I need to install my compaq ij200 to my computer. i have windows xp and i do not have the disk it came with to install it.
    President:
  • 2,712 Answers
Hello davisss12,
You can download the driver from HERE.
Although it is for Windows 98, it should work with XP as well...
Or else, you can register for free with Driver Guide and download the driver for XP from there. Registering is simple and easy, and you will be able to access a huge database of up to date drivers as well. Once you have registered for free, click HERE to go to the download page. The file is about 1.6MB.
Lexmark1100_CJXP1100SE.exe is the name of the file.This is the printer driver for Compaq printer IJ200 to work with Windows XP.
Should you have any further questions, please feel free to post them here. Please do not assign a rating until you feel your problem is resolved. I will try my best to help you further if need be.
If you are satisfied with my solution or have no other questions, please close the problem by assigning a FIXYA rating for my solution. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Apr 19, 2008
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    If you find that the solution/answer I provided led you
    to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
    rating under my solution.
    post them here.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    IrishDruid
    Genius:
  • 1,027 Answers
If you don't mind fooling XP.
Use the Lexmark 1100 driver. (same model as ij200)
Windowss xp professional reboot disk
http://windows-xp-pro-startup-disk.soft32.com/
Bootable disk for XP Professional.
The Windows XP start up disk allows computers without a bootable CD-ROM to perform a new installation of the operating system.
Apr 21, 2013 | HP Compaq Evo D310 PC Desktop
Formatted hard drive need drivers to install windows xp pro
here is what you need:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=3245634
Feb 17, 2011 | HP Compaq Presario C304NR Notebook
How can i install windows xp when screen showing blue screen
Check whether you have installed the SATA Hard Drive driver using a Floppy disk. Some Computers needs SATA Hard Drive Driver before installing the Windows XP. Try using Windows XP SP2 disk.
Jul 01, 2010 | Compaq Presario 700 470024-192 Notebook
Can't install xp in compaq laptop
you mean you need to downgrade your computer from Windows Vista to XP?
if so is the case, you need to go to the BIOS in the Boot menu, select IDE from ACPI.
put the boot option to boot from CD first or disable Boot from hard disk.
then you will be able to downgrade your computer from Vista to XP.
Jun 07, 2010 | Compaq Computers & Internet
How to install windows xp into compaq presario cq40
compaq cq40 is one particular model from compaq which is literally designed for vista and when you want to install win xp ;it doesn't work becoz the BIOS block it;the only way out is to downgrade the system BIOS which is a risky thing.check your bios model and version and google for a lower version and download it and flash the ealier BIOS.gooogle more on How to downgrade BIOS
Sep 21, 2009 | HP Compaq Presario CQ50Z-AMD Sempron(TM)...
How to install windows xp sp2 on compaq v3239tu
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
Mar 14, 2009 | HP 417068-001 Compaq Presario V3000...
I couldn't install windows xp in Compaq cq45 112au
Try using an win 98 startup disk on floppy and start your computer with disk in.Let it finish loading the drivers and then type in fdisk erase your partition and then make a new one. then restart the computer with floppy still in then this time type in format c:/ and format the drive after it is done then you can install win xp.But you need to repartition your hard drive and then format after that to get xp to install Oh yeah when you go to fdisk allow large drive usage
Jan 25, 2009 | Computers & Internet
Hard disk not recognized when reinstalling xp
try formating the drive using fdisk in fat32, you can find this program in windows 98/98se and Me them try instaling windows xp
Nov 10, 2007 | Compaq Pentium 4 , 1.5 GHz (244318-B21)...
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
