Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuum runs but does not pick up dirt
Beater bar turns; it appears the air in the tube is moving, but vacuum does not pick up anything
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 105 Answers
Have you cleaned the washable filter. Perhaps your cyclones are clogged. you can clean the cyclones yourself. check out this video http://www.youtube.com/watch?v=2OO3ugkyzxk
Posted on Jul 10, 2010
Y Shark "Professional" model 540 26 is making a terribly loud noise and not picking up dirt. t also gets HOT
Check( 'beater bar',suction tube to canister) for accumulation of hair,carpet fiber,pet hair,etc....cut hair,etc,with scissors,clean...might also be hair stuck in belt that drives beater bar
May 08, 2017 | Shark Vacuums
I have an Eureka Altima Model 2961AVZ vacuum that suddenly stopped picking up. I have taken it apart, checked the belt which was fine, replaced the hepa filter, and checked for clogs in all the hoses
Is the beater bar actually turning when the power is turned on? Sometimes the belt is fine, but something is jammed and keeping the beater bar from turning. What about the section behind the beater bar, but before the hose upright. I've found large pieces of paper jammed in here and then hair gets caught, ultimately blocking the whole system. Usually you have to turn it over, remove some screws and disconnect the belt and beater bar to get underneath. Just reassemble it in the reverse order to how you took it apart. Double check the hoses and run a "unwound" metal coat hanger through to unclog anything. Does the vacuum " suck" with the hose or tube up to it disconnected? If not you may have a motor that somehow got junk pulled into it. You can open this up as well and clean this out. Of course unplug it all before doing anything.
Nov 03, 2014 | Vacuums
Why won't brushes move on Commercial Carpet Pro Vacuum Cleaner
Luvumuch48tj:
Unplug the vacuum and lay it upside down on some newspaper. Remove the sole plate (bottom plate) with a screwdriver. Pull straight up on the brushes (called a beater bar) and remove the beater bar and belt. Remove the end caps and bearings from the ends of the beater bar (it may take a 2-grunt pull, or CAREFULLY pry the end caps and bearings from the beater bar with a screwdriver) Don't stab your hand with the screwdriver... That HURTS! Once you have the bearings and end caps off, remove the hair, carpet fibers and other gunk from the ends of the beater bar, end caps and bearings. Dribble a little rubbing alcohol on the bearings in the end caps and spin the bearings to clean them... keep dribbling alcohol in the bearings until the alcohol draining from the bearings is clear. Dry the bearings until there is no alcohol in them. Now would be a good time to check the opening in the vacuum head and the hose going into the body of the vacuum for clogs. Reinstall the bearings and end caps on the beater bar and reinstall the beater bar with a new belt in the machine. Reinstall the sole plate. Your machine should run like new.
Feb 15, 2013 | Carpet Pro CPU-2T Commercial Upright...
I inherited this vacuum from my mother but I don't have the manual. I have 2 belts for it, but I don't know where they go. I can turn it on and it seems to work, but the bag doesn't fill up...
Most vacuum uses one belt at a time. The belt connects the agitator (beater bar) to the roller which is driven by the motor of the vacuum in the base of the upright vacuum.
To check if the belt is present/intact on the vacuum, look at the sides of the base for two latches. Push the latches away from each other then lift up to remove the cover so that you can check or replace the belt. To replace the belt, lift the agitator out of the base (first lift the right side). Cut off the old belt with scissors if it is still intact before pulling on the agitator. You may need to pull the bumper forward to get the beater bar out of the base. To put on the new belt, slide it onto the roller of the motor then onto the pulley of the agitator. Replace the beater bar in the housing. Start with the left end cap and make sure to keep the arrow pointing down on both sides of the part. Make sure that the agitator turns and center the belt before reattaching the cover.
While you have cover off, check for anything wrapped around the agitator. Remove anything that prevents the beater bar from turning freely. Make sure the area around the agitator is clear of any clogs.
However, if the belt is missing, the volume of dirt picked up will be less but not zero. It is more likely that the unit is clogged. There are several filters that need regular cleaning or replacement. The motor filter is at the bottom of the vacuum bag cavity. It should be cleaned with warm soapy water then rinsed completely. Squeeze out the excess water and then let it air dry. Wait until it is dry before reassembling the vacuum.
