My XP task manager is disabled and it shows a dialog box with heading SAM, How can i remove it ?
I have XP sp2 my task manager has got disabled may be due to frequent use of pen drives some sort of worm or patch has got installed
Now every time i try to open the task manager it gets open for a fraction of second and then again goes blank after which i receive a message dialog box named SAM
How can i remove this worm ?
Waiting for the answers
    Sergeant:
    Champion:
  • 333 Answers
Download AVG free ediiton, install it and get all the updates. Scan your computer. If the problem is due to a virus or trojan, it will find it and fix it.
http://free.grisoft.com/
If this works don't forget to give feedback - "fixya"
Posted on Apr 19, 2008
How can i enable the task manager on my laptop?
For that go to start menu->run or press windows key +R key so you can see run type in run "gpedit.msc" without "" then press ok then you can see group policy. Go to user configuration-?administrative templates->system CTRL+ALT+DEL option select remove task manager and disable it. Let me know if you need further assistance. Thanks for using FixYa.
Oct 05, 2010 | Microsoft Windows XP Professional SP2
Tip
Enable the Registry Editor, Task Manager and Folder Options Disabled by Viru
Virus attack is common these days and we often come across the problems like Disabled Folder Options or like Task Manager and Regedit disabled by Administrator. These problems are nothing but virus activities. The virus has infected our system and stopping us from accessing these options.
Pressing keys Ctrl+Alt+Del opens up a dialog saying that “Task Manager has been disabled by your Administrator” whereas you are the Administrator yourself. It becomes very annoying when you think that you can fix this problem by going into the Registry Editor but it doesn’t show up. Even the Folder Options gets disabled.
This problem is generally caused by a virus named “Brontok” but don’t worry just use RRT (Remove Restrictions Tool) that can easily solve this problem. RRT is free and can successfully enable:
1. Folder Options
2. Regedit (Registry Editor)
3. Task Manager
4. Show Hidden Files option
The tool will come more useful if you use it in Safe Mode.
Download RRT
on Nov 17, 2008 | Microsoft Windows XP Professional With...
My task manager is not opening up. i am continuously trying ctrl alt delete. mys os is XP.
download Unhook.ini from norton site. Run it as administartor. It should get fixed.
Cheers!
Sep 06, 2010 | Acer Aspire 5600 Series 5630-6951 Laptop
The Update Assistant keeps opening a dialog box stating that it has no access to the router. But whenever I try to do anything in the dialog box--click a button or close the dialog--an Internet Explorer...
1.Press Windows logo key + R, type winver and hit Enter key.( Check the version details of Windows 10 installed on your computer).
2.Shutdown your device ,restart it back and then initiate the upgrade to see if goes correctly this time.
If any third party Antivirus or Online security software is installed, then try to disable it for a moment then try to initiate the upgrade to see if it goes correctly.
In case problem still persist, then try to upgrade it in Clean Boot state.
1. Press Windows Key, type msconfig in the search box, and hit Enter.
2. On the Services tab of the System Configuration dialog box, tap or click to select the Hide all Microsoft services check box, and then tap or click Disable all.
3. On the Startup tab of the System Configuration dialog box, tap or click Open Task Manager.
4. On the Startup tab in Task Manager, for each startup item, select the item and then click Disable.
5. Close Task Manager.
6. On the Startup tab of the System Configuration dialog box, tap or click OK, and then restart the computer.
Apr 08, 2017 | NetGear WNDR3300 - RangeMax Dual Band...
How we will enable the task manager in windows xp
there are 2 ways..
1. just right click to you task bar (shown below) then click task manager.
20fd7c1.jpg 2. press ctrl alt del simultaneously, then click on task manager..
cheers!
Jul 11, 2009 | Microsoft Windows XP Professional SP2 Full...
My task manager has been disabled due to virus attack. help me
There is a registry hack to enable or disable Windows NT TaskManager. The same registry hack applies to Windows 2000 and Windows XP. Hive: HKEY_CURRENT_USER
Key: Software\Microsoft\Windows\CurrentVersion\Policies\System
Type: REG_DWORD
Value: 1=Enablethis key, that is DISABLE TaskManager
Value: 0=Disablethis key, that is Don't Disable, Enable TaskManager
As part of the enhanced management available in Windows 2000 and Windows XP, rather than risking a registry change, as an administrator you can enable or disable Windows 2000 Pro or Windows XP Pro's TaskManager using Group Policy Editor. This can be applied to the local policy. Note: if you are trying to override your organizations group policy, you can't. As soon as you re-authenticate to the domain, the domain or OU Group Policy will rewrite the registry setting. But if the TaskManager was accidently disabled or you need to control this item for a set of standalone boxes this is for you:
  • Click Start
  • Click Run
  • Enter gpedit.msc in the Open box and click OK
  • In the Group Policy settings window
    • Select User Configuration
    • Select Administrative Templates
    • Select System
    • Select Ctrl+Alt+Delete options
    • Select Remove Task Manager
    • Double-click the Remove Task Manager option
And as I mentioned above, since the policy is Remove Task Manager, by disabling the policy, you are enabling the Task Manager.
Mar 23, 2009 | Internet Grisoft AVG Security Full...
My windows cannot open exefile and I cannot install spybotsd162.
Dear johan_poliwa, ur windows installer has corrupted or have been deleted. The best possible solution is that u format ur OS.
Mar 19, 2009 | Microsoft Windows Vista Home Basic Edition
Task manager disable
Its a virus on your computer that has disabled the functionality of task manager, cmd, or registry. Run an antivirus scan and if the problem still persist, you need to either repair or format your pc.
Feb 13, 2009 | Intel Motherboard
Registry Editor, Task manager, Command Prompt Disabled
hi, your computer is attacked by virus .install some antivirus and scan the system to resolve this problem .
Dec 17, 2007 | Microsoft Windows XP Home Edition
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
