Question about HP LaserJet 3050 All-In-One Printer
Vertical line when copying. The line does nIs this a problem for
On the HP Laser Jet 3050, there is a vertical line on every copy, when using the copy feature. The line does not appear when printing. Is this a problem for which there is a solution?
  • steven Jul 10, 2010
    First clean your Glass.
    Thank you, Steven 805-520-3003
  • fayee746 Jul 12, 2010
    Steven: A thorough cleaning of the glass (after I found it) alleviated the problem. I can now copy without vertical lines. Thank you. FE
  • 1,476 Answers
I would look at the scanner. It is not involved in the printer process but is in the copy process. Clean the glass with a glass cleaner and soft cloth. Remove the glass and also clean the lamp assembly. If either part has a dark mark on it it would leave a line on the copy. If this does not solve your problem and the unit is several years old I would replace the lamp. Let me know if you need more assistance.
Thanks for using FixYa and for the generous rating.
hardrocko
Posted on Jul 10, 2010
Testimonial: "Your suggestion worked perfectly. Thank you for the suggestion. This is a friendly-to use and helpful site. Thank you. "
  • Kim Yearick
    Kim Yearick Jul 10, 2010
    That's why we're here. And thank you for the generous rating!!!! Thanks again for using FixYa.
    hardrocko
  • 38 Answers
Open the scanner and clean the glass.
Posted on Jul 12, 2010
How do I fix this
Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans
support.hp.com/us-en/document/c02881567
Figure : Sample output with vertical colored bands or lines ... Remove any paper from the automatic document feeder (ADF) tray. ... To protect the scanner, do not spray the glass cleaner directly on the glass. .... determine if your printer is still under warranty, and then Contact HP Support to schedule a repair or replacement.
How to get rid of lines on a copied page - YouTube
? 2:10
https://www.youtube.com/watch?v=xTJpCg5sHl0
Feb 17, 2010 - Uploaded by Wayne Springer
When you make copies on your copy machine, does it ever leave a black vertical line ... QLS ' How to Eliminate Vertical Linesfrom Scans, Copies & Faxes ... Part 2- Fix or repair color laser printer with fading, light print, or lines ...
Dec 29, 2015 | Office Equipment & Supplies
WHEN TAKING A COPY , IN LASERJET 3050, A VERTICAL BLACK LINE APPEARS IN THE CENTRE OF THE COPY.
If this doesn't appear when printing from computer and olny when copying or faxing, it means that the scanner glass has a spot on it. Please refer to the manual on how to clean the glass window, or go to this page on HP support site to view an image on how to do it:
http://h20464.www2.hp.com/resultsCSR.htm?prodSeriesId=1140783&MEID=A1C54583-26E6-44DA-ACAF-059483D03EE2
The one on the left refers to your model; click the IMAGE button to see an animation.
Please come back with a rating/testimonial if helped.
Aug 15, 2010 | HP LaserJet 3050 All-In-One Printer
HP 3050 vertical black lines during fax
OK, from the desciption i can assume several things here are some option.
If by receipt you are talking about the confirmation the unit prints the the problem is likely dirty glass.
You would also get the lines when you make a copy using the ADF.
Open the lid there are two areas of glass the thin strip is likely dirty and needs to be cleaned.
If by receipt you mean pages you receive from someone else, and not printed or copied on your machine, then their machine has the condition described above.
If everything has the lines then you have a toner or fuser problem:
This is the test to determine toner or fuser issue.
Print a test page
When you hear the paper feed into the machine open the top to stop the machine
Remove the toner cart.
You should be able to see the page with printing on it. (This is before the page hits the fuser)
If you can see the smudge or marks on the page the problem is most likely the cartridge but NOT the fuser.
If the page is clean the problem is most likely the fuser.
Hope this helps
Mar 24, 2009 | HP LaserJet 3050 All-In-One Printer
HP 3050 - vertical black lines
You say that the scanner glass is clean, but it takes next to nothing to cause these lines. Couldn't hurt to chack again (if you havent cleaned it 6 times already).....anyway, I found this document that is not specifically for your machine, but the menu commands should be the same:
Recalibrate the product scanner:
  1. Press ENTER/MENU on the control panel of the product.
  2. Press the < arrow key once to display Service and press the ENTER/MENU button.
  3. Use the < and > keys to select Scan Correction and press the ENTER/MENU button.
  4. Insert a blank, bright white piece of letter (8.5 x 11 inches or 216 x 279 mm) or A4 (8.3 x 11.7 inches or 210 x 297 mm) paper into the document feeder tray.
Good Luck, and please rate the response :)
Mar 20, 2009 | HP LaserJet 3050 All-In-One Printer
Lines on making copies
clean the glass of the scanning area, a small dot of debris on the glass produces a vertical line from top to bottom in the feeding direction of the laser printer.
May 07, 2008 | HP LaserJet 3055 All-In-One Printer
HP 3050 Black Line
I was getting a verticle black line and I had to clean the glass, the long white bar above the glass, and the white and black rollers before my problem was solved.
Mar 12, 2008 | HP LaserJet 3050 All-In-One Printer
Printer putting line down the page
I had a hp 3050 yesterday with two vertical lines running down the page when making a copy. All I had to do was to pull open the top cover where you put the paper you want copied and cleaned the glass strip with a rag and alcohol and the lines were gone.
Jan 21, 2008 | HP LaserJet 3050 All-In-One Printer
Problem while copying
mark on scan glass, clean glass slit in where original is fed for copying
Nov 07, 2007 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 3050 All-In-One Printer Logo
599 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
