This is the sign of a blown head gasket.
Since we don't know what caused the overheating in the first place, a crate motor, in the long run, may be the most cost effective means of resolving this issue.
If you are mechanically inclined, this may be an opportunity to teach your son how to clean up after his mess.
Put the black ink cartrige nozzle in warm water and wait several minutes.I don't know if this will work in your case but you should try it. I had similar situation and this helped.
Hi, You don;t have to take the print head out. Just do a cleaning by ( clicking on printer properties and sellect the maintenance tab and run clean print nozzles). Good luck
I think you choose the wrong catergory, this is for a program, and should only be used when TOPICS Entertainment's/SNAP!'s Dog Training program crashes. Thank you.
I suggest you clean it manually by removing the print head and then rub the print head in a plain paper with isopropyl alcohol until ink flows. Return the ink cartridge into the printer and run the print nozzle for 2-3 times.
I would suggest purchasing the version of the Mavis Beacon Teaches Typing v 1.5. It's compatible with Windows XP. I've also looked at the software description and you are able to select the age group of the typing test.
However, if some reason you have to continue with the same version. What error message do you recieve?
Thank You,
Raphael
That doesn't make any sense either. Canon suggests that you run a deep cleaning three times. Give that a try and if you don't have success use the comment box below to ask me again.
Please remember to rate all out solutions on FixYa.
If this response has fixed your problem please rate it Fixed. If not, ask me what results you have so we can continue to work on a Fix for your problem. Use the comment box below to do this.
Hi springfield,
From what you describe I don?t think it has anything to do with your printer drivers. I would try the following:
-Run a couple of nozzle cleaning jobs.
-If no change I would suspect a defective cartridge and would try a brand new HP cartridge.
If these don?t work I?ll need some more details such as do you refill cartridges, buy remanufactured cartridges or use new HP. Also is this still under manufacturer?s warranty? I don?t want to suggest anything that would void it.
Let us know what happens and please don?t forget to rate the posting.
