Question about DeLonghi Pinguino PACL90 Portable Air Conditioner
My unit is not cooling - DeLonghi Pinguino PACL90 Portable Air Conditioner
  • DeLonghi Master
  • 43,501 Answers
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 12, 2010
Norcold n510ul. Why doesn't it refrigerate in any mode?
it possibly needs recharged with freon and sad to say that can only be done by a certified serviceman
Aug 25, 2015 | Refrigerators
Refrigerator not cooling on electricty or gas
You will first want to ensure the RV is level.
If the RV is level, then open the rear access vent door on the side of the RV to access the rear of the refrigerator. Feel the coils just above the tank on the cooling system. These coils should be warm to the touch. If they are warm and the refrigerator is not cooling then you will require a replacement cooling unit. Also, the most common area for the Dometic 2652 to leak is just above the propane burner area. If it has leaked, you should see a yellow residue in that area. The cooling unit can be changed in approximately 2-3 hours with no specialized tools needed (Arcticold offers 7 day a week free tech support). The old cooling unit will simply unbolt and the new one bolts in. Check out ArctiCold Refrigeration We keep it cold (the highest quality product available) Arcticold New Cooling units come standard with a Lifetime Warranty. Install instructions are also provided with the cooling unit. Arcticold has locations across North America to provide fast delivery. Arcticold cooling units may be purchased over the phone (1-888-782-6665) or through Ebay- Dometic RM2652 Brand New Manufactured Cooling Units LIFETIME WARRANTY
#1 Help Diagnose Video
#2 Install a Arcticold RM2652 Cooling Unit Video
Mar 15, 2014 | Dometic DM2652 Americana Fridge...
Won't work on any power source
If the RV is level and the rear coils of the cooling unit are warm, then you will require a replacement cooling unit. Changing the cooling unit is something that can be done by the end user such as yourself. Check out Arcticold Cooling Units.here ArctiCold Refrigeration We keep it cold or give them a call toll free 1-888-782-6665
By replacing the cooling unit with an aftermarket one, it will save you you money (vs buying a new fridge) and increase the performance and durability of your fridge. Arcticold cooling units can be purchased on ebay Dometic RM2611 Brand New Manufactured Cooling Units LIFETIME WARRANTY... The RM 2611 cooling unit is the same as the RM2620 28c4e1ea-6951-42e3-827e-9b9809f394fb.jpg
Mar 09, 2014 | Dometic RM2620 Refrigerator
Rm2862 willnot comeon at all,frot panel does come on , no blown fuse Lp turns on the heather but unit will not cool
If you fridge is level, and the rear coils of the cooling unit are warm then you more then likely need a replacement cooling unit. If you do, we can help. We are Arcticold Refrigeration. We specialize in the manufacturing of New Replacement Cooling Units for Dometic & Norcold RV Fridges. Our cooling units are direct replacements of the factory units. In most cases the cooling units can be changed in a couple of hours. Arcticold cooling units come standard with new installation hardware, installation instructions, and a lifetime warranty. We also offer 7 day a week free tech support 1-888-782-6665 Our cooling units are available throughout North America. Don't hesitate to give us a call or visit our web site. ArctiCold Refrigeration We keep it cold f926e66c-02f3-4d45-9004-f68d1864e268.jpg
Dec 26, 2013 | Dometic RM2852 Refrigerator
Unit runs and blows air but does not cool, can it be recharged?
check to see if compressor running if ok bad cooling unit or temp sensor
Jul 03, 2012 | Dometic Rooftop RV Air Conditioner
Global.netOur ac/heating unit is approx 2 years old. The unit triped the breaker resulting in the fan continueing to run, but the cooling unit no longer cooled.. Re set the breaker and unit immediately...
I would check all the connections at the breaker panel, and in the disconnect and in the control panel of the unit, the connections must be tight. If the breaker is sized to small a dirty coil could be to blame if so give it the hose, a full solid stream and be thorough is cleaning it.
Jul 02, 2011 | Heating & Cooling
Unit does not cool
It would appear that the unit needs to be regassed and checked for leaks.
Sep 11, 2009 | Refrigerators
No cooling after power out, indicator lights pattern not in manual
The Mitsubishi units have to be reset by turning off the indoor units by switching the remote or thermostat to off. Then turn off the breaker to the outside unit(s). After 30 seconds,turn on the breaker and then you can turn on the remote for cool. If no lights come on on the inside units, most likely you have blown a fuse soldered on the main PC board. At this point, call your technician. A goos tech will be able to wire in an in-line fuse holder so if it should happen again, you can easily replace the fuse. If you do see a light or two come on at the indoor unit but the outdoor unit does not start after 3 or 4 minutes, sounds like you will need to call a technician. Most likely you have a blown fuse on the main PC board of the outside unit. It is not an easy one to replace. Good Luck!
Aug 31, 2007 | Mitsubishi MSH09TW Air Conditioner
Heating & Cooling Logo
306 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
