Question about Ruud Matching Split Air Conditioner
My condenser is bound up, makes sounds like an electric motor that can't spin but is getting power. I think my usual fix of whacking said device sharply with a hammer may not be a good plan as it contains nifty gases. Any suggestions or a comment on how much this will run me to have replaced?
  • 456 Answers
You can always start by replacing the capacitor, but be prepared to
replace the fan motor just in case.
Posted on Jul 10, 2010
Driver's side window will not go up
regulator or motor ar ebad, electric or manual. we have tried this before and it has worked. on an electric motor window whack the lower inside part of the door. sometimes you get a weak motor that will come unstuck from its sticky point.... work the switch at the same time. on a non electric more than likely the cables on the regulaor are bound up. youtube replace videos are available and are similar in most cars can giv you pointers on how to replace it....
Sep 04, 2012 | Infiniti G35 Cars & Trucks
Fan condenser unit wont run
This is usually a bad capacitor or bad fan motor. The capacitor is located inside the electrical panel on the outside unit. You can check these by using a meter that measures Mfds (Microfarads), most of the time you can visually see the capacitor swollen or blown. The fan motor can be checked by a meter that measures ohms, really high ohms are usually bad. If you can't spin the fan blade easily, then it's locked up. What usually happens, the capacitor or motor windings go bad, doesn't spin the fan blade, overheats the compressor so it kicks out on thermal protection till it cools back down, and sometimes the motor will overheat and go into thermal protection also. Just make sure you are getting the 220v to the outside unit too, but shut all power off before doing any trouble-shooting. Hope this helps, feel free to ask any questions!
Jun 30, 2012 | Heating & Cooling
My AC condenser Fan works but I have to spin it. When the AC re-Cycles I have to re spin it. Is this the brushes? The Coil? What can this be
It sounds to me like you need to replace the start capacitor. The easiest way to make sure you get the proper capacitor then remove capacitor and take it with you to electrical supply store;the capacitor may be located on the motor housing squirrel case housing. It is possible that the capacitor is on the inside of the motor. If it is then you will need to replace the motor. Usually the wiring to the capacitor is one solid brown and one is brown with white stripe or has white hash marks on it. Thank you.
Aug 18, 2011 | Amana Heating & Cooling
My air condotioner is blowing out warmair.It blows out cold air forabout 5 minutes then warm again it's a 5050 series
It sounds like the unit is cycling on internal overload. The overload is switch the protects the motor from getting too warm. This would explain your cooling "cycling".
Check the condenser (the outside coil with vertical fins, the back of the unit). Is it clear of any debris? If not clean it using water or compressed air, using care not to bend or damage the fins or electrical wires/components.
Check the condenser fan motor. You can usually see the condenser fan motor through vents in the sheet metal. Check to see the the condenser fan motor runs when cooling is turned on, secondly check to make sure the fan blade is not broken, usually the blades are plastic. If the motor or fan blade is bad, you need a replacement.
Jul 12, 2011 | Goldstar WG5000 Air Conditioner
Our Amanda refrigerator/freezer has been making noises on and off (buzzing) over the past two months, in particular the bottom freezer. Today everything started to melt and the buzzing is frequent every...
It sounds like your evaporator fan motor, they last about 4-5 years. Try to see if the buzzing noise comes from the motor, usually in the freezer compartment behind a vented cover plate
The freezer is usually cooled by the compressor, the fridge is then cooled by an evaporator fan motor ($30). If this fan seizes or slows down then the fridge warms up (it sometimes starts squealing before this happens). It could be that your drain hose is clogged or frozen. Maybe the temperature adjuster go bumped.
If you think it is the evaporator fan motor:
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Can get from a parts supplier or electric motor company.
UNPLUG fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Oct 31, 2009 | Amana ABB1927DE Bottom Freezer...
Interior cooling fan has stopped spinning,
No fuse. The obvious thing is to check the motor itself, which means it must be pulled. Once you gain access to the motor, with the power shut off to the unit, try spinning the blade to see if it is bound up.
If it's spinning freely, remove it from the unit, and test the windings on the motor for continuity with a VOM meter. If you have no meter or access to one, or aren't familiar with electrical, then take the motor to an Appliance parts house. They can usually test it and most carry motors that are adaptable for beverage coolers. Make sure they know whether the machine is a 120 or 240 volt unit.
If I'm not mistaken that motor runs 24/7 when cooler is powered up.
Oct 29, 2009 | Carrier Beverage Air® Marketeer® MT12-1-B...
Hayward AO Smith Pump Motor is getting electricity but won't star
Make sure the motor spins by hand, then make sure the contacts on the v shaped start switch as closed when motor is off and make sure the capacitor is good a bad one usually leaks black stuff all over. To avoid buying a capacitor you might not need have it tested
Jun 03, 2009 | Hayward 2HP Pool Pump Motor A O Smith...
York central ac keeps blowing 3amp fuse on the circuit board when the compressor kicks in. thermostat changed with no help. what's next
sounds like you have short in the low voltge side of the electrical circuit. I would check the thermostat wires outside at the condenser. look for any bare or exposed wires from where the wire comes from the house to the condenser. the thermostat wire will be a brown wire that is run on the outside which sends a signal to the contactor to make the condenser work. common cause his rodents or happens when weed whacking around condenser. Hope this get you started.
Apr 26, 2009 | Heating & Cooling
Inside fan motor - evaporator
Yes if you dont hear the evap fan wprking remove rear panel in freezer let me know what you see. Is coil iced over? Is fan running? Is the motor warm? Attempt to spin the blade gently to see if the motor is bound. You can oil these.
Dec 02, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Drum not spinning - Asko 7705 Condenser Dryer
remove the lid and check for the belt being in place, if not then you need another, if its in place then the problem is electrical regarding the motor, possibly a capacitor, maybe the motor itself hope i have helped a little
Sep 30, 2007 | Dryers
Ruud Matching Split Air Conditioner Logo
50 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
