Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Lawn mower won't start unless I jump start it
I bought a new battery and it only starts when I jump start it.
  • Ian Summerfield
    Ian Summerfield Jul 10, 2010
    was the battery precharged?take a lead off and put it on charge overnight,and then retry
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 146 Answers
Take the battery back and have them test it (if they don't have the equipment, go to a specialized battery store instead where they'll test it for free). A new battery that has been sitting on a shelf a long time -- more than a couple months -- will discharge itself. Don't let them just charge it up for you -- the ultimate life of the battery will have been reduced. Get a fresh battery - look at the manufactured date sticker.
Posted on Jul 10, 2010
The car just clicks and doesn't start.
You may need to drive the car back to where you bought the battery. You may have a faulty battery or faulty alternator. When the car is running it should be charging from about 13.8amps and above. If the battery is completely depleted, a jump pack will not be able to jump start the vehicle.
Hope that helps.
G
Dec 02, 2014 | 1998 Volkswagen Passat
Suburban won't start, bought a new battery but does no thing, when jump started it stays running until it is shut off and will not start again
If you can jump start it and it stays running....I am assuming that you connect the Jumper Cable Ground to something other than your battery. If so, Your negative battery cable is suspect. Check both ends for ANY corrosion or loose connections.
Aug 18, 2011 | Chevrolet 1500 Cars & Trucks
Eight days ago 2005 Suburban would not start. Made a clicking sound when I tried to start it. Jumped the battery seemed fine. Today same thing. Made clicking sound, jumped, started up. Went and bought...
Even a new battery will go dead if the car is running on the battery instead of the alternator.
Check alternator output.
First charge the battery up.
Then check voltage with a meter from Harbor Freight ($3).
Should be 12.5.
The start engine and rev it up.
Should go over 14.
But also clean and grease battery terminals, alternator terminals, and check engine ground strap.
Sep 21, 2010 | 2005 Chevrolet Suburban
Hi, I own a 2005 R1 for a year now and about 2 or 3 months ago I felt that the battery maybe low, I tried to cherge it but it didn't help much. I bought a new battery today and after installing it the...
ur alternator or voltage regulator has issues-batt is not being charged--havum tested with a multimeter--inspect wiring 1st-may be loose or corroded
Sep 14, 2010 | 2007 Yamaha YZF-R1
2001 saab 9 3 won't start. I can jump start it
Sounds like your starter motor is bad. Is the starter motor spinning?
Jul 06, 2010 | 2001 Saab 9-3
2003 BMW 525i--could an improper jump start blow a fuse?
new altenator,sounds like you put the cables on the wrong way round
Jun 14, 2009 | 2001 BMW 5 Series
I have an RZT50 Cub Cadet Mower that only starts with jump
it sounds like the starter motor is pulling to many amps for the battery to cope with. if its a 12v system it should not pull the battery down to less than 8.5 volts on cranking if it does the starter-motor is defective you can check this with a volt meeter across the battery terminals and see what it read as you crank the engine. hope this helps
May 12, 2009 | Garden
Car Battery
Alternator is bad. It is not charging the battery as you drive.
Apr 30, 2009 | 2002 Ford Expedition
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
373 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
