Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
We just up graded the pump and have the salt water system hooked to it for days now the the water is a light green color It looks clean not algae green Could it be to much salt or not enough? When I test it the test strips says it normal
    Problem Solver:
  • 8 Answers
Did you have to put more water in than usuall before you noticed the green? If you filled the pool with well water it could be iron in the water (which gives you a clear green look). If thats the problem then next time run the hose into the skimmer or into the filter pump suction. That way the fill water will be filtered before going into the pool. If it is iron in your pool and you shock the pool it will turn brown.
Posted on Aug 15, 2010
Getting same green film on top of water that is the same color green as the copper piece in the salt water pump has turned
The two green colors may be associated somehow but when you say anything about green water I think it is more likely the water is turning green from algae. The best way to rule this out is to test the chlorine level and then shock with vinyl shock to about 10 ppm. If it is algae then the it may be cloudy but should turn more blue rather than green. If other chemistry is good such as salt concentration and stabilizer then running the pump, filter and chlorinator according to the Intex manual. When a pool is shocked the filter can get dirty quickly and then reduce the flow. For this reason make sure you clean the filter. I hope this helps.
Please vote on this answer. Thank you.
Aug 26, 2011 | Intex Automatic Salt Water System for ...
My pool is nasty green...waiting for intex saltwater unit to arrive. Do I need to drain pool before and put clean water in before I begin running this new pump?
I would start with a fresh clean pool if it's that nasty green!!! Drain and scrub all algae..
Did you already buy your salt?? Remember.. you will need to add your salt and run the pump without the chlorinator for 24 hrs to properly dissolve the salt.. If your not sure how much salt to buy, post again how many gallons your pool is and how much salt will you need and you should get an answer from one of us... Good luck....
Aug 20, 2011 | Intex Automatic Salt Water System for ...
Two weekends ago I came back from a 4 day trip to a green stincky pool. Low flow, we cleaned the filter and scrubbed the algae, by morning a beautiful sight. Yesterday after not look at the pool over the...
You should definitely shock however the best solution for solving an algae problem, which is what you have, is using a product called
Algimycin 2000
this will clear up your pool in about 24 hours
US Parts Center
Aug 18, 2011 | Intex Automatic Salt Water System for ...
My husband converted our 27 x 52 round above ground pool over to saltwater two weeks ago and we have yet to be able to get in it to swim. We drained all 18,700 gallons, scrubbed the liner and refilled the...
Wrinkles in your pool liner wall is a slight problem and can be a place for algae to grow, BUT can be treated and cleaned.. Algae will appear if your not providing the correct amount chlorine, regardless of wrinkles or not.. Let me tell you how I take care of my 14,500 gallon 18' X 33' X 48" pool using only the 8110 Intex model and hope you can apply some of my techniques to your pool and system...
In the 2 years I've own my system, I have not added any chlorine, even for those times my system failed and water turned green.. Yes.. I could have bought SHOCK and CHLORINE and added to my pool to kill the algae, but chose to vacuum, brush and set my chlorinator to max and did it without buying any of these expensive chemicals.. It took over 3 days to finally see results after running my system at at 12 to 14 hrs pump and 10 to 12 hrs chlorination.. After my pool cleared and chlorine level was at optimal, I lowered my chlorination to around 6 to 8 hrs.. Right now that the temperature is around 95 degrees, I run the pump for 12 hrs and chlorinate for 10.. My chlorine level is slight low and today I plan to raise my chlorination to 11 hours.. My pool water right now is crystal clear and clean. I vacuum my pool daily and check the electrolytic cell weekly for optimal results..
Now...you have a huge above ground pool, almost 19,000 gallons!!! To start.. you should have added almost 500 lbs of salt!!! and ran the pump only for over 24 hrs to properly dissolve the salt..
Next, you should test the water salt concentration level and should have been between 2000 and 3000 ppm. After the proper level and because your pool is so big, run your pump at 12 hrs or longer and possible 10 to 12 hrs chlorination...
You said the manual vacuum sucks up the liner??? They sell a nifty device that hooks up at the end of the hose and attaches at the skimmer inlet that has a relief spring activated door that prevents sucking up the liner and also, you may to look for a different vacuum head???
Bottom line... NO, the only way to clean the algae is NOT with vacuum and brush only..It could be done with SHOCK and CHLORINE.. I chose not to add shock and chlorine to mine.. But you will need to vacuum the dead algae and clean you filter several times..One more thing... I hope your chlorinator is big enough for your size pool.. The max gallons the manual shows is for a 14500 gallons, like mine... Good luck and hope this info helps...
Aug 14, 2011 | Intex Automatic Salt Water System for ...
Problem is test strips indicate high copper ion (pink) and total alkalinity is low (light tan) Free chlorine is ok (between 0.5 and 1) and ph is good. We have this greenish silt like stuff on the bottom...
1st.. Clean the green (algae) stuff out..
2nd. Clean the filter...
3rd.. Repeat step 1 and 2 until most all the algae is removed..
4rd.. Brush you pool with a pool brush to remove the remaning algae...
5th.. Seems like you have the right chlorine level but not running your filter long enough??? After all steps are completed, run you filter at 8 hrs and your chlorinator between 3 to 6 hrs until your pool clears up.. After that, vacuum again and clean your filter... During the summer months, 4hrs is not enough circulation.. Hope this works for you and good luck.. Please take the time to write a comment if this works for you...Thanks..
Aug 07, 2011 | Intex Automatic Salt Water System for ...
