Question about Sony Bravia KDL-32V4000 32 in. LCD TV
I have a sony KDL26L4000 26" and for a unknown reason it wont turn on when using remote i have tried new batteries you have to press up on remote control or 1 on remote control and the green led keeps blinking on and off and flashing all the time instead of just staying green. hope you can help
  • 11,361 Answers
It sounds like the key on the remote is stuck. In your case, if you see the flashing light on the camera screen without pushing any button, then for sure one of the button is stuck.
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera’s Lens (Digital Camera can detect IR), you should see flashing light on the camera’s screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Posted on Jul 10, 2010
Mum pressed some buttons on amp now the amp wont respond to the original remote or the universal remote. buttons wont work, batteries good and lights up. is there a button that blocks ir signal?
Looking at the user guide it appears that the amp has a standby mode.
See not below on turning standby on. Question can you see the standby light flashing.
I would also suggest using function on the amp to remove any possible issues with the remote.
One would expect the system to return to normal operation by pressing the power button again. If not what do you see on the display.
Note:
Press 1 to turn on the receiver.You can also turn on the receiver using 1 on the remote control. When you turn off the receiver, press 1 again. "STANDBY" flashes on the display panel. Do not disconnect the AC power cord (mains lead) while "STANDBY" is flashing. This may cause a malfunction.
Jul 08, 2017 | Sony Audio Players & Recorders
I got a sony tv model kv-eg25m20 and it just went off and now it wont switch on again. No red light nothing. Please help.
Start with basic checks like plug fuse any damage to its mains cable mains socket or any adapters (some have fuses people forget about). Check remote batteries and remote hide it from TV (I have seen a sick remote fire signals unknown to anyone and cause shutdown)
Unplug for an hour turn off its power switch then try again,if all these ideas fail, you are into a service call out because there is possibly an internal fault which will require an engineer.
Sorry for limited ideas.....
Mar 05, 2015 | Sony Televison & Video
My TI-83 calculator wont turn on when i pit in brand new batteries and it still wont turn on i have tried pressing every solution help please!!
I see thatt you do not have the same kind of batteries :for example, you need to buy alkaline from the same type all SONY etc do not mix other type or mark , not use differente mark. 2) must be sure about the polarities of the batteries 3) clean the contacts batteries for dust, oxide, corrosion 4) open the calculator for some wires desolder and resolder the 2 wires again.
If the problem persist you must go to the repair shop TV.
God Bless you
Nov 11, 2012 | Televison & Video
I don't know if I can make it any clearer. My remote RM-PP411 suddenly stopped working. It has new battries and the use mode light lights up when any key is pressed. I turned the STR-D685 on by hand and...
Please take these actions before we try yet another universal programmable remote 1. Clean the IR screen on your tv set. It will often appear clear in view with a reflective window which often has a black, blue, or red tint to it 2. Clean the same window on the programmable remote 3. From tons of experience, I've noticed that Sony tends to provide the most compatible remote for replacements 4. Please confirm with me which codes your attempting to use when programming, and type /model number of the universal remote 5. Keep in mind that the remote that does not work as a replacment may very well be exchanged 6. Only use approved batteries for your remote and keep in mind that rechargeable batteries account for 50 percent of electronic errors 7. If your old remote simply stopped working for no reason at all, then we may have a communication problem with the tv combo set itself. 8. Ensure that the tv set is ready and able to receive a signal by setting it to the factory defaults within the settings menu 9. If we know why your older remote simply stopped transmitting the signal, we will acheive a must faster solution 10. Please attempt a fresh set of batteries in the older remote to determine the root cause behind the transmission problem 10. Check your power cord for crimping, dents, or pinched underneath unit. Each of these activities will cause power to stop transmitting to your unit 11. the digital display is not popular for having problems. 12. Ensure that you press the power on button on the digital display firmly at an attempt to power the unit on. 13. If you still have not recieved power, we will continue to troubleshoot the internal portions
Jan 26, 2011 | Sony RM-PP411 Remote Control
Cannot turn on or off the tv with remote,can't turn up or down vo
It sounds like either the remote is no good or the ir receiver in the TV has gone bad. try new batteries, or even a universal remote. this will help tell you if it's the TV or remote, good luck
May 31, 2010 | LG 42LG50 42 in. LCD HDTV
Remote control wont turn on
Hi
Please try to remove the battery and check with different batteries.
Check wen you press any button the RED light is blinking or not ?
Feb 19, 2010 | Exceed-RC Toys
My remote wont operate my sony TV volume
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 25, 2009 | Sony RMT-D155A Remote Control
Key remote no working
Sometimes when you cycle the ignition (turn the key from off to start and back to off again) to often in a short period of time (usually 8 times in 10 seconds or so) on accident, the remote access personality module will enter its programming mode by default. This is how the dealership will program in new remotes for your vehicle. However, if it is done unintentionally, and then no new remote is entered into the system (done by simply pressing any key on the remote within the next 20 seconds or so) then any previous remotes programmed into the RAP module are erased. Hence, your remote will no longer work, until and unless it is reprogrammed using the above method.
May 24, 2009 | 1999 GMC Safari
Remote wont work
for some reason unknown, the laser or infrared diode has died
May 20, 2007 | RCA 257003 Remote Control
Sony Bravia KDL-32V4000 32 in. LCD TV Logo
354 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
