Teach me how to clean the inkjet head. - Office Equipment & Supplies
    Brigadier General:
  • 7,191 Answers
Please elaborate your problem providing us with more details of the problem.
Thanks
Posted on Jul 28, 2010
I have replaced the print heads, and instead of printing red, which I made, it is printing black
DEAR FRIENDS; PLS DO THIS FIRST STEP FIRST
How to print nozzle check pattern iPF6100/iPF610/iPF710/iPF8000S/iPF9000S/iPF800/iPF9100
  1. Load unused paper.
  2. Press the Menu button to display MAIN MENU .
  3. Press or to select Test Print , and then press the button.
  4. Press or to select Nozzle Check , and then press the button.
  5. Press or to select Yes , and then press the OK button.The printer goes online and prints a test pattern.
Second later print out result pls compare you result print with my attachment picture.
replaced-print-heads-instead-printing-5j51azquscxy1hu2enwrxd50-4-1.jpg let say if anything color no same like example red = black,yellow = yellow black , cyan = dark or magenta = green.
this means got dirty on site purge unit and printhead unit. you need to call canon technician done services for you because i can't teach you how to clean the purge unit and print head unit scared you will spoil this both unit.
Hope can help you ,TQVM..
Apr 13, 2016 | Canon IMAGEPROGRAF IPF8000 InkJet Plotter...
Blocked print head
INK PROBLEM
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head. You maybe lucky with this -
INKJET PRINT HEAD CLEANING FLUID
http://www.pcx.com.au/ProductDetail.aspx?ProductId=1099 http://www.amazon.co.uk/PRINTER-CLEANING-RECOVERY-FLUID-100ML/dp/B001EN9W2Y
Mar 17, 2013 | Epson Stylus Pro 4800 InkJet Printer
I would like to put the cleaning process through, as i hav'nt used it for 6 months. epson stylus TX710W.
The print head clean maintenance is usually located in the printer Properties.
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Aug 26, 2011 | Epson Stylus Photo R800 InkJet Printer
Is their anyway to unclog the blk ink. Can it be done or do I need to get another printer.
It is impossible to clear blocked print heads. You can purchase a new print head, but they are expensive, sometimes it cost a little more to get a new and better printer.
Jan 23, 2011 | Brother MFC295CNAll-In-One InkJet Printer
Printer has ink and is hooked up correctly to the best of my knowledge. sheet goes in as if it's printing but comes out blank
did you try head cleaning on the printer maintenance,probably the print head is already clog if you can buy a chemical solution for print head in your area then buy it,just contact me if you have it and i will teach how.
Sep 10, 2009 | Office Equipment & Supplies
One color doesnt print
If you have a non-HP inkjet printer. The cheapest thing to do is to found a set of spent cartridges and drill 2 small holes on each. Fill them with alcohol or ink cartridge cleaner. Then you can clean the head as much as you want for free. You may need to reset the chip on some printers.
The problem is the color head cleaning on almost all cheap inkjet printers is done by creating a vacuum over the color head. It would **** all the ink out of the head regardless of the color.
Sep 02, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
I need to clear the inkjet heads on my Epson Stylus R220.
Follow the steps below to clean the print head using the Head Cleaning utility.
Make sure that the printer is turned on and the ink out light is off. Access the printer software. Click the Maintenance tab, then click the Head Cleaning button. Follow the on-screen instructions. The power light flashes while the printer performs the cleaning cycle. Never turn off the printer while the power light is flashing. Doing so may damage the printer. When the power light stops flashing, load a few sheets of paper and click Print Nozzle Check Pattern in the Head Cleaning dialog box to confirm that the print head is clean.
Apr 21, 2009 | Epson Stylus Photo R220 InkJet Printer
Brand new Epson black ink cartridge won't print
Leaving an inkjet for two weeks with an empty cartridge is a definite way to get clogged printheads. Try doing 4 to 5 head cleans, wait about 10 hours for the ink to soften and do another 3 or 4 cleans with anozzle check after each. You should see a gradual improvement in the nozzle checks. If there is no improvement then you need a head cleaning solution such as this one:
http://www.powerklin.co.uk/?gclid=CNGDypir-JgCFQ4yQgodZlC4lw
Others are available just try googling "inkjet head cleaning".
Hope this helps.
Please take a moment to rate this solution, thanks.
Mar 25, 2009 | Epson Stylus Photo R300M InkJet Printer
Troubleshooting routine maintenance
SAME PROBLEM BUT I DONT TEACH. WE HAVE JUST REPLACED THE YELLOW AND THE BLACK INK RECENTLY IN THE PAST WHEN THE PROBLEM WAS UNRESOLVED WE WOULD JUST UNPLUG IT AND WAIT.
Oct 13, 2008 | Brother MFC-5840CN All-In-One InkJet...
Canon Pixma iP2000
try cleaning the print head as follows, otherwise a new print head.
OK, Canon will hate me for posting this.
1. Remove ink cartridges
2. Remove print head
3. go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
4. Fold several layers of paper towel and place on flat surface.
5. Run hot water until HOT!
6. Turn hot water back to a dribble.
7. Run the dribbling hot water through print head, be careful not to wet the gold contacts.
8.When water running through print head is clear, place print head on paper towel.
9. Repeat number 7 and 8 until no colour shows on paper towel.
10. Gently DAB print head (DO NOT WIPE) inside and out with dry paper towel until dry.
11. I normally replace print head after drying, but you may wish to let it air dry overnight.
12. Replace print head in printer and install cartridges
13. Start printing.
I do this to all 4 of my Canon printers every 6 months or so.
If any colour fails to print after this process it means your print head probably needs replacing.
Jun 28, 2008 | Canon PIXMA iP2000 InkJet Printer
14 people viewed this question
jasbo
jasbo
