Question about Dell Inspiron 530 Desktop Computer
Slot for the camera card no longer work on the
Slot for the camera card no longer works on the hard drive
It used to work......
    Scholar:
  • 193 Answers
What hard drive?! you meen memmory card right! well maby its the memmry card problem, not the slot
Posted on Jul 10, 2010
My computer no longer recognizes my Samsung L830 camera
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
Jul 06, 2013 | Samsung Digimax L830 Digital Camera
Hello, My digital camera is Pentax Optio E30. After taking photos I tried to download them to my netbook using the SD card slot. I inserted the memory card into the slot but no files appeared but when I...
Pretty cool that the newer computers are coming with an SD card slot. However the computer looks at this as an external hard drive and I don't think the pictures are just going to automatically pop up on the screen. You will need to go find the "drive" click on the folder and open, once you have the pictures open you can select all copy and then create a folder on your computer hard drive and paste the pictures in that. Once the pictures have transferred do a safe eject of the SD "drive" and remove the SD card. Don't forget to do a format to the card once back into the camera.
Apr 05, 2011 | Cameras
How can I find the correct USB cord to download pictures? I've tried make and model but can't get USB info with same.
Well, if I were you seeing you are going to have to buy something I'd be buying a card reader. With a card reader you can either purchase on that works with the one card you use or a multi which has a number of slots for all the cards made. What you do here is connect the USB cable that comes with the reader to the computer and insert teh memory card from the camera into the reader. the computer then loos at the Memory card as if it were an external hard drive and the camera is not even hooked up. You can open the files and save them to a folder on your hard drive. Last single reader I bout was $12.00. Works great no programing to worry about either.
Jan 06, 2011 | Cameras
Hp 3x optical zoom photosmart R847 camera plug in to PC and cord was check it is working fine but it will no longer establish a connection with the computer Uninstalled disk and reinstalled still...
Consider NOT connecting the camera to the computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Dec 02, 2010 | Cameras
Have an older 4500 Super that has been an amazing camera, but the no longer will recognize the SD cards--just flashes NO CARD. Is there anything I can do to solve this problem? Otherwise, works well.
Probably the first thing to try is formatting the card. There is a function in the camera menus to do this. If it won't format or gives an error when you try, then there may be an issue with the connectors in the card slot or the card may be incompatible. SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. Some cameras have a capacity limit, and won't work with cards that are too large (in memory terms).
Oct 27, 2010 | Samsung Digimax 4500 Digital Camera
When I insert a memory card into my pentax camera, I am getting a memory card error message. There are pictures on the memory card. The card works when inserted into another digital camera.
Hello
Ok, here is something that just might work.
In your case the problem is not with the card but rather with your camera's card reader. This is a rather hard problem to fix yourself but here is what you can do.
Open the card slot of your camera and peer inside with a sharp light or torch. You should see a little metal tab or switch inside the card slot. This is the write protection switch. Contrary to popular belief , the switch on the card does not impact the operation of the card itself but rather tells the camera that the card should be locked by depressing the little pin inside.
If you put a protected card into a camera with no protection switch , the card would operate normally.
However , with time and repeated use , the switch will start to bend slightly until it will no longer depress when a unlocked card is inserted.
With a toothpick or needle , slightly and very gently push this tab up a little bit. (some camera's will require you to pull the tab down), This will allow the switch to operate once again and should solve your problem.
Kind Regards
Andrea
Aug 13, 2010 | Pentax *ist DL Digital Camera
What can I do when my camera says 'memory card is write protected'? I have moved toggle switch from lock to unlock, removed card, blew inside card slot and it still states the same thing.
Hello
Kind Regards
Andrea
Aug 12, 2010 | Cameras
Locked card
Hello
Ok, here is something you can try:
Kind Regards
Andrea
Aug 03, 2010 | SanDisk 2GB microSD Memory Card
Auto play screen does not appear when camera card is inserted
WHEN YOU CONNECT YOUR MULTI CARD FROM PC THAT TIME YOU SHOW OPENING OPTION THAT TIME IT SHOWS DO NOT TAKE ACTION CLICK ON IT AND IT WILL NEVER DO AS LIKE THIS
Oct 20, 2009 | Computers & Internet
I need a bigger hard drive
You can purchase the cards at any retail store. The memory cards from Smart phones and Digital camera's also work
Mar 05, 2009 | Acer Aspire One PC Notebook
Dell Inspiron 530 Desktop Computer   Logo
mukhtar21 shaikh
mukhtar21 shaikh
