Question about Pentair 3hp Whisperflo Pool Pump In - Ground
Pentair pool pump strainer basket has a lot of air bubbles never seem to fill up .
  • 366 Answers
Either you have a suction side air leak or the pump is too large for the plumbing and is cavitating.
Posted on Jul 11, 2010
Why is the pump pulling water but blowing air as well as water in the pool?
look for small crack in strainer housing or missing o-ring on cover , i use a eye dropper of blue dye on outside !! of strainer housing , a quick look at pool return and you'll see where the crack is , dry out housing 1st but superglue has saved many a cracked strainer from replacemnet
May 08, 2014 | Pentair "Pentair" In Ground Pool Pump ...
My pump is running but pulling no water from the pool. It ran ok for 1/2 a day but a lot of air bubbles into the pool. Now it will not pull water again.
First of do not let the pump continue to run with out pumping water, permanent damage may result.
A couple of thing could be your problem. 1-Make sure the basket in your strainer is not plugged up preventing water from freely flowing through it.
2-Most likely you are sucking air in from the lid on the pump where the strainer is, you may need to replace the o-ring(s) and be sure to get the waterproof grease from the pool store and lubricate the o-ring(s) liberally and try it again.
Good Luck
Jun 16, 2011 | Plumbing
Not pumping strong. Filter pressure gauge is going low.
Could be air entering the pump on the suction side - dead giveaway is a stream of bubbles entering the pool, possible causes are damage/faulty pipe joint, leak at strainer basket - is the o-ring clean and in place, is the lid craked? Other possibility is leaves etc caught in the impeller caused by damaged or missing strainer basket.
Jan 23, 2011 | Pentair 011515 WhisperFlo FullRated Energy...
I came back from vacation to find the pool not running. Power must have triped while gone. Turned power back on at the breaker. Went to the autopilot to turn system on. Autopilot was fine and had power but...
It sounds like your pool pump might have lost its prime. Make sure the lid is on and is secured tightly. Check your water level to make sure that it is above the skimmers. Make sure the suction lines, pump strainer, and pump pot are full of water. After you check these things, re-prime. If this still doesn't solve the problem, also check for clogged baskets and worn out gasket/valve. Make sure that you don't have an visible air leaking in the pool (look for bubbles).
Dec 13, 2010 | Pentair Whisperflo 1 12 Hp Pool Pump Wf26...
Losing pressure after about 15 mins pool pump stars really well but then seems to lose pressureleaf catcher before pemp seems to get air in it is this pump or pipes
If the inlet strainer gets air in it, the pump will lose prime. Fill the inlet strainer basket with water, make sure the cover is on air tight. Start the pump and watch the inlet strainer, the amount of air trapped should not increase, if it does, you have a leak somewhere on the piping between the pool and the pump.
Nov 19, 2010 | Plumbing
I have a Whiperflo 3hp pool pump. The water
There are a couple things that you will need to check when pool pumps start losing pressure. Air bubbles are definitely one step, but check these things as well. Check you impeller to see if there is a clog or obstruction. You pump strainer could also be clogged. It could be that your o-ring needs to be replaced also. Try these things, reprime the pump, and see if it maintains pressure.
Jul 19, 2010 | Pentair 3hp Whisperflo Pool Pump In -...
We do not know where the air filter valves are
Air filter?
Remove the strainer basket cover ... fill with water ... check the gasket ... replace if questionable ... close the cover and SNUG the top down. Start the pump ... it should run just fine.
If you are sucking air, tighten the strainer basket cover a little.
Still sucking air? You will have to find the air leak. You might plug the leak with plumbers putty.
May 29, 2010 | Jacuzzi Cyget In Ground Pool Pumps
I have Hayward earth filter for the pool along with a Pentair Mini Max 100 pool heater - first time starting both for the season and the filter motor is making a straining noise. For the few minutes its...
make sure all vents are clean check to see if there is anything stuck in impeller with pump off take straner basket out look at opening going back to filter is water filling the strainer basket
Jun 17, 2009 | Hayward 1.5 Hp Northstar High Performance...
In-g pool loss of pressure and bubbles from return line any ideas
If you notice bubbles in the water returning into the pool from the eyeball/discharge, or water in the strainer basket is visibly swirling (bubbles visible) odds are you need you replace the o-ring on the lid of the strainer basket in the front of the pump. This basket may also be clogged with debris, which also effect pressure. Could also be a cracked or warped strainer lid. Should be easy to see when you remove to check o-ring. Once you remove the strainer o-ring make sure you lube it with a good silcone based lube.
May 18, 2009 | Hayward Sand Filter System & Tank 21" 1...
Air in filter on hayward above ground pool.
I had similar situation.try removing winterizing plug,wrap with teflon tape, make sure no debris on threads. This worked for me. Tony
Apr 28, 2009 | Pool & Spa
Pentair 3hp Whisperflo Pool Pump In - Ground Logo
427 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
