Question about Proform LX660 Treadmill Walking Belt
The treadmill stops after about 20 minutes or so. I push the fuse back in, and then I can start it again. It shuts off again after 15 - 20 minutes or less. Can I replace the fuse, or what is the problem?
Same problem
Posted on Jul 17, 2010
  • 15 Answers
Try lubricating the running belt. Any decent sized fitness store should have a lubrication kit. Also, make sure the machine is plugged into a dedicated circuit. Meaning, there are no other devices on the same circuit as the treadmill. Not just the same outlet, but the entire circuit of the room you have the treadmill in. You also want to make sure it's not on any extension cords. Plug it into a surge protector (power bar with a cord less than 6') and then directly into the wall. Those are the 3 main culprits why treadmills shut down after a short period of time.
Posted on Jul 10, 2010
Car shuts of suddenly while driving. Starts back up after 20 minutes.
When the gas-cap is plugged, you build up vacuum in the gas- tank and cause the gas flow to stop.
Use premium gas only, ETHANOL in the mix is attracting moisture/water which is part of the problems.
Jun 26, 2015 | Cars & Trucks
My treadmill stops running after 3 minutes. It shuts down and I have to reset and start over again. After another 3 minutes, it shuts off again.
Sounds like a motor or electrical system cooling problem. Could be dirt or blocked motor. Try Computer air blast can and or a vacuum to clean out motor and electronics.
Mar 04, 2015 | Proform Crosswalk Advanced Cr 525i 525x...
Pacemaster Pro Plus treadmill popping fuse
You need to replace the walking belt. Don't use the machine until you've replaced that.
May 22, 2017 | Exercise & Fitness
My t9600hrt treadmill stopps working after about 15min and then i can start it up again and same
Lube the treadmill for deck belt+roller bearing too.
This happen because the lack of maintenance schedule.
See the video, if after you fix it, the problem remain, is TIME to replace the old deck board.
God bless you
Feb 25, 2013 | Vision Fitness T9600 Deluxe Treadmill
Pro-form 370e crosswalk treadmill when the start button is pushed it starts up then stops immediately.
1)Lube the deck belt, this a problem by lack of maintenance, this produce enough friction and shut down the machine, by protecting the electronic system.
2) Test the input voltage motor, if there are voltage, the motor need repair.
3) Test the output voltage board, for input voltage motor, if there are NOT voltage the board is faulty.
God bless you
May 15, 2012 | Proform 370E Treadmill Walking Belt
My treadmill runs for 15 minutes than stops for a minute than start up for 10 minutes than stops, than start up
It is designed to be able to be restarted after about 5 minutes. When it stops, wait 5 to 10 minutes, reset the circuit breaker. Of course you still have the same problem.
The motor contoller board is most likely overheating do to friction, so you're going to need to lubricate the walking belt(this should actually be done every 6 months) you can order a kit on ebay for about 15-20 bucks, it's called " lube n walk ", and no, I don't sell it, but I use it on the treadmills I service.
I recomend you loosen the belt one full turn on each side before you lube the belt, apply the lube and run the treaadmill for one mile without anyone on it and then let it rest for a while.
After that give it a try. if the belt slips, then tighten it back up one turn, but don't over tighten it.
I also recomend using a single outlet surge supressor.
That should solve your problem.
Jan 11, 2011 | RTO Image 15.0R Treadmill Walking Belt
Windshiled wipers will work on the intermittet stage for about 10-15 minutes then automatically goes to regular speed and will not shut off. When stop vehicle and shut engine off and let sit 15-20 minutes...
windshiled wipers will work on the intermittet stage for about 10-15 minutes then automatically goes to regular speed and will not shut off. When stop vehicle and shut engine off and let sit 15-20 minutes wipers will shut off. When needed again same thing will happen This is on a 2003 Chevrolwt express Va
Feb 09, 2010 | 2003 Chevrolet Express
Engine stops running after warming up.
you have a failing crankshaft position sensor
Apr 13, 2009 | 1990 Oldsmobile Cutlass Supreme Conv
Proform LX660 Treadmill Walking Belt Logo
1,237 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
