I was looking for the same info on a Haier 10" HLT10 portable. Try 1481 and 1491. These codes were listed for an ATT-Uverse URC, however, they did not work for me on the portable.
i do not think it would work with your tv. there has been problems when tech installed uverse on dozens of tv. you can try to purchase an universal remote and see if that works. it is just like a jvc vcr/dvd player/recorder which will not work with any tv but jvc. you can also call att tech to help
Yes you have to use the recommended Uverse codes, and follow the directions to enter the code. Hold the tv button down, on the Uverse remote, then with it stil held down add the OK button, let go of both, then you will see the lights at the top of Uverse remote light up, it is then ready to accept the code, it will be a four digit code, Go to [email protected], and look under TV, then programming the remote is there. Put remote Code in the att search box if you can't find it.
Hi, Maybe too late for you but ATT just gave me a code that works with my Vizio plasma. Code is 1343. Even the mute works correctly. They gave me some others to try but I didn't need them. Other codes were 1018, 0030 and 0056.
1343 or 1005 are the codes - press the TV mode button and the OK button together - the release at the same time - the top row of mode buttons needs to blink twice - then enter the code - the TV button should blink 2 times - try the power and volume buttons - if it worked then be sure to press the ATT mode button again after so you can change the channels
Most Polaroid flat-screen TVs won't program to the Uverse remotes. Try buying a different universal remote that shows coding for both Uverse and Polaroid.