Hi I have ab 18x52' intex above ground pool with klear saltwater system, but I have algae in the bottom of the pool, please tell what to do to clean it without emptying the pool, and can i use any...
Get ready for a full weekend of cleaning your pool :) This is the chemical free method...
1st... Start with a clean filter...So clean your filter...
2nd.. Vacuum your pool and get most of the algae up from the bottom and sides.. Go slow so you do not stir up the algae. Make sure you use the vacuum attachment with brushes..
3rd..Clean your filter...
4th...repeat step 2 again...
5th... Clean your filter...
6th... Brush your pool with a pool brush to loosen the remaining algae..
7th... Set your pump timer for 12 hrs and your chlorinator for 10 to 11 of those hrs... and run for 3 days...
8th.. Check your water and see if has cleared and the algae is almost completely gone.. If so, check your free chlorine level and adjust your cycle down if at the required level..
9th.. if your chlorine level is not at optimal, run at the 12 hr cycle for 3 more days and check..
10th.. After water is clear and free of algae, clean your filter and adjust your cycle down to control your free chlorine level...
Good luck and hope this method works for you.. It has for me for over 2 years with my Intex Salt Water system...
Please take the time to rate me and write a comment... really appreciate!!!
Aug 03, 2011 | Intex Automatic Salt Water System for ...
Recently installed Intex saltwater system, all of a sudden, have green forming around walls of pool. All levels look okay; except chlorine is a little low and PH is very high...I ran the boost cycle last...
Once you get the "Green" stuff on the walls, you must brush it off.. and one boost cycle will not do.... Make sure you have the correct salt level!!! Keep in mind..big pools can take up to 350 lbs of salt... Now...set you pump at 12 hrs and you chlorinator at 10 hrs between those 12 hrs.. Run this cycle and you should see results within 2 to 3 days... Clean you filter and rinse your electrolytic cell after 3 days because you will have dead algae. After the water turns clear, you can then lower your cycle to 10 pump and 8 chlorinate.. Good luck! hope this helps!
Jul 19, 2011 | Intex Automatic Salt Water System for ...
We changed our pool over to salt water four days ago ago and it is cloudy and has green algae in it. It had green algae when we switched. We thought the salt water system would kill it, but it is still...
You don't mention the size of the pool. If this is a above ground small pool ... dump the water, clean the liner and refill it. Remove the metal with a sequestering agent. Get the alkalinity correct. Get the pH correct then add the salt to 3200 ppm.
Chlorine kills algae. Are you sure it is algae and not metal in the water?
pH should be 7.2 to 7.6. Alkalinity should be 100. If a gunnite pool, the calcium should be 300. Salt should be 3200. Cyanuratic acid should be 50+ if this pool is outside (not indoors).
What to do. If this is a big pool, and you are sure this is not metal in the water, I would super chlorinate the pool - take it to 20 or so ppm. Run the filter for at least 24 hours. Watch the pressure ... you will be filtering out a lot of stuff.
Let me know what happens ...
Thanks for your question @ FixYa.com
May 24, 2011 | Intex Automatic Salt Water System for ...
I have a 16x32 dished out pool; average depth 5.5ft
First of all to answer your question. Yes the intex generator will work with a 16x36
Where do you get an average of 5.5ft when you say the pool is 36" deep
Well now the bad news. A salt water system will not solve your algae problems
Algae comes from wrong pool maintainence
You must now with a green pool shock your pool with 1 gallon of chlorine and now with a pool brush brush the sides and bottom now wait 4 hours for things to settle.
now vaccum clean cartridge if applicable or back flush your sand filter
wait 24 hours and brush again.
Continue to do this until it starts to clear watch your chlorine level and if it starts to get low shock again until the green goes away.
You will also need to buy an algacide, non foaming and follow the directions usually 14-24 ounces per 10,000 gallons of water
also put a stabilizer in your pool to help maintain your chlorine level. It will still drop but not as fast
one of the main contributing factors to a green pool or lack of sanitizer ( chlorine ) is # of bathers,sun,heat,sun
tan oils, and even the most common problem Lack of use.
The water needs to be constantly moving to help prevent algae. If you do not use it for a few days or so then brush it even if you do not see algae Guarantee if you go in the pool a few days later after not using it for a bit you would feel the slipperyness HMMMMMM is that a word anyway you would feel it
Another thing to consider is to filter filter filter
unless you have a 4000 gl ph pump you can not get enough filtering with an intex pump.
a pool should be turned over at least 3 times a day this means if you have lets say a 5000gallon pool and a 2000 gl ph filter you will need to filter at least 7.5 hours and that is at the low end
An intex pump pulls about as much energy as a 40 watt light bulb I have aintex 2500gl ph pump with a 7000gl pool I run my filter 24/7
Bottom line is you do not need a salt system that is just one more so to speak chemical to maintain at a certain level
Stick with getting your chemicals right and your problems will go away if you have any more questions or something specific just e-mail me
Jun 20, 2010 | Intex Automatic Salt Water System for ...
Why did my pool turn green shortly after start up?
The question is what the green is... If you see the presence of Algae in the pool, then you need to treat for removal of Algae. This can be prevented in the future by keeping your Chlorine level at or above 1 part per million. If your water color is a green tint but no algae present, you may have a high copper content in the water or some other mineral present. You will need to use a Metal out product soon to prevent staining, especially if your pool is plaster. If you have a pool heater, make sure the chlor gen was installed in the plumbing AFTER the heater. Seek professional assistance from a local pool professional with salt system experience if you are unable to resolve this to prevent system wide complications.
Apr 14, 2010 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
519 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
