Question about Garland PS-6-24BG-2626 Gas Kitchen Range
Oven ignitor glows but gas doesn' fire? I guess it's the oven valve. Since we are not using the griddle, I'm wondering if I can use the valve from the griddle (which is on top) for the oven? Craig
    Sergeant:
    Champion:
  • 311 Answers
Replace the ignitor; it is worn out. It is not like a light bulb where it goes out totally.
Posted on Jul 10, 2010
10 year old DCS Oven does ignite. Oven ignitor glows but maybe not enough to trigger LP from being introduced?
just because the ignitor glows it doesn't mean it's good,it takes 3.2 amps for the ignitor to open the gas valve and ignite the flame,usually if the flame doesn't ignite in around 40 seconds the ignitor is bad.also check the burner tube,your model number doesn't come up so i don't know if you have one or two ignitors in this oven but i've found that when the ignitor starts to fail and the customer waits to long to have it looked at the ignitor burns a hole in the tube and then both the ignitor and tube has to be changed,hope this helps and good luck with your oven.
Jul 19, 2013 | DCS RGU-486GD-L Range 48", 6 Burner,...
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
My oven works fine it just doesn't heat-up. I can hear ignition clicking but no fire from burners. A technican told me to purge the union above gas to get rid of air in the line. Thanks Louis
Personally I wouldn't describe an oven that doesn't heat up as working fine. You shouldn't have any air in your gas line unless this is the first time firing the oven, in either case the air in the gas line would work its way out eventually and the oven would light on its own.
Check to see if your ignitor is glowing before you hear the clicking, if the ignitor isn't glowing it needs to be replaced and is fairly easy to do so. If your ignitor is glowing you should check to make sure you are getting gas to the burner. The only way I would recommend checking this is with your nose, do you smell gas when the gas valve clicks? If you do then something is wrong with the burner, either dirty or the exhaust is too strong, or even gas pressure too low. If you don't smell any gas that doesn't necessarily mean no gas is coming out, at this point you should call a authorized service provider to take it over from here.
Nov 03, 2010 | Baxter BXA2G Stainless Steel Gas Single...
Gas oven doesnt work
Hello there:
Gas oven won't work, Ignitor is glowing Everything in the circuit must have continuity for the oven to fire up. What if the ignitor glows but the oven will still not come on? If the ignitor is glowing that would mean you have a circuit. Solution: Replace the ignitor, even if it comes on. Why? Because 99% of the time the ignitor is weak. When it is working fine it should be so bright you cannot look at it for long. If it is a mellow orange color it is bad, replace it. The only way the gas oven valve would be bad is if it is open and has no continuity. That goes for the control as well. Check out this simple diagram of how a basic gas range operates. glowbar.jpg oven ignitor An ignitor must draw at least 3.5 amps or that safety valve will not open up and release the gas: gas-ignitor-circuit.anim.5. Click on image to see it in motion
Apr 27, 2010 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Oven will not fire up fgf354bgwc
Hi, The ignitor could still be bad even if it glows. It is a very common problem on the gas reanges. The ignitor is getting so weak it will not open the gas valve.
I hope this helps you understand what is happening. Please let me know if I can assist you further.
Thanks
Vic
Jul 26, 2009 | Ovens
Oven not lighting on Amana model agds902ss
Helloemauldin Welcome to Fixya
My name is Huum,
When you turn the thermostat on your range on it sends 120 volts to the bake valve and ignitor. The bake valve and ignitor are wired in series and the ignitor draws all the current and heats up. As the ignitor heats its resistance changes and when it is cherry red the current switches to the gas valve and it opens. The amp draw on the ignitor needs to be 3.2-3.6 amps for the gas valve to open. The gas valve has gas to it at all times. The gas valve should open within 40 seconds after the ignitor starts to glow.
If the ignitor is glowing red and the gas valve doesn’t open the ignitor is usually the problem. Sometimes the ignitor will glow red but the resistance doesn’t change and the gas valve doesn’t draw the current.
This is not a do it your selfer!
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 24, 2008 | Amana AGDS902SS Gas Kitchen Range
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
Lighting pilot of GE gas stove
According to the model number you supplied it looks like your oven use a glow bar ignitor not a pilot light. In that case there is no place to hold a fire. what happens with these when you turn the oven on 120 volts goes to the ignitor causing it to heat up ,the amp draw across the ignitor causes the gas safety valve to open, and then lights the gas. So if you turn your oven on you should see a bright red glow if not probably the the ignitor, to check it you would have to verify you actually have power going to it. If the ignitor glows but the gas valve does not open you will still need to replace the ignitor has to pull about 3.2 amps across ignitor to open safety valve. Your broil burner works the same way. And most of the ovens the floor of the oven comes out to allow easier acess to the ignitor. also if you have to change the ignitor put just a dab of dish detergent on the screws to help from stripping them
Nov 27, 2007 | GE JGRP17 Gas Single Oven
Garland PS-6-24BG-2626 Gas Kitchen Range Logo
132 people viewed this question
Top Garland Kitchen Ranges Experts
John Tripp
John Tripp
Dennis Boxerman
Are you a Garland Kitchen Range Expert? Answer questions, earn points and help others