An exhaust filter also needs regular cleaning. This is behind the dust cover near the bottom of the area covered by the cover. To remove the dust cover, pull forward and then lay it down. To clean, put the filter under cold running water. Then air dry completely before reassembling the vacuum cleaner.
Finally check if the hose is clogged. First remove the hose by grasping it near the base and twisting it as you pull it away from the vacuum. Pull the hose completely straight then plug in and turn on your vacuum. Stretch out the hose and then let it relax into its storage configuration. Turn off the vacuum and then unplug it. Check for and remove any clumps of dirt stuck in the hose before replacing the hose.
If you have cleaned the vacuum and it is still not picking up dirt, try a different pile height setting on the vacuum. Also check if the agitator should be replaced.
Manage My Life has the manual for the vacuum here: http://www.managemylife.com/mmh/owner_manuals/15123/KENMORE-Vacuum-Upright-L0807740?brand_name_search=33078 . This manual gives the pictures of the various parts that need to be cleaned or replaced regularly. Sears Parts Direct has some parts for the unit; see http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Vacuum-Parts/Model-72136078600/0582/0645000?sid=PDVertical .
I hope this helps.
Aug 03, 2011 | Kenmore 33078 Bagged Upright Vacuum
My vacum will not pick up, it is spitting the dirt out?
Check for blockage.
Most likely place is in the tube leading up from behind the beater bar. While unplugged, remove beater bar & belt & check.
If you have a strong shop vac, remove beater bar, belt, and bag, applying suction to the tube in back of the beater bar will many times dislodge the clog with little effort, sometimes though it will take some fishing around with a stiff piece of coathanger wire or similar.
Normally when you can apply suction with the shop vac to the tube in back of the beater bar & feel suction at the tube were the bag connects, you know you've got it all and you should be unclogged. Put it back together and you should be ready to roll.
Feb 11, 2011 | Hoover Tempo Widepath Upright Vacuum -...
I have a Hoover Turbo EmPower 4600 and the roller will not turn when we turn on the vacuum. The vacuum is fairly new, and hasn't seen too much use, but now the roller won't turn, so it's not picking...
The beater belt is broken. There are 4 phillips head screws on the outside (2 on top of the base on either side of the upright, and 2 on the front edge on the underside of the base near front edge). and 4 phillips head screws on the inside (holding the guard cover over the beater bar). The belt is about $3 (part number 38528040). Take out the beater bar and put the new belt around it. Then put the other end around the metal bar and stretch the belt taut as you position the beater bar back into its channel slots. Replace the guard and top cover and you should be good to go...
Jan 23, 2010 | Hoover Vacuums
No suction...bag about half full. I have no
The brush may be spinning, but you probably need to replace the belt2_bing.gif because it is stretched. It is probably slipping on the beater bar..
Jim
Dec 03, 2009 | Riccar 8955 Upright Vacuum
Vacuum won't pick up any dirt - there's no roller marks when vacuuming carpet. Roller does turn and filters are clean.
When you turn the roller, you should feel some resistance from the belt. Remove the base blate that surrounds the beater bar. Check the belt. Take care in removing the beater bar, so you can get it back in the same way it comes out. Clean the beater bar while you have the bottom open. If you remove the beater bar to replace the belt, take the time to inspect the cavity behind the beater bar where the vacuum picks up. That is where vacuums usually stop up. Reassemble the vacuum. If necessary, slip the belt over the motor shaft and then slide the roller undre the belt. Install the beater bar back in the sockets and replace the base plate.
Best regards,
--W/D--
Aug 12, 2009 | Dyson DC14 Bagless Upright Cyclonic Vacuum
My dyson animal is hard to push on carpet - the beater bar is still operational. When I turn off the beater bar and run the vacuum on hardwood the beater bar stops moving, but it still ''rolls'' on the...
If suction is not what it was, check all of your hoses and connections for vacuum leaks. And the beater roll should always be turning - check out the belt for slippage.
Sep 20, 2017 | Dyson DC17 Animal Bagless Upright Cyclonic...
Can't lower beater bar - so won't pick up lint
the small tube under the hover goes stiff and the beater bar wont go lower enough so youve got to get small tube under hover soft and than set beaterbar to the ground let it go hard and may solve your problem many thanks nick...
Nov 15, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
408 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
