Question about E-Machines eMachines Monitor E15T4
Monitor displays frequency out of range.....need help . How can I solve this?
  • 6,826 Answers
The frequency is out of range because the VGA graphics card is not compatible or set right for the monitor's set of frequencies that it can work with.
Try another VGA graphics card.
Or upgrade the card to one with DVI, and upgrade the monitor to one of those 24" DVI Samsung monitors. They're nice. I got one from Best Buy a few years ago, and never regretted the larger desktop.
Good luck on this one.
Posted on Jul 10, 2010
4 Suggested Answers
  • 103 Answers
SOURCE: Signal out of range?
Using your CRT, open the properties of the video adapter. Look for the refresh rate and set it to 60Hz. This should fix your problem.
Hope this helps, and please rate my advice, good OR bad.
Thanks, and good luck!
Posted on Feb 04, 2008
dugiehowsa
  • 114 Answers
SOURCE: Monitor not displaying
Sounds like your video adapter settings have been wedged. If you are running Windows XP Service Pack 2, you can use the following steps. 1) Boot the laptop into safe mode. Boot into safe mode with networking support if possible. This can be done by tapping the F8 key as the computer first turns on. 2) Once you are at the Desktop, right click on My Computer and select Manage. 3) In the window that appears, select Device Manager from the menu on the left. 4) Find Display Adapters on the right and click the plus sign. This will list the video adapter that you have. NOTE: WRITE this down EXACTLY. You may need to go and get drivers for this. Seeing this is an older model, I doubt you'll need it, but better to be safe then sorry. 5) Go to your manufacturers support web site and download these drivers. You may not need them, but better to be safe then sorry. NOTE: Skip step 5 if you did not boot with network support or cannot get to the Internet. This can be done from normal mode. 6) Right click on the display adpater and choose un-install. Hit OK on the window that appears and reboot the machine when the process is done. 7) The machine will take longer than usual to boot, as Windows XP is re-discovering the video adapter and resetting everything to the defaults. When it is done booting, the screen may look weird since the settings are now the defaults. You can the set them to what you want by right clicking on the desktop and selecting properties. Then go to the settings tab. 8) IF it did not re-discover the video adapter (this can be confirmed through the device manager), then go ahead and install the drivers. Windows Update will most likely also have the drivers.
Posted on Oct 16, 2006
frankzjm
  • 191 Answers
SOURCE: at start up it displays a message "frequency out of range" please change the display mode to 1280 x 1024 with 60Hz, any idea why its doing this and how to solve this issue so i can log back on to wind
ok you may do soluton #1 make monitor show windows start. then enter windows-->enter control panel --> display--> setting --> monitor -->
choose the refrash frequency to lower stage (at least 60 Hz)
until no message pop on the monitor.
heop help you fix it.
Posted on May 21, 2009
Get rid of "Out Of Range" message on e218c1 monitor.
The device driving the monitor is exceeding the horizontal and vertical frequencies that the monitor can display .....thus the "out of range". The specs for this state that the Horizontal Freq. is 80Khz and the Vertical Rate is 75hz. If you are driving this monitor from a computer running Windows, reboot the PC and use the F8 key to put it in SAFE mode. This will cause the video driver to default to a rate that the monitor can handle. Then go into the screen resolution settings and reset them. The native resolution of the monitor is 1680x1050 at 60 Hz. Exceed that and you'll get the "out of range"
Sep 10, 2014 | Envision Peripherals 22"" envision e218c1...
Tip
Planar PX2710MW frequency out-of-range
After a computer reboot, about 8 out of 10 times the monitor would display a blue "frequency out of range" message. It would take several power off/on cycles for the monitor to finally display Microsoft Windows.
I called Planar tech support. They were super-nice. After about 15 minutes in which I shared my screen with them, the tech suggested I go into thePX2710MW's main menu (i.e. "Button 1") and then click "memory recall".
Problem solved! Wow.
on Feb 26, 2016 | Planar PX2710MW Monitor
Please help.. my monitor has no display and my don't even beep. the LED in the monitor turns back to orange after few seconds. cpu, disk drives and ram are working..
This is one of the serious problem that arises because if you set your monitor with a high resolution with high frequency, then the monitor doesn't display anything as it's frequency is out of the rang or limit of the monitor's actual resolution capacity. Each monitor will have a limit of max frequency that is said to be the Refresh rate (for each and every resolution setting the display is refreshed.) When high resolution is set with high frequency that is not supported by the monitor, it then display a message like "frequency out of range". If you press ESC key within the few seconds of this setting, it will revert back to its initial resolution. But if you continued with the setting of same High resolution with High frequency, the monitor is not going to display anything because its frequency is out of the range. Most of old monitors like CRT's etc doesn't support 1024×768 at a refresh rate greater than 60Hz.
Jun 20, 2011 | Asrock P4I45GV R5 Motherboard
Frequency out of range
Try to set the monitor refresh rate to Adapter Default despite of Optimal or lower rate of refresh. For this first download the manual of your monitor and check what is the highest refresh rate your monitor can suport. Then goto the display properties and set the adapter refresh rate to Adapter Default. In most cases such problem is solved. You did not mentioned the OS. This method is applicable in Windows only. (ehteshamhusain@gmail.com)
Jul 23, 2009 | HP Compaq FS7600 17" CRT Monitor
View sonic -E70fB monitor displaying H.V frequency out of range when ever i play a game on the monitor screen it is displaying h.v frequency out of range....how to solve this problem
view sonic -E70fB monitor displaying H.V frequency out of range
Jun 06, 2009 | ViewSonic G70F 17'' Monitor + Wyse Winterm...
You need to install the video drivers for your monitor. Go into SAFE mode to install them.
Mar 29, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
Out of range frequency
Lower the PC display resolution to a lower refresh rate.
Jan 09, 2009 | LG 42LC2D 42 in. LCD HDTV
OUT OF RANGE on monitor screen
you have to change frequency of monitor to work smoothly form display property.
Out of Range is frequency is not matching
To solve this, wwhile booting Press F8 to get advanced boot menu from that select "Enable VGA mode"
change the display properties
right click on desktop - Select properties - Settings - Advanced (from bottom) - goto monitor tab - change the frequecny to default. and restart the system normal mode
May 25, 2008 | XFX GeForce FX 5200 Graphic Card
Feb 02, 2008 | Balance CM2017 17" Monitor
E-Machines eMachines Monitor E15T4 Logo
511 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
