Question about Jenn-Air JFC2087HRP Side by Side Refrigerator
Ice is partially melted in ice maker. It seems like everything else in the freezer is totally frozen
  • Jenn-Air Master
  • 43,501 Answers
Here are some basic tips for ice maker troubleshootingice is partially melted in ice maker - 2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Posted on Jul 13, 2010
Whirlpool refrigerator #ER2CHMXPL02 I think I have two separate problems. 1st one is a water leak that fills the bottom bins daily! The freezer does not seem to be defrosting, everything in there looks...
Could be that the freezer is too full with foodstuff and there is no air circulation, therefor, some places in the freezer build ice. The defroster is working and melting the ice that drips to the bottom bins.
I suggest you remove everything from the freezer. unplug the frigde. Let all ice build ups melt. Remove ice from the foodstuff and put back in. Make sure that vents in the freezer and fridge are not blocked.
Oct 18, 2013 | Whirlpool 21.0 cu. ft. Top Freezer...
No water to icemaker, but through the door water is working. Ice maker itself is ok.
This is most likely cause because some part of the ice maker/distribution mechanism is broken. If at all possible, remove everything from the fridge and freezer and allow the freezer to thaw. If that is not possible, you could try and remove just the ice maker to thaw it or try and thaw it while it is still in the freezer. I hope this helps and have a nice day!
May 04, 2011 | LG LFX21980ST Stainless Steel Bottom...
Seems the freezer door was not completely closed. Ice started ot melt and then form icicles! Well we closed the freezer the next morning. Now the ice maker and water dispensor are not working. In...
when you closed the door, the freezer froze all the condensation/melting ice,hence the icemaker freezing.
the best solution is a TOTAL defrost/clean out,then dry out.DO NOT USE HOT WATER/SCRAPERS,let it defrost naturally or use car de-icer.wipe out with bicarb to keep fresh.and then restart as new.
Sep 11, 2010 | Jenn-Air 21.6 cu. ft. Side-By-Side...
I have an LG LFC21770 refrigerator and have noticed a build up of ice on the back wall of the freezer section. Yesterday, when I opened it to get some ice - the ice was frozen but had obviously melted...
If the freezer fails to defrost you get ice building up at the back of the freezer.
The defrost cycle relies in a thermistor transducer to detect the ice build up and to turn on the defrost cycle. The water usually then drips down to a tray under te fridge and then gets evaporated away.
Hopefully you only have a problem with the thermistor and not the defrost circuitry,
This is hard for a repair man to diagnose as when you call them out to your fridge it will be impossible to diagnose if the freezer is totally packed with ice.
And if you let it defrost totally it will be hard to diagnose as they may not be allowed to use freon to cool the transducer.'
So if you call someone in to check this you need to know if the ice build up will be a problem for them .
Youtube has several videos on this situation .
Apr 21, 2017 | LG LFC21760 Bottom Freezer French Door...
Ice is dumped before totally frozen.
Sounds like a water valve problem. The hollow ice cubes are the giveaway. This means not enough water. only things it can be is the ice maker is not turning on the water valve long enough or the water valve is restricted or the water valve has been leaking and has frozen the fill tube. and is only leting out a small amount of water in this case as well you will still need a new water valve.
start with water valve and if that does not solve the problem you will need to replace the ice maker.
Jan 12, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
My refridgerator box fills with water
common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Feb 01, 2009 | Refrigerators
Water leaking from freezer / above refrigerator section, ice maker not leaking, could this be from the defrost cycle?
Jan 25, 2009 | Refrigerators
Water leaking from freezer.
instead of ice maker heres a more common problem
Nov 15, 2008 | Frigidaire FRS26R4A Side by Side...
Ice maker not working
If you press and hold the button on the ice maker for seconds it will go into test mode and do a complete cycle. Try this and it should correct the problem. If you think the arm is frozen, you could use a hair dryer on it for a couple of minutes then do the test.
Sgt 48
May 20, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Ice maker
check the fill cup on the back of the ice maker for an obstruction of frozen ice, it the fill cup is frozen over then the water entering the ice maker will cascade over the frozen ice down into the freezer
if frozen melt it with a hair dryer then it will be ok
Apr 20, 2008 | Maytag MZD2752G Side by Side Refrigerator
Jenn-Air JFC2087HRP Side by Side Refrigerator Logo
112 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
