Question about Philips DIRECTV H20 DTV Receiver
H20 Reciver power up problems
I bought a used H20 Directv reciever. I plug it in and after a few minutes the resolution lights start scrolling. I understand this is part of the usual startup but the lights never stop scrolling. I can't get a light on the power button and the unit will not turn on. Anyone have an idea?
  • 1 more comment
  • atxz06 May 02, 2008
    identical problem. it shows "Receiver is booting" then "Just a few more seconds", then resolution light cycles.
  • Anonymous Aug 10, 2008
    same problem -- no solution in sight!
    Direct TV customer support told me to get a new HDMI cable but it didn't work.
  • dave barnes Sep 02, 2008
    I'm having the same problem. Was working fine until a couple weeks ago and then started being flakey and then around the 24'th of August it only has the resolution lights rolling through. Nothing to the screen. Did Directv send some type of update that killed these?
Same problem on two different h20 receivers - called directv and explained the situation each time. since these are leased receivers, new ones on the way.
Posted on Sep 21, 2008
Direct tv reciever keeps flashing when plugged in.
Probably a power supply problem. Have you tried switching off at the mains for a few minutes?
Mar 25, 2014 | Directv D11 DTV Receiver
Reciever says it has new software to download but cannot download making my reciver not work at all how can I get it to download the software
reset the reciever by pressing the red button behind the panel on the front, as soon as you see letters on the screen during the start up process press 0,2,4,6,8 on your remote and that will force the download
Dec 24, 2010 | Directv D10 DTV Receiver
I have a STR AV1020 receiver. If I leave the power cable plugged in, even if the system is off, there is an issue. When I power on the receiver, all lights come on and stay on. Sometimes playing with the...
Hello i have a Sony str-av 1020 reciver. But reciver is burned power supply transformer. At the transformer walks around 125 v, but i don't know how much Current transformer on the other side is, and i don't know what transformer i have to buy? Please help. I would be very grateful!
Mar 08, 2010 | Sony Audio Players & Recorders
Have green lights but no pic...also unit very hot
those units are known to go out after not long at all try doing a front panel reset by pushing the red button where the access card is you may have to do it several times to see if it will finally come up if not your looking at buying a new receiver
Aug 15, 2009 | Philips DIRECTV H20 DTV Receiver
Guitar hero world tour, Ps3, when the wireless reciever is plugged in the guitar shows two lights on the strum bar...the ps button works and the controller allows me to quit the game/shut down system etc...
It seems that the recent PS3 Firmware update (2.80) reassigns your controllers. In order to fix this (I just did it 20 minutes ago and all is fine) is:
Go to the XMB "Settings" Menu.
Open "Accessory Settings"
Using the controller you want to reassign, open "Reassign Controllers"
Scroll to the number you want that controller to be (1,2,3 or 4)
You are good to go!
Thanks to the Phone Help at Activision for this fix!
Jul 31, 2009 | Activision Guitar Hero
I have 15 bad direct tv reciver h20 h21-200 does not powerup
If you are not getting any power to the box, then the power supply may need to be changed.
Jul 10, 2009 | Samsung SIR-TS160 DirecTV DTV Receiver
Direct Tv Receiver No sound Black Screen
unplug the power from the reciever for a few moments. plug it back in and let it load. once its finished turn to channel 201. Usually it the reciever is on an unavailable channel (channel with no programming) when it restarted it will go back to that unavailable channel hince the black screen and no sound.
Jan 01, 2009 | Philips DIRECTV H20 DTV Receiver
HDMI interface issues
If you swapped directv receivers and the problem followed to a different tv then there is something wrong with the directv receiver. Need to run satellite setup again on this receiver to fix. repeat satellite setup is accessible through the setup submenu by pressing menu from the directv remote. look under satellite submenu once in setup
Dec 23, 2008 | JVC HD-52Z575 52" Rear Projection...
Directv H20 Receiver won't power up
You have a faulty power supply in the receiver.It has to be repaired,it seems to be a common problem
Dec 22, 2008 | Philips DIRECTV H20 DTV Receiver
Sound problems
Make sure it is not a problem with the DTV reciever first by connecting up another smaller TV set to that reciver. if it is the TV set for sure, a cheap fix would be to run the audio outputs of the DTV reciever to a small stereo or a powered speaker. Good Luck
Mar 23, 2007 | Sharp 27H-S60 TV
Philips DIRECTV H20 DTV Receiver Logo
790 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
