Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
How do i fix an F5 error code on a Fisher & Paykel Dishdraw DS605. I have turned the power off but the error keeps returning?
  • Fisher and P... Master
  • 3,247 Answers
I am assuming you have the DD605 double drawer dishwasher. Is the problem F5 on both drawers or just one?
F5 code involves the drawer lid seal and will need a bit of effort to check and fix.
Take the drawer out and inspect the inside of the top panel for a black rubber strip. If it is broken or not responding to up down movement then it needs to be replaced. In addition the actuator motors on each side that drive the seal could be faulty.
If you are not comfortable with repairing slightly complex apliances then you may have to call the technician.
Posted on Aug 19, 2010
Fisher & Paykel Double Dishdraw (DD60DCX6). 1 Draw gets stuck mid cycle & continues to wash, no beeps, water not hot. Can you tell me which parts need replacing. Previously other draw
Coulg be a faulty heater. The unit will continue to wash for 2 hours before it gives an F4 fault message. Check the resistance of the heater element. There may be a solder link that is designed to fail if the temperature ever gets too high. Otherwise it could be a faulty controller board. Post back if you can narrow the diagnosis.
Jan 27, 2015 | Fisher and Paykel Dishwashers
Fisher paykel troubleshooting
http://www.fisherpaykel.com/vault/pdfs//pdf_usecares/590199D%20DishDrawerP7%20userguide%20USCANZAUGBIE.pdf
Needs re programing and resetting . Check the machine is still level and the draws are not vibraiting out as the machine gets going
Jul 21, 2014 | Fisher and Paykel Dishwashers
Fisher and paykel double dish draw has stopped working and is coming up with F5
Hi.
F5 is Lid Fault.
Try clearing the error code by disconnecting power from circuit breaker for five minutes. If that does not help, then there is a problem with lid switch. The part must be tested and replaced.
Regards.
Ginko
Aug 20, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Our Fisher & Paykel Intuitive Q came up with an Error Code 51, Stopped and an Alarm came on.
Hi, this is an update on what I found out about the E51 error code from Fisher & Paykel. This code is an error with the internal memory as one of the previous poster's said. Fisher & Paykel Rep said though it wont hurt the function of the machine it should still be replaced because it may effect the compliance information.
Nov 15, 2010 | Fisher and Paykel (IWL12)
Hello -Just looking for help on fixing a service code 66 which comes up when you turn the power on. Unknown age on machine. Fisher and paykel intuitive eco model IW811
HI error code 66 means you have a pressure transducer out of range error.This means that the control module is faulty and needs replacing.please confirm that the error code is numbered 66.Please reply for further help and clarification of this fault code.Hope this helps.
Jun 02, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Hi My Fisher and Paykel Soft Touch dishwasher on a daily basis shows the error code F5 and beeps until I pull it out from the wall and turn it off and on again. How can I fix this?
there is no f5 fault in any of the soft touch f7p dishwashers, sure its not something else whats the model no , i fix f&p for a living
Oct 27, 2009 | Dishwashers
Fisher&paykel d603 dishwasher
Disconnet Dishwasher, Remove lower dishdraw, soak up excess water with a towel, use a hairdryer to dry water especially under grey plastic cover. Then check seal on either dishdraw and make sure they are not kinked or leaking as this has most likely caused the problem. Power up problem should be resolved. Don't leave dishdraw unattended till you validate problem definately fixed.
Sep 06, 2008 | Fisher and Paykel 23 in. DS603H W Built-in...
Error code. Fisher and Paykel Dishwasher
well since you asked on the 5th July, and no reply, doesnt look like you may get one. I thought thats what this site was about??
Jul 05, 2008 | Dishwashers
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
5,527 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
