challenging.
The lamp replacement is a very simple process; instructions are in the TV’s owner’s manual. Call the factory, they will send you the lamp to your home with complete detailed instructions.
Good Luck, Big Irish.
Jun 17, 2008 | Panasonic PT-45LC12 45" Rear Projection...
Replaced lamp still not working
Power issues (Tv True True (``````````` (``````````` 0 95250 95250 clip_image002.gif not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung True True (``````````` (``````````` 0 95250 95250 clip_image002.gif is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Jan 16, 2008 | Samsung HLN5065W 50" Rear Projection...
Samsung HLS4266W 43" dlp
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Toshiba TheaterWide 62HM84 62" Rear Projection HDTV-Ready Television Logo
177 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
